주요 콘텐츠로 건너뛰기
MacBook Pro 13" Retina Display Late 2012 Battery Connector Replacement
단지 전제 조건
이 안내서는 다른 가이드의 선행 작업으로 사용하기 위한 것입니다. 그 자체로는 불완전합니다.
필요한 것
  1. MacBook Pro 13" Retina Display Late 2012 Battery Connector Replacement, Battery Connector: 1 단계, 이미지 1/1
    • Remove the plastic cover adhered to the battery contact board.
  2. MacBook Pro 13" Retina Display Late 2012 Battery Connector Replacement: 2 단계, 이미지 1/1
    • Remove the following screws securing the battery connector board to the logic board:
    • Two 2.8 mm T6 Torx screws
    • One 7.0 mm T6 Torx shouldered screw
  3. MacBook Pro 13" Retina Display Late 2012 Battery Connector Replacement: 3 단계, 이미지 1/2 MacBook Pro 13" Retina Display Late 2012 Battery Connector Replacement: 3 단계, 이미지 2/2
    • Use tweezers to remove the small plastic cover located near the bottom right of the battery connector board.
  4. MacBook Pro 13" Retina Display Late 2012 Battery Connector Replacement: 4 단계, 이미지 1/1
    • Remove the wide head 6.4 mm T6 Torx screw securing the battery connector to the logic board assembly.
  5. MacBook Pro 13" Retina Display Late 2012 Battery Connector Replacement: 5 단계, 이미지 1/2 MacBook Pro 13" Retina Display Late 2012 Battery Connector Replacement: 5 단계, 이미지 2/2
    • Carefully lift the battery connector board up off the logic board.
    • It is recommended to bend the battery cables just slightly, to keep the board suspended up above the logic board and out of the way.
    • Do not fold the board completely over, or crease the cables, as this may damage the battery.
결론
Walter Galan
694,692 평판
안내서 1,203개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 251
