주요 콘텐츠로 건너뛰기
MacBook Air 11" Mid 2011 Solid-State Drive Replacement
필요한 것
  1. MacBook Air 11" Mid 2011 Solid-State Drive Replacement, Lower Case: 1 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    P5 Pentalobe Screwdriver Retina MacBook Pro and Air
    $5.99
    • Before proceeding, close your computer and lay it on a soft surface top-side down.
    • Remove the following ten screws:
    • Two 8 mm 5-point Pentalobe screws
    • Eight 2.5 mm 5-point Pentalobe screws
    • The special screwdriver needed to remove the eight 5-point Pentalobe screws can be found here.
  2. MacBook Air 11" Mid 2011 Solid-State Drive Replacement: 2 단계, 이미지 1개 중 1개
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
  3. MacBook Air 11" Mid 2011 Solid-State Drive Replacement, Battery: 3 단계, 이미지 2개 중 1개 MacBook Air 11" Mid 2011 Solid-State Drive Replacement, Battery: 3 단계, 이미지 2개 중 2개
    • In this step you will disconnect the battery to help avoid shorting out any components during service.
    • Use the flat end of a spudger to pry both short sides of the battery connector upward to disconnect it from its socket on the logic board.
    • Bend the battery cable slightly away from the logic board so the connector will not accidentally contact its socket.
  4. MacBook Air 11" Mid 2011 Solid-State Drive Replacement, Solid-State Drive: 4 단계, 이미지 1개 중 1개
    • Remove the single 2.9 mm T5 Torx screw securing the SSD to the logic board.
  5. MacBook Air 11" Mid 2011 Solid-State Drive Replacement: 5 단계, 이미지 2개 중 1개 MacBook Air 11" Mid 2011 Solid-State Drive Replacement: 5 단계, 이미지 2개 중 2개
    • Use a spudger to help lift the free end of the SSD just enough to grab it with your other hand.
    • Do not lift the end of the SSD excessively.
    • Pull the drive straight out of its socket and remove it from the logic board.
    • When reinstalling the SSD, be sure it is properly seated before reinstalling its retaining screw.
결론
다른 113명이 해당 안내서를 완성하였습니다.
작성자
8다른 기여자 명과 함께
Walter Galan
706,103 평판
안내서 1,203개를 작성함
16가이드 댓글
Note: if you're installing a blank SSD, you'll want to format it with Disk Utilities) before the OS X installer will recognize it.
aaronmiller - 답글
Could not have been any easier, with this guide.
Thank you very much!
916sp - 답글
is it possible to replace an 128 GB Solid State Drive with an 240 GB? (MacBook Air, 11", Mid 2011)
zimmermatthias - 답글
Does anyone know if the Samsung 960 pro 512gb m.2 drive is compatible with this machine?
Mark - 답글
No, is not, I just bought a 1TB Samsung 960 EVO m.2 and had to return it, for not being compatible. (is smaller and the pin-out is not the same)
fjlbandeira -
댓글 쓰기
조회 통계:
지난 24시간: 16
지난 7일: 166
지난 30일: 732
전체 시간: 253,131
