주요 콘텐츠로 건너뛰기
MacBook Pro 13" Retina Display Late 2013 Heat Sink Replacement
필요한 것
  1. MacBook Pro 13" Retina Display Late 2013 Heat Sink Replacement, Lower Case: 1 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    Magnetic Project Mat
    $19.95
    • Two 2.3 mm P5 Pentalobe screws
    • Eight 3.0 mm P5 Pentalobe screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
  2. MacBook Pro 13" Retina Display Late 2013 Heat Sink Replacement: 2 단계, 이미지 1개 중 1개
    • Wedge your fingers between the upper case and the lower case.
    • Gently pull the lower case away from the upper case to remove it.
  3. MacBook Pro 13" Retina Display Late 2013 Heat Sink Replacement: 3 단계, 이미지 2개 중 1개 MacBook Pro 13" Retina Display Late 2013 Heat Sink Replacement: 3 단계, 이미지 2개 중 2개
    • The lower case is connected to the upper case with two plastic clips near its center.
    • During reassembly, gently push down the center of the lower case to reattach the two plastic clips.
  4. MacBook Pro 13" Retina Display Late 2013 Heat Sink Replacement, Battery Connector: 4 단계, 이미지 1개 중 1개
    • If necessary, remove the plastic cover adhered to the battery contact board.
  5. MacBook Pro 13" Retina Display Late 2013 Heat Sink Replacement: 5 단계, 이미지 2개 중 1개 MacBook Pro 13" Retina Display Late 2013 Heat Sink Replacement: 5 단계, 이미지 2개 중 2개
    • Use the flat end of a spudger to lift the battery connector straight up out of its socket on the logic board.
    • Be sure you lift up only on the connector itself, not the socket, or you risk permanent damage to the logic board.
  6. MacBook Pro 13" Retina Display Late 2013 Heat Sink Replacement: 6 단계, 이미지 1개 중 1개
    • Bend the battery connector up out of the way to prevent accidental contact with its socket during your repair.
  7. MacBook Pro 13" Retina Display Late 2013 Heat Sink Replacement, Heat Sink: 7 단계, 이미지 3개 중 1개 MacBook Pro 13" Retina Display Late 2013 Heat Sink Replacement, Heat Sink: 7 단계, 이미지 3개 중 2개 MacBook Pro 13" Retina Display Late 2013 Heat Sink Replacement, Heat Sink: 7 단계, 이미지 3개 중 3개
    • Carefully remove the rubber fan bumper from the edge of the heat sink.
    • The fan bumper wraps around the heat sink and fits into slots in the fan duct. During reassembly, be sure to fit the tabs into the notches in the fan duct.
  8. MacBook Pro 13" Retina Display Late 2013 Heat Sink Replacement: 8 단계, 이미지 2개 중 1개 MacBook Pro 13" Retina Display Late 2013 Heat Sink Replacement: 8 단계, 이미지 2개 중 2개
    • Use the flat end of a spudger to peel the four foam stickers off of the heat sink screws.
  9. MacBook Pro 13" Retina Display Late 2013 Heat Sink Replacement: 9 단계, 이미지 1개 중 1개
    • Remove the following screws securing the heat sink to the logic board:
    • Four 2.6 mm T5 screws
    • One 2.4 mm Phillips #000 screw
  10. MacBook Pro 13" Retina Display Late 2013 Heat Sink Replacement: 10 단계, 이미지 2개 중 1개 MacBook Pro 13" Retina Display Late 2013 Heat Sink Replacement: 10 단계, 이미지 2개 중 2개
결론
다른 25명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Sam Goldheart
회원 가입일: 10/18/12
475,086 평판
안내서 538개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,788개를 작성함
2가이드 댓글
If you are following this guide to replace the thermal paste on the CPU i think you should know that - if you, like i, have decided to remove the black electrical tape that is on the CPU, make sure you are super careful when using Thermal Paste Remover Liquid. Any liquid can easily get under the CPU because there is enough gap from every side.
My Mac lives but now i live with the memory of worryingly wondering whether i killed it while cleaning out the liquid from underneath the CPU without lifting it.
Alexander - 답글
Thanks a lot, used this guide to change thermal paste on my oldie 🙏
in_sympathy - 답글
댓글 쓰기
조회 통계:
지난 24시간: 8
지난 7일: 80
지난 30일: 344
전체 시간: 26,559
