주요 콘텐츠로 건너뛰기
MacBook Pro 13" Retina Display Early 2013 Logic Board Replacement
필요한 것
  1. MacBook Pro 13" Retina Display Early 2013 Logic Board Replacement, Lower Case: 1 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    Magnetic Project Mat
    $16.96
    • Two 2.3 mm P5 Pentalobe screws
    • Eight 3.0 mm P5 Pentalobe screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
  2. MacBook Pro 13" Retina Display Early 2013 Logic Board Replacement: 2 단계, 이미지 1개 중 1개
    • Wedge your fingers between the upper case and the lower case.
    • Gently pull the lower case away from the upper case.
  3. MacBook Pro 13" Retina Display Early 2013 Logic Board Replacement: 3 단계, 이미지 3개 중 1개 MacBook Pro 13" Retina Display Early 2013 Logic Board Replacement: 3 단계, 이미지 3개 중 2개 MacBook Pro 13" Retina Display Early 2013 Logic Board Replacement: 3 단계, 이미지 3개 중 3개
    • During reassembly, gently push down the center of the lower case to reattach the two plastic clips.
    • The lower case is connected to the upper case at the center, with two plastic clips.
  4. MacBook Pro 13" Retina Display Early 2013 Logic Board Replacement, Battery Connector: 4 단계, 이미지 1개 중 1개
    • Remove the plastic cover adhered to the battery contact board.
  5. MacBook Pro 13" Retina Display Early 2013 Logic Board Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the following screws securing the battery connector board to the logic board:
    • Two 2.8 mm T6 Torx screws
    • One 7.0 mm T6 Torx shouldered screw
  6. MacBook Pro 13" Retina Display Early 2013 Logic Board Replacement: 6 단계, 이미지 2개 중 1개 MacBook Pro 13" Retina Display Early 2013 Logic Board Replacement: 6 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use tweezers to remove the small plastic cover located near the bottom right of the battery connector board.
  7. MacBook Pro 13" Retina Display Early 2013 Logic Board Replacement: 7 단계, 이미지 1개 중 1개
    • Remove the wide head 6.4 mm T6 Torx screw securing the battery connector to the logic board assembly.
  8. MacBook Pro 13" Retina Display Early 2013 Logic Board Replacement: 8 단계, 이미지 2개 중 1개 MacBook Pro 13" Retina Display Early 2013 Logic Board Replacement: 8 단계, 이미지 2개 중 2개
    • Carefully lift the battery connector board up off the logic board.
    • It is recommended to bend the battery cables just slightly, to keep the board suspended up above the logic board and out of the way.
    • Do not fold the board completely over, or crease the cables, as this may damage the battery.
  9. MacBook Pro 13" Retina Display Early 2013 Logic Board Replacement, Battery Contact Board: 9 단계, 이미지 2개 중 1개 MacBook Pro 13" Retina Display Early 2013 Logic Board Replacement, Battery Contact Board: 9 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Grasp the Interposer with tweezers.
    • An interposer is the name for an interface that links one electrical connection to another. In this repair, it is the board connecting the battery to logic board.
    • Lift the Interposer off the logic board and remove it.
    • Removing this board will ensure that the battery remains disconnected throughout your repair, preventing your computer from accidentally powering on. It's also a good idea to take it out so it doesn't fall out unexpectedly.
  10. MacBook Pro 13" Retina Display Early 2013 Logic Board Replacement, Heat Sink Assembly: 10 단계, 이미지 1개 중 1개
    • Remove the following screws securing the heat sink to the logic board assembly:
    • One 2.4 mm Phillips #00 screw
    • One 3.4 mm T5 Torx screw
    • Four 2.7 mm T5 Torx screws
  11. MacBook Pro 13" Retina Display Early 2013 Logic Board Replacement: 11 단계, 이미지 2개 중 1개 MacBook Pro 13" Retina Display Early 2013 Logic Board Replacement: 11 단계, 이미지 2개 중 2개
    • Lift and remove the heat sink up off the logic board assembly.
    • When reinstalling the heat sink, be sure to apply a new layer of thermal paste. If you have never applied thermal paste before, we have a guide that makes it easy.
  12. MacBook Pro 13" Retina Display Early 2013 Logic Board Replacement, I/O Board Data Cable: 12 단계, 이미지 2개 중 1개 MacBook Pro 13" Retina Display Early 2013 Logic Board Replacement, I/O Board Data Cable: 12 단계, 이미지 2개 중 2개
    • Use the flat end of a spudger to pry the right side of the I/O board data cable connector up off its socket on the I/O board.
    • When prying the I/O board data cable connector from its socket, make sure to pry the connector itself and not the socket. Prying the socket may cause irreversible damage to the I/O board.
  13. MacBook Pro 13" Retina Display Early 2013 Logic Board Replacement: 13 단계, 이미지 2개 중 1개 MacBook Pro 13" Retina Display Early 2013 Logic Board Replacement: 13 단계, 이미지 2개 중 2개
    • Wedge the flat end of a spudger beneath the left side of the I/O board data cable connector.
    • Gently twist the spudger to disconnect the I/O board data cable connector from its socket on the logic board.
  14. MacBook Pro 13" Retina Display Early 2013 Logic Board Replacement: 14 단계, 이미지 1개 중 1개
    • Lift and remove the I/O board data cable from the MacBook Pro.
  15. MacBook Pro 13" Retina Display Early 2013 Logic Board Replacement, iSight Camera Cable: 15 단계, 이미지 2개 중 1개 MacBook Pro 13" Retina Display Early 2013 Logic Board Replacement, iSight Camera Cable: 15 단계, 이미지 2개 중 2개
    • Use the tip of a spudger to push the iSight camera cable connector straight away from its socket on the logic board.
    • It is recommended to carefully push on both sides of the connector to "walk" it out of its socket.
  16. MacBook Pro 13" Retina Display Early 2013 Logic Board Replacement: 16 단계, 이미지 2개 중 1개 MacBook Pro 13" Retina Display Early 2013 Logic Board Replacement: 16 단계, 이미지 2개 중 2개
    • Move the iSight camera cable aside.
  17. MacBook Pro 13" Retina Display Early 2013 Logic Board Replacement, Right Fan: 17 단계, 이미지 3개 중 1개 MacBook Pro 13" Retina Display Early 2013 Logic Board Replacement, Right Fan: 17 단계, 이미지 3개 중 2개 MacBook Pro 13" Retina Display Early 2013 Logic Board Replacement, Right Fan: 17 단계, 이미지 3개 중 3개
    • Use the tip of a spudger to flip up the retaining flap on the right fan ribbon cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap, not the socket itself.
    • Pull the right fan ribbon cable straight out of its socket on the logic board.
  18. MacBook Pro 13" Retina Display Early 2013 Logic Board Replacement: 18 단계, 이미지 1개 중 1개
    • Remove the three 3.1 mm T5 Torx screws securing the right fan to the logic board assembly.
  19. MacBook Pro 13" Retina Display Early 2013 Logic Board Replacement: 19 단계, 이미지 1개 중 1개
    • Lift and remove the right fan out of the upper case.
  20. MacBook Pro 13" Retina Display Early 2013 Logic Board Replacement, Left Fan: 20 단계, 이미지 2개 중 1개 MacBook Pro 13" Retina Display Early 2013 Logic Board Replacement, Left Fan: 20 단계, 이미지 2개 중 2개
    • Use the tip of a spudger to flip up the retaining flap on the left fan ribbon cable ZIF socket.
  21. MacBook Pro 13" Retina Display Early 2013 Logic Board Replacement: 21 단계, 이미지 1개 중 1개
    • Remove the three 3.1 mm T5 Torx screws securing the left fan to the logic board assembly.
  22. MacBook Pro 13" Retina Display Early 2013 Logic Board Replacement: 22 단계, 이미지 2개 중 1개 MacBook Pro 13" Retina Display Early 2013 Logic Board Replacement: 22 단계, 이미지 2개 중 2개
    • Lift and remove the left fan out of the upper case.
    • Make sure to pull the left fan straight away to simultaneously pull the left fan ribbon cable out of its socket on the logic board.
  23. MacBook Pro 13" Retina Display Early 2013 Logic Board Replacement, Logic Board Assembly: 23 단계, 이미지 3개 중 1개 MacBook Pro 13" Retina Display Early 2013 Logic Board Replacement, Logic Board Assembly: 23 단계, 이미지 3개 중 2개 MacBook Pro 13" Retina Display Early 2013 Logic Board Replacement, Logic Board Assembly: 23 단계, 이미지 3개 중 3개
    • Use the tip of a spudger to push the edges of the I/O board connector straight out of its socket on the logic board.
  24. MacBook Pro 13" Retina Display Early 2013 Logic Board Replacement: 24 단계, 이미지 2개 중 1개 MacBook Pro 13" Retina Display Early 2013 Logic Board Replacement: 24 단계, 이미지 2개 중 2개
    • Wedge the flat end of a spudger underneath the keyboard backlight connector and the logic board.
    • Gently twist the flat end of a spudger upwards to pry the keyboard backlight connector up off its socket on the logic board.
  25. MacBook Pro 13" Retina Display Early 2013 Logic Board Replacement: 25 단계, 이미지 3개 중 1개 MacBook Pro 13" Retina Display Early 2013 Logic Board Replacement: 25 단계, 이미지 3개 중 2개 MacBook Pro 13" Retina Display Early 2013 Logic Board Replacement: 25 단계, 이미지 3개 중 3개
    • Grab the black pull tab secured to the display data cable lock and rotate it toward the DC-In side of the computer.
    • Pull the display data cable straight out of its socket on the logic board.
    • Do not lift up on the display data cable, as its socket is very fragile. Pull the cable parallel to the face of the logic board.
  26. MacBook Pro 13" Retina Display Early 2013 Logic Board Replacement: 26 단계, 이미지 1개 중 1개
    • Pry the headphone jack cable connector up off its socket on the logic board.
  27. MacBook Pro 13" Retina Display Early 2013 Logic Board Replacement: 27 단계, 이미지 3개 중 1개 MacBook Pro 13" Retina Display Early 2013 Logic Board Replacement: 27 단계, 이미지 3개 중 2개 MacBook Pro 13" Retina Display Early 2013 Logic Board Replacement: 27 단계, 이미지 3개 중 3개
    • Use the tip of a spudger to flip up the retaining flap on the microphone ribbon cable ZIF socket.
    • Grasp the plastic pull tab and pull the microphone ribbon cable out of its socket.
  28. MacBook Pro 13" Retina Display Early 2013 Logic Board Replacement: 28 단계, 이미지 3개 중 1개 MacBook Pro 13" Retina Display Early 2013 Logic Board Replacement: 28 단계, 이미지 3개 중 2개 MacBook Pro 13" Retina Display Early 2013 Logic Board Replacement: 28 단계, 이미지 3개 중 3개
    • Use the flat edge of a spudger to flip up the retaining flap on the keyboard ribbon cable ZIF socket.
    • Grasp the plastic pull tab and pull the keyboard ribbon cable out of its socket.
  29. MacBook Pro 13" Retina Display Early 2013 Logic Board Replacement: 29 단계, 이미지 3개 중 1개 MacBook Pro 13" Retina Display Early 2013 Logic Board Replacement: 29 단계, 이미지 3개 중 2개 MacBook Pro 13" Retina Display Early 2013 Logic Board Replacement: 29 단계, 이미지 3개 중 3개
    • Repeat the previous procedure to disconnect the Trackpad ribbon cable from its socket on the logic board.
  30. MacBook Pro 13" Retina Display Early 2013 Logic Board Replacement: 30 단계, 이미지 2개 중 1개 MacBook Pro 13" Retina Display Early 2013 Logic Board Replacement: 30 단계, 이미지 2개 중 2개
    • Wedge the flat end of a spudger beneath the right speaker cable connector.
    • Gently pry the right speaker cable connector up off from its socket on the logic board.
    • Be sure you are prying up on the connector, not the socket itself.
  31. MacBook Pro 13" Retina Display Early 2013 Logic Board Replacement: 31 단계, 이미지 1개 중 1개
    • Use the flat end of a spudger to pry the SSD cable connector up off its socket on the logic board.
  32. MacBook Pro 13" Retina Display Early 2013 Logic Board Replacement: 32 단계, 이미지 2개 중 1개 MacBook Pro 13" Retina Display Early 2013 Logic Board Replacement: 32 단계, 이미지 2개 중 2개
    • Wedge the tip of a spudger beneath the left speaker cable connector.
    • Gently pry the left speaker cable connector up off from its socket on the logic board.
  33. MacBook Pro 13" Retina Display Early 2013 Logic Board Replacement: 33 단계, 이미지 1개 중 1개
    • Remove the nine 3.3 mm T5 Torx screws securing the logic board and MagSafe DC-in board to the upper case.
  34. MacBook Pro 13" Retina Display Early 2013 Logic Board Replacement: 34 단계, 이미지 2개 중 1개 MacBook Pro 13" Retina Display Early 2013 Logic Board Replacement: 34 단계, 이미지 2개 중 2개
    • Carefully grasp the corner of the logic board (opposite of the I/O ports) and lift the logic board out of the upper case.
  35. MacBook Pro 13" Retina Display Early 2013 Logic Board Replacement, MagSafe DC-In Board: 35 단계, 이미지 2개 중 1개 MacBook Pro 13" Retina Display Early 2013 Logic Board Replacement, MagSafe DC-In Board: 35 단계, 이미지 2개 중 2개
    • Gently push the edges of the MagSafe cable connector away from its socket on the logic board.
    • It is recommended "walk" the connector out of its socket. Simply push the top and bottom corners of the connector and carefully "walk it out" of its socket.
  36. MacBook Pro 13" Retina Display Early 2013 Logic Board Replacement: 36 단계, 이미지 1개 중 1개
    • Pull the MagSafe cable connector straight out of its socket on the logic board.
  37. MacBook Pro 13" Retina Display Early 2013 Logic Board Replacement, Logic Board: 37 단계, 이미지 1개 중 1개
    • Logic board remains.
결론
다른 14명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Sam Goldheart
회원 가입일: 10/18/12
474,950 평판
안내서 538개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,623개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 18
지난 30일: 54
전체 시간: 28,872
