주요 콘텐츠로 건너뛰기
MacBook Air 13" Retina Display 2019 Trackpad Replacement
필요한 것
  1. MacBook Air 13" Retina Display 2019 Trackpad Replacement, Remove the screws securing the lower case: 1 단계, 이미지 1개 중 1개
    • Before starting this procedure, you should disable your Mac's Auto Boot feature. Auto Boot powers on your Mac when you open the lid, and may be accidentally triggered during disassembly. Use this guide to disable Auto Boot.
    • If your MacBook is running Big Sur v11.1 or later, disabling Auto Boot may not work. You can proceed normally, but make sure to disconnect the battery as soon as you're inside.
    • Completely power off and unplug your MacBook Air before you start. Close the display and flip the entire laptop upside-down.
    • Use a P5 driver to remove the following screws:
    • Two 7.9 mm screws
    • Two 7.1 mm screws
    • Six 2.6 mm screws
  2. MacBook Air 13" Retina Display 2019 Trackpad Replacement, Remove the lower case: 2 단계, 이미지 1개 중 1개
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
    • Remove the lower case.
    • After reassembly, your MacBook might not turn on until it's connected to a power source (a low power phone charger may work). To test your repair, plug in your charger, allow two minutes for your MacBook to turn on, and check that everything works as expected.
  3. MacBook Air 13" Retina Display 2019 Trackpad Replacement, Disconnect the battery: 3 단계, 이미지 1개 중 1개
    • Peel back the tape covering the battery connector enough to reveal the connector underneath.
  4. MacBook Air 13" Retina Display 2019 Trackpad Replacement: 4 단계, 이미지 2개 중 1개 MacBook Air 13" Retina Display 2019 Trackpad Replacement: 4 단계, 이미지 2개 중 2개
    • Use a spudger to slide the battery connector parallel to the logic board and out of its socket on the logic board.
  5. MacBook Air 13" Retina Display 2019 Trackpad Replacement, Disconnect the logic board: 5 단계, 이미지 2개 중 1개 MacBook Air 13" Retina Display 2019 Trackpad Replacement, Disconnect the logic board: 5 단계, 이미지 2개 중 2개
    • Use a T3 Torx driver to remove the two 1.4 mm screws securing the trackpad connector bracket.
    • Depending on the condition of your bits, a T4 Torx driver may fit better.
    • Remove the trackpad connector bracket.
  6. MacBook Air 13" Retina Display 2019 Trackpad Replacement: 6 단계, 이미지 2개 중 1개 MacBook Air 13" Retina Display 2019 Trackpad Replacement: 6 단계, 이미지 2개 중 2개
    • Use the flat end of a spudger to pry the trackpad cable connector up and out of its socket.
  7. MacBook Air 13" Retina Display 2019 Trackpad Replacement: 7 단계, 이미지 3개 중 1개 MacBook Air 13" Retina Display 2019 Trackpad Replacement: 7 단계, 이미지 3개 중 2개 MacBook Air 13" Retina Display 2019 Trackpad Replacement: 7 단계, 이미지 3개 중 3개
    • If the left speaker is already disconnected, skip this step.
    • Slide the tip of a spudger underneath the left speaker cable and pry straight up to disconnect the speaker.
    • With the connector disconnected, slide the flat end of a spudger under the cable to separate the adhesive securing the cable to the logic board.
  8. MacBook Air 13" Retina Display 2019 Trackpad Replacement: 8 단계, 이미지 2개 중 1개 MacBook Air 13" Retina Display 2019 Trackpad Replacement: 8 단계, 이미지 2개 중 2개
    • Use a T3 Torx driver to remove the two 1.3 mm screws securing the USB-C port connector bracket.
    • Remove the USB-C connector bracket.
  9. MacBook Air 13" Retina Display 2019 Trackpad Replacement: 9 단계, 이미지 2개 중 1개 MacBook Air 13" Retina Display 2019 Trackpad Replacement: 9 단계, 이미지 2개 중 2개
    • Use the flat end of a spudger to pry the USB-C cable connector up and out of its socket on the logic board.
  10. MacBook Air 13" Retina Display 2019 Trackpad Replacement: 10 단계, 이미지 3개 중 1개 MacBook Air 13" Retina Display 2019 Trackpad Replacement: 10 단계, 이미지 3개 중 2개 MacBook Air 13" Retina Display 2019 Trackpad Replacement: 10 단계, 이미지 3개 중 3개
    • Use a spudger to lift up the small locking flap on the sound board cable's ZIF connector.
    • Slide the sound board cable out of the ZIF connector.
  11. MacBook Air 13" Retina Display 2019 Trackpad Replacement: 11 단계, 이미지 1개 중 1개
    • Peel back the black tape covering the fan cable connector.
  12. MacBook Air 13" Retina Display 2019 Trackpad Replacement: 12 단계, 이미지 3개 중 1개 MacBook Air 13" Retina Display 2019 Trackpad Replacement: 12 단계, 이미지 3개 중 2개 MacBook Air 13" Retina Display 2019 Trackpad Replacement: 12 단계, 이미지 3개 중 3개
    • Use the tip of a spudger to lift up the locking flap on the fan cable's ZIF connector.
    • Slide the fan cable out of the ZIF connector.
  13. MacBook Air 13" Retina Display 2019 Trackpad Replacement: 13 단계, 이미지 2개 중 1개 MacBook Air 13" Retina Display 2019 Trackpad Replacement: 13 단계, 이미지 2개 중 2개
    • Use a T3 Torx driver to remove the two 1.4 mm screws securing the antenna cable bracket.
    • Remove the antenna cable bracket.
  14. MacBook Air 13" Retina Display 2019 Trackpad Replacement: 14 단계, 이미지 3개 중 1개 MacBook Air 13" Retina Display 2019 Trackpad Replacement: 14 단계, 이미지 3개 중 2개 MacBook Air 13" Retina Display 2019 Trackpad Replacement: 14 단계, 이미지 3개 중 3개
    • Insert the point of a spudger under one of the antenna cables close to the connector. Pry straight up to disconnect the cable.
    • Repeat for the other antenna cable.
  15. MacBook Air 13" Retina Display 2019 Trackpad Replacement: 15 단계, 이미지 2개 중 1개 MacBook Air 13" Retina Display 2019 Trackpad Replacement: 15 단계, 이미지 2개 중 2개
    • Use a T3 Torx driver to remove the two 1.5 mm screws securing the display cable connector bracket.
    • Remove the display cable connector bracket.
  16. MacBook Air 13" Retina Display 2019 Trackpad Replacement: 16 단계, 이미지 2개 중 1개 MacBook Air 13" Retina Display 2019 Trackpad Replacement: 16 단계, 이미지 2개 중 2개
    • Use the flat end of a spudger to pry up the display cable connector.
  17. MacBook Air 13" Retina Display 2019 Trackpad Replacement, Unscrew the logic board: 17 단계, 이미지 1개 중 1개
    • Use a T5 Torx driver to remove the following screws:
    • One 5.5 mm screw
    • Three 2.6 mm screws
    • Two 1.9 mm screws
  18. MacBook Air 13" Retina Display 2019 Trackpad Replacement, Remove the logic board: 18 단계, 이미지 1개 중 1개
    • Remove the logic board.
  19. MacBook Air 13" Retina Display 2019 Trackpad Replacement, Separate the trackpad cable adhesive: 19 단계, 이미지 3개 중 1개 MacBook Air 13" Retina Display 2019 Trackpad Replacement, Separate the trackpad cable adhesive: 19 단계, 이미지 3개 중 2개 MacBook Air 13" Retina Display 2019 Trackpad Replacement, Separate the trackpad cable adhesive: 19 단계, 이미지 3개 중 3개
    • Carefully slide an opening pick under the trackpad cable towards the keyboard connector to separate the adhesive securing it to the upper case.
    • If you have difficulty separating the adhesive, heat it slightly with an iOpener or hair dryer to soften the adhesive.
  20. MacBook Air 13" Retina Display 2019 Trackpad Replacement, Disconnect the keyboard: 20 단계, 이미지 3개 중 1개 MacBook Air 13" Retina Display 2019 Trackpad Replacement, Disconnect the keyboard: 20 단계, 이미지 3개 중 2개 MacBook Air 13" Retina Display 2019 Trackpad Replacement, Disconnect the keyboard: 20 단계, 이미지 3개 중 3개
    • Use the flat end of a spudger to lift the small locking flap on the keyboard ZIF connector.
    • The trackpad cable connects the logic board to both the keyboard and the trackpad.
    • Slide the keyboard cable straight out of its connector.
  21. MacBook Air 13" Retina Display 2019 Trackpad Replacement, Separate the trackpad cable adhesive: 21 단계, 이미지 2개 중 1개 MacBook Air 13" Retina Display 2019 Trackpad Replacement, Separate the trackpad cable adhesive: 21 단계, 이미지 2개 중 2개
    • Carefully slide an opening pick under the trackpad cable to separate the adhesive securing it to the battery.
    • If you have difficulty separating the adhesive, heat it slightly with an iOpener or hair dryer. Be careful not to overheat the battery.
  22. MacBook Air 13" Retina Display 2019 Trackpad Replacement, Remove the trackpad: 22 단계, 이미지 1개 중 1개
    • Use a T5 Torx driver to remove the following screws securing the trackpad:
    • One 3.2 mm screw
    • Eight 3.1 mm screws
  23. MacBook Air 13" Retina Display 2019 Trackpad Replacement: 23 단계, 이미지 2개 중 1개 MacBook Air 13" Retina Display 2019 Trackpad Replacement: 23 단계, 이미지 2개 중 2개
    • With the laptop still lying screen-side down, carefully open the laptop. The trackpad will stay sitting on the display.
    • Remove the trackpad from the MacBook. Take care not to scratch the display.
  24. MacBook Air 13" Retina Display 2019 Trackpad Replacement, Disconnect the trackpad cable: 24 단계, 이미지 3개 중 1개 MacBook Air 13" Retina Display 2019 Trackpad Replacement, Disconnect the trackpad cable: 24 단계, 이미지 3개 중 2개 MacBook Air 13" Retina Display 2019 Trackpad Replacement, Disconnect the trackpad cable: 24 단계, 이미지 3개 중 3개
    • Use the flat end of a spudger to lift the small locking flap on the trackpad's ZIF connector.
    • Slide the trackpad cable straight out of the ZIF connector.
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Adam O'Camb
회원 가입일: 04/11/15
216,267 평판
안내서 416개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 6
지난 7일: 39
지난 30일: 127
전체 시간: 9,304
