소개
Internal Prerequisite.
필요한 것
Use the flat end of a spudger to pry both short sides of the battery connector upward to disconnect it from its socket on the logic board.
Bend the battery cable slightly away from the logic board so the connector will not accidentally contact its socket.
거의 끝나갑니다!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
My macbook air's configuration (Mid-2011 core i5) has a different battery connector. It slides into a receptacle on the logic board. If your battery connector does not look like the one pictured, use the pointy end of a spudger to depress the small indentation in the middle of the battery connector cable terminal, and pull aft to release the clasp mechanism.
Ethan Cross - 답글
Maybe your battery connector doesn't match the picture because these instructions are for the mid-2012 model and yours is mid-2011.
colleenthompson - 답글
