이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계에 사용된 도구:Magnetic Project Mat$19.95
하단 케이스를 상단 케이스에 고정하는 다음 나사 열 개를 풀어주세요:
2.3mm P5 Pentalobe/펜타로브/별나사 두 개
3.0mm P5 Pentalobe/펜타로브/별나사 여덟 개
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Use the flat end of a spudger to peel the four foam stickers off of the heat sink screws.
Remove the following screws securing the heat sink to the logic board:
Four 2.6 mm T5 screws
One 2.4 mm Phillips #000 screw
Use the tip of a spudger to push on either side of the the iSight camera cable connector to walk it out of its socket on the logic board.
Peel the iSight camera cable off the fan housing to fold it out of the way.
Use the tip of a spudger to flip the tab on the fan's ZIF connector.
Carefully pull the fan cable straight out of its socket.
Remove the following screws securing the fan to the upper case:
One 5.0 mm T5 Torx screw
Two 3.6 mm T5 Torx screws
Lift the end of the fan closest to the display hinge and remove the fan from the upper case.
Remove the two 2.1 mm T5 Torx screws securing the I/O board cable bracket to the logic board.
Remove the I/O board cable bracket.
Use the flat end of a spudger to pop the I/O board connector straight up off its socket on the logic board.
Lift the logic board end of the I/O board cable straight up to bend it out of the way.
Use the tip of a spudger to lift the right speaker connector straight up out of its socket on the logic board.
With the tip of a spudger, push on either side of the I/O board connector to walk it out of its socket on the logic board.
Use the flat end of a spudger to disconnect the keyboard backlight cable and bend it up out of the way of the logic board.
Grab the black plastic tab to flip the display cable connector open and pull it straight out of its socket on the logic board.
Carefully pull the DC-In board connector straight out of its socket on the logic board.
Wedge the flat end of a spudger under the left speaker cable near the connector and lift it straight up out of its socket and fold it out of the way.
Use the tip of a spudger to flip the retaining tab on the microphone cable ZIF connector.
Pull the microphone cable out of its socket on the logic board.
Use the tip of a spudger to flip the retaining tab on the ZIF connector.
Pull the keyboard cable straight out of its ZIF socket on the logic board.
Pull the trackpad ribbon cable straight out of its socket on the logic board.
Remove the five 3.5 mm T5 Torx screws securing the logic board to the upper case.
Lift the processor end of the logic board up slightly and pull it toward the fan recess to free the ports from the edge of the upper case.
Remove the logic board.
Remove the following screws securing the left speaker to the upper case:
One 5.7 mm T5 Torx screw
One 6.5 mm T5 Torx screw
One 3.8 mm T5 Torx screw
Lift the corner of the left speaker up and slide it toward the battery to remove it from the upper case.
Remove the single 3.7 mm T5 Torx screw securing the case-edge of the battery contact board.
Insert the tip of a spudger under the battery-side portion of the rubber microphone cable cover to detach the adhesive there.
Use the flat end of a spudger to wedge the battery contact board up slightly to allow room to extract the dual microphone assembly.
Insert the tip of a spudger underneath the connector end of the microphone ribbon cable and slide it toward the screw post to free that half from the upper case.
Insert the tip of a spudger under the battery-side portion of the microphone ribbon cable and slide it toward the screw post to free it from the upper case.
Pull the dual microphone cable assembly up and toward the logic board recess to remove it from the upper case.
다른 2명이 해당 안내서를 완성하였습니다.
