주요 콘텐츠로 건너뛰기
MacBook Core Duo Hard Drive Replacement
필요한 것
동영상 개요
  1. MacBook Core Duo Hard Drive Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Use a coin or spudger to rotate the battery-locking screw 90 degrees clockwise.
  2. MacBook Core Duo Hard Drive Replacement: 2 단계, 이미지 1개 중 1개
    • Lift the battery out of the computer.
  3. MacBook Core Duo Hard Drive Replacement, Memory Cover: 3 단계, 이미지 1개 중 1개
    • Remove the three evenly-spaced Phillips screws from along the rear wall of the battery compartment.
    • The screws are captive to the metal memory cover.
    • When replacing the memory cover, use a spudger to re-insert the foam cushioning behind the rear wall for propper battery spacing.
  4. MacBook Core Duo Hard Drive Replacement: 4 단계, 이미지 1개 중 1개
    • Lift up on L-shaped memory cover, slide it to the right, and lift it out of the computer.
  5. MacBook Core Duo Hard Drive Replacement, Hard Drive: 5 단계, 이미지 1개 중 1개
    • Grasp the white plastic tab attached to the hard drive and pull it to the right, removing the hard drive from the computer.
    • The hard drive goes back into its compartment with the label facing down.
  6. MacBook Core Duo Hard Drive Replacement, Hard Drive: 6 단계, 이미지 1개 중 1개
    • Remove the two black T8 Torx screws securing the silver bracket to the hard drive.
  7. MacBook Core Duo Hard Drive Replacement: 7 단계, 이미지 1개 중 1개
    • Rotate the hard drive and remove the two black T8 Torx screws on the other side of the drive.
  8. MacBook Core Duo Hard Drive Replacement: 8 단계, 이미지 1개 중 1개
    • Lift the silver metal hard drive bracket off of the hard drive.
    • You'll need to transfer this metal bracket to your new hard drive.
    • If you are installing a new hard drive, we have an OS X install guide to get you up and running.
결론
다른 614명이 해당 안내서를 완성하였습니다.
작성자
13다른 기여자 명과 함께
iRobot
회원 가입일: 09/24/09
1 평판
안내서 635개를 작성함
20가이드 댓글
Thanks iFixit for this great walkthrough. Yes, it worked find. Have a look: http://www.vimeo.com/17134347 ;) Keep on rockin' /Sebastian
Sebastian Perschke - 답글
Any suggestions for when the rubber track comes out with the hard disk? Short of dismantling the whole thing?
billkline - 답글
I saw no replies to the "black rubber lip in the slot" comment. What is the fix for that rubber liner track strip coming loose from the inside of the HD enclosure, please?
Mike -
Thanks for the guide, iFixit! It worked like a cham.
scheppdogg532 - 답글
I was wondering if there are any harddrives that are known to be incompatible with this MacBook (aside from dimensions of course)?
Jeannine Guenette - 답글
댓글 쓰기
조회 통계:
지난 24시간: 14
지난 7일: 85
지난 30일: 510
전체 시간: 435,045
