주요 콘텐츠로 건너뛰기
MacBook Pro 13" Retina Display Late 2012 AirPort Board Assembly Replacement
단지 전제 조건
이 안내서는 다른 가이드의 선행 작업으로 사용하기 위한 것입니다. 그 자체로는 불완전합니다.
필요한 것
  1. MacBook Pro 13" Retina Display Late 2012 AirPort Board Assembly Replacement, AirPort Board Assembly: 1 단계, 이미지 1/1
    • Remove the single 2.7 mm T5 Torx screw securing the AirPort board to the I/O board.
  2. MacBook Pro 13" Retina Display Late 2012 AirPort Board Assembly Replacement: 2 단계, 이미지 1/3 MacBook Pro 13" Retina Display Late 2012 AirPort Board Assembly Replacement: 2 단계, 이미지 2/3 MacBook Pro 13" Retina Display Late 2012 AirPort Board Assembly Replacement: 2 단계, 이미지 3/3
    • Use the flat end of a spudger to pry and disconnect the three antenna cable connectors from the AirPort board.
    • The three cables are coded with black sleeves of different lengths. During reassembly:
    • Connect the long-sleeved cable to the center socket.
    • The short-sleeved cable connects next to the screw.
    • The remaining cable has no sleeve, and connects in the last empty socket, next to the fan.
  3. MacBook Pro 13" Retina Display Late 2012 AirPort Board Assembly Replacement: 3 단계, 이미지 1/2 MacBook Pro 13" Retina Display Late 2012 AirPort Board Assembly Replacement: 3 단계, 이미지 2/2
    • Move the antenna cables aside, clear of the AirPort board.
  4. MacBook Pro 13" Retina Display Late 2012 AirPort Board Assembly Replacement: 4 단계, 이미지 1/2 MacBook Pro 13" Retina Display Late 2012 AirPort Board Assembly Replacement: 4 단계, 이미지 2/2
    • Wedge a plastic opening tool between the AirPort board (side nearest the I/O ports) and the I/O board.
    • Gently pry the AirPort board upwards, but do not remove it.
    • Only lift the AirPort board as much as is necessary to get a grip on it. Lifting it too high above the I/O board may damage the board or the socket.
  5. MacBook Pro 13" Retina Display Late 2012 AirPort Board Assembly Replacement: 5 단계, 이미지 1/2 MacBook Pro 13" Retina Display Late 2012 AirPort Board Assembly Replacement: 5 단계, 이미지 2/2
    • Pull the AirPort board straight out of its socket on the I/O board.
결론
Walter Galan
694,877 평판
안내서 1,203개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 13
전체 시간: 85
