이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
Use this guide to replace the AirPort/Bluetooth card.
필요한 것
이 단계에 사용된 도구:P5 Pentalobe Screwdriver Retina MacBook Pro and Air$5.99
Use a P5 Pentalobe driver to remove ten screws securing the lower case, of the following lengths:
Two 9 mm screws
Eight 2.6 mm screws
Grab the clear plastic pull tab attached to the battery connector and pull it parallel to the board toward the front edge of the Air.
Use the flat end of a spudger to pry both antenna connectors up from their sockets on the AirPort/Bluetooth card.
다른 20명이 해당 안내서를 완성하였습니다.
댓글 3개
My Macbook Air was bought October 2012 but has this WiFi/BT card. It failed and the machine would not boot, even to recovery or single-user mode, and removing the card allowed it to boot.
Is possible to replace this with a newer card? Be nice to have wifi-6 and Bluetooth 5.2
