이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
Use this guide to replace the heat sink, or remove it for reapplication of thermal paste.
Be sure to apply a new layer of thermal paste before reinstalling your heat sink.
필요한 것
이 단계에 사용된 도구:P5 Pentalobe Screwdriver Retina MacBook Pro and Air$5.99
Use a P5 Pentalobe driver to remove ten screws securing the lower case, of the following lengths:
Two 9 mm screws
Eight 2.6 mm screws
Grab the clear plastic pull tab attached to the battery connector and pull it parallel to the board toward the front edge of the Air.
Use the flat end of a spudger to pry the I/O board cable connector up out of its socket on the I/O board.
Disconnect the I/O board by pulling its power cable away from its socket on the logic board.
Remove the two 4.9 mm T8 Torx screws securing the antenna cable retainer on the left display hinge to the upper case.
다른 7명이 해당 안내서를 완성하였습니다.
댓글 3개
Well imho a lil bit overkill from step 11 - you can easily unscrew with thin screwdriver the lonely heatsink screw near the rubber component
