소개
Follow this guide to replace the wireless antenna assembly in your MacBook Pro, or to get it out of the way for other repairs.
For your safety, drain your MacBook Pro’s battery to 25% charge or less before you begin.
Some photos in this guide are from a different model and may contain slight visual discrepancies, but they won't affect the guide procedure.
필요한 것
If your MacBook is running Big Sur v11.1 or later, disabling Auto Boot may not work. You can proceed normally, but make sure to disconnect the battery as soon as you're inside.
Use a P5 Pentalobe driver to remove the six screws securing the lower case:
Two 6.7 mm screws
Four 3.4 mm screws
Apply a suction handle to the lower case near the front-center area of the MacBook Pro.
Lift the suction handle to create a slight gap between the lower case and the chassis.
Insert one corner of an opening pick into the space between the lower case and the chassis.
Slide the opening pick around the nearest corner and halfway up the side of the case.
Insert your opening pick once again under the front edge of the lower case, near one of the two centermost screw holes.
Give the pick a firm twist to pop free the third clip securing the lower case to the chassis.
Repeat this procedure near the other of the two centermost screw holes, popping the fourth clip free.
Remove the lower case.
Set it in place and align the sliding clips near the display hinge. Press down and slide the cover toward the hinge. It should stop sliding as the clips engage.
When the sliding clips are fully engaged and the lower case looks correctly aligned, press down firmly on the lower case to engage the four hidden clips underneath. You should feel and hear them snap into place.
Carefully peel up the large piece of tape covering the battery connector, on the edge of the logic board nearest the battery.
Remove the tape.
Use a spudger to gently lift the battery power connector, disconnecting the battery.
Lift the connector high enough so that it stays separated from its socket. If it accidentally makes contact during the course of your repair, it could damage your MacBook Pro.
Use a T3 Torx driver to remove the four 1.9 mm screws securing the plastic covers on top of the display hinges.
Remove both plastic hinge covers.
Remove the two 2.9 mm T3 Torx screws securing the aluminum cover on top of the main display cable.
Remove the cover.
Remove the four 1.5 mm T3 Torx screws securing the two aluminum covers on top of the two display board cables.
Use a pair of tweezers to remove the two aluminium covers.
Carefully disconnect the three antenna coax cables by prying them straight up from the logic board.
Use an opening pick to lever out the antenna cable assembly in the areas shown.
Carefully remove the antenna assembly, while simultaneously feeding the antenna cable bundle out from underneath the heat pipe.
Repair didn’t go as planned? Try some basic troubleshooting or search our Answers community for help.
다른 한 분이 해당 안내서를 완성하였습니다.
