주요 콘텐츠로 건너뛰기
MacBook Air 11" Late 2010 AirPort/Bluetooth Card Replacement
필요한 것
  1. MacBook Air 11" Late 2010 AirPort/Bluetooth Card Replacement, Lower Case: 1 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    P5 Pentalobe Screwdriver Retina MacBook Pro and Air
    $5.99
    • Before proceeding, close your computer and lay it on a soft surface top-side down.
    • Remove the following ten screws:
    • Two 8 mm 5-point Pentalobe screws
    • Eight 2.5 mm 5-point Pentalobe screws
    • The special screwdriver needed to remove the eight 5-point Pentalobe screws can be found here.
    I recommend that one of the tools you obtain is a jeweler's loupe that mounts on your glasses. It makes things easier.
    blairweaver - 답글
    This is not correct. You need the pentalobe tool at this point.
    Duane Hellums - 답글
  2. MacBook Air 11" Late 2010 AirPort/Bluetooth Card Replacement: 2 단계, 이미지 1개 중 1개
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
  3. MacBook Air 11" Late 2010 AirPort/Bluetooth Card Replacement, Battery: 3 단계, 이미지 2개 중 1개 MacBook Air 11" Late 2010 AirPort/Bluetooth Card Replacement, Battery: 3 단계, 이미지 2개 중 2개
    • In this step you will disconnect the battery to help avoid shorting out any components during service.
    • Use the flat end of a spudger to pry both short sides of the battery connector upward to disconnect it from its socket on the logic board.
    • Bend the battery cable slightly away from the logic board so the connector will not accidentally contact its socket.
  4. MacBook Air 11" Late 2010 AirPort/Bluetooth Card Replacement, AirPort/Bluetooth Card: 4 단계, 이미지 2개 중 1개 MacBook Air 11" Late 2010 AirPort/Bluetooth Card Replacement, AirPort/Bluetooth Card: 4 단계, 이미지 2개 중 2개
    • Use the flat end of a spudger to pry both antenna connectors up from their sockets on the AirPort/Bluetooth card.
  5. MacBook Air 11" Late 2010 AirPort/Bluetooth Card Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the single 2.9 mm T5 Torx screw securing the AirPort/Bluetooth card to the logic board.
  6. MacBook Air 11" Late 2010 AirPort/Bluetooth Card Replacement: 6 단계, 이미지 2개 중 1개 MacBook Air 11" Late 2010 AirPort/Bluetooth Card Replacement: 6 단계, 이미지 2개 중 2개
    • Slightly lift the free end of the AirPort/Bluetooth board and pull it out of its socket on the logic board.
    • Remove the AirPort/Bluetooth board from the Air.
결론
다른 11명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Andrew Bookholt
592,098 평판
안내서 619개를 작성함
댓글 한 개
Hi Andrew, thanks for your guide on MacBook Air 11" Late 2010 Airport-Bluetooth Card. I am desperately trying to purchase new cables with female connectors to connect to the Card's male jacks. I ignore the size which is important: I tried MHF 4 too small, MHF 1 too big, so before buying wrong cables again I wonder if you can tell me what size is the Card's jack connection. I thank you for your help in advance.
Max
Massimo Bazzano - 답글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 11
지난 30일: 65
전체 시간: 23,483
