주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
MacBook Core Duo Hard Drive Connector Replacement
필요한 것
  1. MacBook Core Duo Hard Drive Connector Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Use a coin or spudger to rotate the battery-locking screw 90 degrees clockwise.
  2. MacBook Core Duo Hard Drive Connector Replacement: 2 단계, 이미지 1개 중 1개
    • Lift the battery out of the computer.
  3. MacBook Core Duo Hard Drive Connector Replacement, Memory Cover: 3 단계, 이미지 1개 중 1개
    • Remove the three evenly-spaced Phillips screws from along the rear wall of the battery compartment.
    • The screws are captive to the metal memory cover.
    • When replacing the memory cover, use a spudger to re-insert the foam cushioning behind the rear wall for propper battery spacing.
  4. MacBook Core Duo Hard Drive Connector Replacement: 4 단계, 이미지 1개 중 1개
    • Lift up on L-shaped memory cover, slide it to the right, and lift it out of the computer.
  5. MacBook Core Duo Hard Drive Connector Replacement, Upper Case: 5 단계, 이미지 1개 중 1개
    • Remove the following 3 screws:
    • One 11 mm Phillips #00 in the middle of the case.
    • Two 14.5 mm Phillips #00.
    • If the screws stick in the case, you can use a magnetized screwdriver to draw them out.
    • The shorter of the three screws goes in the middle.
  6. MacBook Core Duo Hard Drive Connector Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the following 3 screws from the rear wall of the battery compartment:
    • Two 3 mm Phillips #00. (A1181 has three 3 mm screws and one 4 mm.)
    • One 4 mm Phillips #00 on the right side.
    • When reinstalling these screws, press gently on the lower case to line up the screw holes.
    • These screws easily strip, so be careful while taking these particular screws out.
  7. MacBook Core Duo Hard Drive Connector Replacement: 7 단계, 이미지 1개 중 1개
    • Remove the two 6 mm Phillips #00 screws from either side of the right wall of the battery compartment (not the ones closest to the battery connector).
  8. MacBook Core Duo Hard Drive Connector Replacement: 8 단계, 이미지 1개 중 1개
    • Remove the four 3 mm indicated Phillips #00 screws from the front wall of the battery compartment. When working from the left, remove the 2nd, 4th, 7th and 9th screw.
  9. MacBook Core Duo Hard Drive Connector Replacement: 9 단계, 이미지 1개 중 1개
    • Remove the following 4 screws from the back of the computer:
    • Two 7 mm shouldered Phillips on the far sides.
    • Two 10.5 mm Phillips toward the center.
    • Do not over-tighten these; you can cause the case to distort.
  10. MacBook Core Duo Hard Drive Connector Replacement: 10 단계, 이미지 1개 중 1개
    • Remove the two 5.2 mm shouldered Phillips #00 screws from the optical side of the computer.
    • It is not necessary to remove the similar screws on the other side of the computer.
  11. MacBook Core Duo Hard Drive Connector Replacement: 11 단계, 이미지 1개 중 1개
    • Starting near the display and working around to the front of the computer, pry up on the upper case. It is held with clips on the right above the optical drive. These will release with some firm lifting pressure.
    • Be careful when prying up the upper case. It's very easy to slice open a fingertip and thus provide the blood sacrifice the Mac gods sometimes require of those who insist on doing their own repairs.
    • There's a trackpad and keyboard ribbon connecting the upper case to the logic board, so don't pull the upper case off entirely just yet.
    • If you have trouble getting the clips to release, be careful that you are not prying the plastic top of the upper case away from its metal frame.
  12. MacBook Core Duo Hard Drive Connector Replacement: 12 단계, 이미지 1개 중 1개
    • While holding up the upper case (from the bottom or the top), use a spudger to pry up the orange trackpad and keyboard cable from its connector.
    • Take care to pry between the black socket and the white connector. You might have to pry on both sides for it to release properly.
    • Do not pry from the bottom or the top, but from the sides.
    • If you happen to break your upper case cable when removing the upper case, we stock the cable individually and we have a guide that makes replacing it easy.
  13. MacBook Core Duo Hard Drive Connector Replacement, Hard Drive Connector: 13 단계, 이미지 1개 중 1개
    • Use the white plastic pull-tab to slide the hard drive to the left and out of the computer.
  14. MacBook Core Duo Hard Drive Connector Replacement: 14 단계, 이미지 1개 중 1개
    • Disconnect the orange optical drive ribbon cable from the logic board.
  15. MacBook Core Duo Hard Drive Connector Replacement: 15 단계, 이미지 1개 중 1개
    • Disconnect the newly-revealed display data cable. If there is no pull-tab on the top of the connector, it may be helpful to use a spudger to disconnect this connector.
  16. MacBook Core Duo Hard Drive Connector Replacement: 16 단계, 이미지 1개 중 1개
    • Disconnect the (once again) newly-revealed hard drive cable.
  17. MacBook Core Duo Hard Drive Connector Replacement: 17 단계, 이미지 1개 중 1개
    • Deroute the hard drive connector cable from the four tabs along the edge of the optical drive.
  18. MacBook Core Duo Hard Drive Connector Replacement: 18 단계, 이미지 1개 중 1개
    • Remove the two Phillips screws securing the hard drive connector to the lower case.
  19. MacBook Core Duo Hard Drive Connector Replacement: 19 단계, 이미지 1개 중 1개
    • Carefully lift the hard drive connector out of the case slightly, and turn it over to reveal the IR sensor connector beneath. Use a spudger to flip up the tiny bar holding the cable in place.
    • Slide the orange IR sensor cable out of its connector, and lift the hard drive connector out of the computer.
결론
다른 26명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
iRobot
회원 가입일: 09/24/09
1 평판
안내서 636개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 10
지난 30일: 38
전체 시간: 45,276
