주요 콘텐츠로 건너뛰기
MacBook Air 13" Early 2014 Solid-State Drive Replacement
필요한 것
    • Before proceeding, power down your MacBook. Close the display and lay it on a soft surface, top-side down.
    • Use a P5 Pentalobe driver to remove ten screws securing the lower case, of the following lengths:
    • Two 9 mm screws
    • Eight 2.6 mm screws
  1. MacBook Air 13" Early 2014 Solid-State Drive Replacement: 2 단계, 이미지 1/1
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
  2. MacBook Air 13" Early 2014 Solid-State Drive Replacement, Battery Connector: 3 단계, 이미지 1/2 MacBook Air 13" Early 2014 Solid-State Drive Replacement, Battery Connector: 3 단계, 이미지 2/2
    • To ensure that everything is de-energized and won't turn on while you're working, it is recommended that you disconnect the battery.
    • Grab the clear plastic pull tab attached to the battery connector and pull it parallel to the board toward the front edge of the Air.
    • Do not lift upward on the connector as you disconnect it or you risk damage to the connector socket.
  3. MacBook Air 13" Early 2014 Solid-State Drive Replacement, Solid-State Drive: 4 단계, 이미지 1/1
    • Remove the single 2.9 mm T5 Torx screw securing the SSD to the logic board.
  4. MacBook Air 13" Early 2014 Solid-State Drive Replacement: 5 단계, 이미지 1/2 MacBook Air 13" Early 2014 Solid-State Drive Replacement: 5 단계, 이미지 2/2
    • Gently lift the end of the SSD about half an inch and pull it straight out of its socket on the logic board.
    • Don't lift the SSD more than half an inch—doing so may damage the SSD or its socket on the logic board.
    • When reinstalling the SSD, be sure it is properly seated before reinstalling its retaining screw.
결론
다른 86명이 해당 안내서를 완성하였습니다.
Jeff Suovanen
회원 가입일: 08/06/13
409,626 평판
안내서 259개 작성하였습니다
iFixit iFixit 회원
Community
141 회원들
안내서 17,637개 작성하였습니다
23 댓글
Fairly straight forward once you get the right screwdrivers. Took me less than 10 minutes.
Jesse Collis - 답글
Very simple and straight forward replacement. First-party SSD replacement can be found on ebay (typically removed from parted-out MacBook Airs). Currently they're aren't any third-party parts available.
rickhendricks - 답글
Don't forget to re-attach the battery cable before closing up the underside... not that I did or anything ;-/
phil - 답글
The Relevant Parts list all has incorrect links. Bait & Switch??
Examples:
"$199.95 Macbook Air 11" and 13" (Mid 2013/Early 2014) SSD, 256 GB"
Actually supplies: 128GB USED
"$349.95 Macbook Air 11" and 13" (Mid 2013/Early 2014) SSD, 512 GB"
Actually supplies: 256GB USED
carnthehawks - 답글
Whoops! Looks like we didn't update the details on those parts when we updated the part itself, sorry about that!
Sam Goldheart -
댓글 쓰기
조회 통계:
24 시간 전: 41
7일 전: 227
30일 전: 1,093
전체 시간: 272,017
