주요 콘텐츠로 건너뛰기
MacBook Pro 13" Retina Display Early 2015 Heat Sink Replacement
필요한 것
  1. MacBook Pro 13" Retina Display Early 2015 Heat Sink Replacement, Lower Case: 1 단계, 이미지 1/1
    이 단계에 사용된 도구:
    Magnetic Project Mat
    $19.95
    구매
    • Two 2.3 mm P5 Pentalobe screws
    • Eight 3.0 mm P5 Pentalobe screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
  2. MacBook Pro 13" Retina Display Early 2015 Heat Sink Replacement: 2 단계, 이미지 1/1
    • Wedge your fingers between the upper case and the lower case.
    • Gently pull the lower case away from the upper case to remove it.
  3. MacBook Pro 13" Retina Display Early 2015 Heat Sink Replacement: 3 단계, 이미지 1/2 MacBook Pro 13" Retina Display Early 2015 Heat Sink Replacement: 3 단계, 이미지 2/2
    • The lower case is connected to the upper case with two plastic clips near its center.
    • During reassembly, gently push down the center of the lower case to reattach the two plastic clips.
  4. MacBook Pro 13" Retina Display Early 2015 Heat Sink Replacement, Battery Connector: 4 단계, 이미지 1/1
    • If necessary, remove the plastic cover adhered to the battery contact board.
  5. MacBook Pro 13" Retina Display Early 2015 Heat Sink Replacement: 5 단계, 이미지 1/2 MacBook Pro 13" Retina Display Early 2015 Heat Sink Replacement: 5 단계, 이미지 2/2
    • Use the flat end of a spudger to lift the battery connector straight up out of its socket on the logic board.
    • Be sure you lift up only on the connector itself, not the socket, or you risk permanent damage to the logic board.
  6. MacBook Pro 13" Retina Display Early 2015 Heat Sink Replacement: 6 단계, 이미지 1/1
    • Bend the battery connector up out of the way to prevent accidental contact with its socket during your repair.
  7. MacBook Pro 13" Retina Display Early 2015 Heat Sink Replacement, Heat Sink: 7 단계, 이미지 1/3 MacBook Pro 13" Retina Display Early 2015 Heat Sink Replacement, Heat Sink: 7 단계, 이미지 2/3 MacBook Pro 13" Retina Display Early 2015 Heat Sink Replacement, Heat Sink: 7 단계, 이미지 3/3
    • Carefully remove the rubber fan bumper from the edge of the heat sink.
    • The fan bumper wraps around the heat sink and fits into slots in the fan duct. During reassembly, be sure to fit the tabs into the notches in the fan duct.
  8. MacBook Pro 13" Retina Display Early 2015 Heat Sink Replacement: 8 단계, 이미지 1/2 MacBook Pro 13" Retina Display Early 2015 Heat Sink Replacement: 8 단계, 이미지 2/2
    • Use the flat end of a spudger to peel the four foam stickers off of the heat sink screws.
  9. MacBook Pro 13" Retina Display Early 2015 Heat Sink Replacement: 9 단계, 이미지 1/1
    • Remove the following screws securing the heat sink to the logic board:
    • One 2.7 mm T5 screw (silver)
    • Four T5 screws (black)
  10. MacBook Pro 13" Retina Display Early 2015 Heat Sink Replacement: 10 단계, 이미지 1/2 MacBook Pro 13" Retina Display Early 2015 Heat Sink Replacement: 10 단계, 이미지 2/2
결론
다른 56명이 해당 안내서를 완성하였습니다.
Andrew Optimus Goldheart
회원 가입일: 10/17/09
504,097 평판
안내서 407개 작성하였습니다
iFixit iFixit 회원
Staff
141 회원들
안내서 17,893개 작성하였습니다
댓글 6개
what part should i purchae to get the rubber fan bumper?
Walid Shraim - 답글
Bonjour !
Merci pour ce tutoriel de qualité ! Pour la pâte thermique, j’ai opté pour la Grizzly Kryonaut… Un peu overkill pour un MBP 13” de 2015, mais cela devrait contribuer à sa longévité !
Une remarque cependant : sur mon modèle, la vis en ROUGE de l’ETAPE 9 n’était pas une Torx T5, mais une Y00 ! Cela ne m’a pas posé de problème car j’avais le kit complet de tournevis, mais cela l’aurait été si je n’avais acheté qu’un P5 et un T5 ! Faites attention !
Bonne continuation !
PS: si certains doutent de leurs capacités à réaliser cette opération, sachez que je suis grand débutant en informatique et que je n’ai eu AUCUN problème. La partie la plus ardue étant le retrait du connecteur de la batterie !
Merlin Calvez-Martinez - 답글
Used this guide to pop the heat sink and scrape off the old thermal paste. Cleaned and re-applied with new paste, hopefully leading to better thermal performance. One thing I noticed is that the heatsink doesn’t cover the second module (presumed to be the integrated GPU) next to the CPU? Perhaps this is why thermal performance is so abysmal on these little guys.
Ming Lee - 답글
In my MacBook Pro, the screw in step 9 that is farthest away from the CPU is a Philips screw, rather than T5 Torx.
I bought my MacBook Pro in 2016, over a year after it came out, so this might be different depending on when yours was manufactured.
Daniel Korzhenevich - 답글
What is the 4 screw size of heatsink? mine are stripped, need to buy new 4
rick - 답글
댓글 쓰기
조회 통계:
24 시간 전: 16
7일 전: 77
30일 전: 385
전체 시간: 44,032
