이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Grab the clear plastic pull tab attached to the battery connector and pull it toward the front edge of the Air to disconnect the battery from the logic board.
Use the flat end of a spudger to pry the I/O board cable connector upward out of its socket on the I/O board.
While gently pulling the I/O board cable upward near its connection to the logic board, use the tip of a spudger to pry upward on alternating sides of the connector to help "walk" it out of its socket.
Remove the I/O board cable.
Use the tip of a spudger to carefully flip up the retaining flap on the fan cable ZIF socket.
Remove the following three screws securing the fan to the upper case:
One 3.6 mm T5 Torx screw
One 2.7 mm T5 Torx screw
One 3.6 mm T5 Torx screw with a short head
Lift the fan out of the upper case and carefully pull the fan ribbon cable out of its socket as you remove it from the Air.
Disconnect the I/O board by pulling the power cable away from its socket on the logic board.
Pull the camera cable parallel to the face of the I/O board toward the corner of the Air to disconnect it from its socket, using the tip of a spudger to help push the connector out of its socket.
Use the flat end of a spudger to pry the left speaker cable connector up and out of its socket on the I/O board.
De-route the left speaker cable from its retainer on the I/O board.
Use the flat end of a spudger to pry the microphone cable connector up and out of its socket on the I/O board.
Remove the single 3.6 mm T5 Torx screw securing the I/O board to the upper case.
Carefully lift the I/O board from its edge nearest the logic board and remove it from the upper case.
Remove the two 4.9 mm T8 Torx screws securing the antenna cable retainer on the left display hinge to the upper case.
Push the antenna cable retainer out of the way and remove the 3 mm T5 Torx screw securing the end of the heat sink to the upper case.
Remove the four 2.5 mm T5 Torx screws securing the heat sink to the logic board.
다른 30명이 해당 안내서를 완성하였습니다.
댓글 4개
Excellent instructions / guide. Replaced both heat sink and fan without a hitch. Thank you!
I wanted to bring my old 2011 MBA back to life since its still running strong, so I followed this with a new thermal paste, good cleaning and a new battery, its like a brand new computer now. Glad I got the ifixit kit as well when I ordered the battery. Hope to keep this MBS going another year or two before I upgrade. Now I need to do the same with my MBP 2010 for fun.
I have a mid-2011 MacBook Air identical to the model in the instructions, and it frequently gets up to 80C when running under a heavier load. I am planning to disassemble it entirely and repaste the machine, and fully blow out the inside. I will post on here when I get it done and see how it runs! Thanks for the guide!
thanks alot.. I followed the procedure to replace the thermal paste and it was great.but i didn’t realise a difference in heat and sound of fan.
