주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Mac mini Model A1283 Internal Frame Replacement
필요한 것
    1. Mac mini Model A1283 Internal Frame Replacement, Top Housing: 1 단계, 이미지 2개 중 1개 Mac mini Model A1283 Internal Frame Replacement, Top Housing: 1 단계, 이미지 2개 중 2개
      • Power down your Mac mini, disconnect all of the cables, and flip it over.
      • Insert the Jimmy into the crack between the aluminum top housing and the plastic lower housing.
      • The Jimmy should reach a stop about 3/8" down.
      댓글 쓰기
    2. Mac mini Model A1283 Internal Frame Replacement: 2 단계, 이미지 3개 중 1개 Mac mini Model A1283 Internal Frame Replacement: 2 단계, 이미지 3개 중 2개 Mac mini Model A1283 Internal Frame Replacement: 2 단계, 이미지 3개 중 3개
      • Gently bend the Jimmy outwards to pry the crack open a little larger and lift the lower housing up a small amount.
      • There are several plastic clips on the lower housing that fit into a channel in the aluminum top housing. Your goal is to use the Jimmy to push these clips inward enough to free them from the channel, while gently pulling up on the lower housing.
      댓글 쓰기
    3. Mac mini Model A1283 Internal Frame Replacement: 3 단계, 이미지 2개 중 1개 Mac mini Model A1283 Internal Frame Replacement: 3 단계, 이미지 2개 중 2개
      • Once you have the first side free, rotate the Mac mini and start prying up on the front edge.
      • Use the same prying motion to both bend the clips inward and lift the lower housing up out of the top housing.
      댓글 쓰기
    4. Mac mini Model A1283 Internal Frame Replacement: 4 단계, 이미지 2개 중 1개 Mac mini Model A1283 Internal Frame Replacement: 4 단계, 이미지 2개 중 2개
      • You may need to move the Jimmy along the edge to pry up all of the clips. Be patient and do a little bit at a time.
      댓글 쓰기
    5. Mac mini Model A1283 Internal Frame Replacement: 5 단계, 이미지 2개 중 1개 Mac mini Model A1283 Internal Frame Replacement: 5 단계, 이미지 2개 중 2개
      • Keep working around the perimeter, freeing the clips along the final edge.
      댓글 쓰기
    6. Mac mini Model A1283 Internal Frame Replacement: 6 단계, 이미지 2개 중 1개 Mac mini Model A1283 Internal Frame Replacement: 6 단계, 이미지 2개 중 2개
      • Flip the Mac mini back over and lift the top housing off of the lower housing.
      댓글 쓰기
    1. Mac mini Model A1283 Internal Frame Replacement, Internal Frame: 7 단계, 이미지 1개 중 1개
      • In the next few steps you will be removing the AirPort and Bluetooth antennas (shown in red) from the internal frame. Be very careful, as breaking the brackets will require replacing the internal frame.
      • We will first remove the AirPort antenna, located in the lower left corner of this picture.
      댓글 쓰기
    2. Mac mini Model A1283 Internal Frame Replacement: 8 단계, 이미지 2개 중 1개 Mac mini Model A1283 Internal Frame Replacement: 8 단계, 이미지 2개 중 2개
      • Slightly squeeze the two retaining arms toward each other and lift the AirPort antenna off its post.
      • Squeezing the two posts excessively will surely break them off the internal frame. Work delicately.
      • During reinstallation, you will have to slightly squeeze the two posts together so they fit into the openings on the AirPort antenna board.
      댓글 쓰기
    3. Mac mini Model A1283 Internal Frame Replacement: 9 단계, 이미지 2개 중 1개 Mac mini Model A1283 Internal Frame Replacement: 9 단계, 이미지 2개 중 2개
      • The two Bluetooth antenna boards simply lift off the internal frame.
      • Grab the Bluetooth antenna nearest the port side of the computer by the edges of the board and pull it straight up off the internal frame.
      • Pull carefully, as it may offer significant resistance and release suddenly.
      댓글 쓰기
    4. Mac mini Model A1283 Internal Frame Replacement: 10 단계, 이미지 1개 중 1개
      • Remove the antenna board near the front of the mini by pulling it straight up off the internal frame.
      • If necessary, remove the piece of tape securing the antenna leads to the internal frame.
      • Be sure to keep track of the springs under each of the three antenna boards.
      댓글 쓰기
    5. Mac mini Model A1283 Internal Frame Replacement: 11 단계, 이미지 1개 중 1개
      • Use the flat end of a spudger to pry the audio ribbon cable connector up off the audio board.
      댓글 쓰기
    6. Mac mini Model A1283 Internal Frame Replacement: 12 단계, 이미지 1개 중 1개
      • Remove the following four screws securing the internal frame to the bottom housing:
      • Three 6.7 mm Phillips #00 screws
      • One 9.5 mm Phillips #00 screw
      • The screw in the lower right corner of this image is recessed deep in the internal frame and longer than the other three screws. A flashlight and a thin screwdriver aid in removal.
      댓글 쓰기
    7. Mac mini Model A1283 Internal Frame Replacement: 13 단계, 이미지 1개 중 1개
      • Lift the internal frame off the bottom housing, starting at the rear edge, until you feel the concealed edge connector on the motherboard disconnect. Then lift straight off, minding the bluetooth and 802.11 antenna cables.
      • When reassembling, the wifi antenna wire routes to the inside of the vent and then over the top of the vent.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 4명이 해당 안내서를 완성하였습니다.
작성자
10다른 기여자 명과 함께
Walter Galan
710,648 평판
안내서 1,203개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 10
지난 30일: 51
전체 시간: 11,123
