Use a P5 driver to remove the following screws:
Two 7.6 mm screws (with a 2.7mm collar)
Two 7.1 mm screws
Six 2.3 mm screws
Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
Remove the lower case.
Use a T3 torx driver to remove two 2.3mm screws from the battery PCB:
Use a T3 Torx driver to remove the one 1.1 mm screw securing the antenna cable bracket.
Remove the antenna cable bracket.
Lift the antenna bar straight up and out of the case. Take care not to snag the antenna bar on any cables or connectors.
Remove the antenna bar.
Use a T9 Torx driver to remove the six 4.7 mm screws securing the display hinges to the upper case.
다른 한 분이 해당 안내서를 완성하였습니다.
