주요 콘텐츠로 건너뛰기
MacBook Air 13" Mid 2011 Left Speaker Replacement
필요한 것
    • Before proceeding, power down your MacBook. Close the display and lay it on a soft surface, top-side down.
    • Use a P5 Pentalobe driver to remove ten screws securing the lower case, of the following lengths:
    • Two 9 mm screws
    • Eight 2.6 mm screws
  1. MacBook Air 13" Mid 2011 Left Speaker Replacement: 2 단계, 이미지 1/1
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
  2. MacBook Air 13" Mid 2011 Left Speaker Replacement, Battery: 3 단계, 이미지 1/2 MacBook Air 13" Mid 2011 Left Speaker Replacement, Battery: 3 단계, 이미지 2/2
    • Grab the clear plastic pull tab attached to the battery connector and pull it toward the front edge of the Air to disconnect the battery from the logic board.
    • Do not lift upward on the connector as you disconnect it.
  3. MacBook Air 13" Mid 2011 Left Speaker Replacement: 4 단계, 이미지 1/1
    • Remove the following five screws securing the battery to the upper case:
    • Three 6.3 mm T5 Torx screws
    • Two 2.4 mm T5 Torx screws
  4. MacBook Air 13" Mid 2011 Left Speaker Replacement: 5 단계, 이미지 1/1
    • When handling the battery, avoid squeezing or touching the four exposed lithium polymer cells.
    • Lift the battery from its edge nearest the logic board and remove it from the upper case.
    • When installing the new battery, if there is a thin plastic film on your replacement battery, do not attempt to remove it. It is glued on and protects the battery pack while it is inside the MacBook.
    • If you're installing a new battery, you should calibrate it after installation:
    • Charge it to 100%, and then keep charging it for at least 2 more hours. Then, unplug and use it normally to drain the battery. When you see the low battery warning, save your work, and keep your laptop on until it goes to sleep due to low battery. Wait at least 5 hours, then charge your laptop uninterrupted to 100%.
    • If you notice any unusual behavior or problems after installing your new battery, you may need to reset your MacBook's SMC.
  5. MacBook Air 13" Mid 2011 Left Speaker Replacement, Left Speaker: 6 단계, 이미지 1/1
    • Use the flat end of a spudger to pry the left speaker cable connector up and out of its socket on the I/O board.
    • Pry up from beneath the wires.
  6. MacBook Air 13" Mid 2011 Left Speaker Replacement: 7 단계, 이미지 1/1
    • De-route the left speaker cable from its retaining clip on the I/O board.
  7. MacBook Air 13" Mid 2011 Left Speaker Replacement: 8 단계, 이미지 1/3 MacBook Air 13" Mid 2011 Left Speaker Replacement: 8 단계, 이미지 2/3 MacBook Air 13" Mid 2011 Left Speaker Replacement: 8 단계, 이미지 3/3
    • Use the flat end of a spudger to pry the left speaker off the adhesive securing it to the upper case.
    • Remove the left speaker from the upper case.
결승점
다른 10명이 해당 안내서를 완성하였습니다.
Andrew Bookholt
583,553 평판
안내서 619개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 9
전체 시간: 7,273
