주요 콘텐츠로 건너뛰기
MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement
필요한 것
    • Two 2.3 mm P5 Pentalobe screws
    • Eight 3.0 mm P5 Pentalobe screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
  1. MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: 2 단계, 이미지 1/1
    • Wedge your fingers between the upper case and the lower case.
    • Gently pull the lower case away from the upper case to remove it.
  2. MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: 3 단계, 이미지 1/2 MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: 3 단계, 이미지 2/2
    • The lower case is connected to the upper case with two plastic clips near its center.
    • During reassembly, gently push down the center of the lower case to reattach the two plastic clips.
  3. MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement, Battery Connector: 4 단계, 이미지 1/1
    • If necessary, remove the plastic cover adhered to the battery contact board.
  4. MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: 5 단계, 이미지 1/2 MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: 5 단계, 이미지 2/2
    • Use the flat end of a spudger to lift the battery connector straight up out of its socket on the logic board.
    • Be sure you lift up only on the connector itself, not the socket, or you risk permanent damage to the logic board.
  5. MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: 6 단계, 이미지 1/1
    • Bend the battery connector up out of the way to prevent accidental contact with its socket during your repair.
  6. MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement, Heat Sink: 7 단계, 이미지 1/3 MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement, Heat Sink: 7 단계, 이미지 2/3 MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement, Heat Sink: 7 단계, 이미지 3/3
    • Carefully remove the rubber fan bumper from the edge of the heat sink.
    • The fan bumper wraps around the heat sink and fits into slots in the fan duct. During reassembly, be sure to fit the tabs into the notches in the fan duct.
  7. MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: 8 단계, 이미지 1/2 MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: 8 단계, 이미지 2/2
    • Use the flat end of a spudger to peel the four foam stickers off of the heat sink screws.
  8. MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: 9 단계, 이미지 1/1
    • Remove the following screws securing the heat sink to the logic board:
    • Four 2.6 mm T5 screws
    • One 2.4 mm Phillips #000 screw
  9. MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: 10 단계, 이미지 1/2 MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: 10 단계, 이미지 2/2
  10. MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement, Fan: 11 단계, 이미지 1/2 MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement, Fan: 11 단계, 이미지 2/2
    • Use the tip of a spudger to push on either side of the the iSight camera cable connector to walk it out of its socket on the logic board.
  11. MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: 12 단계, 이미지 1/2 MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: 12 단계, 이미지 2/2
    • Peel the iSight camera cable off the fan housing to fold it out of the way.
  12. MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: 13 단계, 이미지 1/3 MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: 13 단계, 이미지 2/3 MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: 13 단계, 이미지 3/3
    • Use the tip of a spudger to flip the tab on the fan's ZIF connector.
    • Carefully pull the fan cable straight out of its socket.
  13. MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: 14 단계, 이미지 1/1
    • Remove the following screws securing the fan to the upper case:
    • One 5.0 mm T5 Torx screw
    • Two 3.6 mm T5 Torx screws
  14. MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: 15 단계, 이미지 1/3 MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: 15 단계, 이미지 2/3 MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: 15 단계, 이미지 3/3
    • Lift the end of the fan closest to the display hinge and remove the fan from the upper case.
  15. MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement, Logic Board Assembly: 16 단계, 이미지 1/2 MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement, Logic Board Assembly: 16 단계, 이미지 2/2
    • Remove the two 2.1 mm T5 Torx screws securing the I/O board cable bracket to the logic board.
    • Remove the I/O board cable bracket.
  16. MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: 17 단계, 이미지 1/2 MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: 17 단계, 이미지 2/2
    • Use the flat end of a spudger to pop the I/O board connector straight up off its socket on the logic board.
    • Be careful to only pry up on the I/O board cable, not on the socket itself or you risk damaging your logic board.
  17. MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: 18 단계, 이미지 1/2 MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: 18 단계, 이미지 2/2
    • Lift the logic board end of the I/O board cable straight up to bend it out of the way.
    • To avoid damage to the cable, fold only at the bend in the I/O board end of the cable.
  18. MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: 19 단계, 이미지 1/2 MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: 19 단계, 이미지 2/2
    • Use the tip of a spudger to lift the right speaker connector straight up out of its socket on the logic board.
  19. MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: 20 단계, 이미지 1/2 MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: 20 단계, 이미지 2/2
    • With the tip of a spudger, push on either side of the I/O board connector to walk it out of its socket on the logic board.
  20. MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: 21 단계, 이미지 1/3 MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: 21 단계, 이미지 2/3 MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: 21 단계, 이미지 3/3
    • Use the flat end of a spudger to disconnect the keyboard backlight cable and bend it up out of the way of the logic board.
  21. MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: 22 단계, 이미지 1/3 MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: 22 단계, 이미지 2/3 MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: 22 단계, 이미지 3/3
    • Grab the black plastic tab to flip the display cable connector open and pull it straight out of its socket on the logic board.
  22. MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: 23 단계, 이미지 1/2 MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: 23 단계, 이미지 2/2
    • Carefully pull the DC-In board connector straight out of its socket on the logic board.
  23. MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: 24 단계, 이미지 1/3 MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: 24 단계, 이미지 2/3 MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: 24 단계, 이미지 3/3
    • Wedge the flat end of a spudger under the left speaker cable near the connector and lift it straight up out of its socket and fold it out of the way.
  24. MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: 25 단계, 이미지 1/2 MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: 25 단계, 이미지 2/2
    • If necessary, peel back any tape covering the microphone cable ZIF connector.
  25. MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: 26 단계, 이미지 1/3 MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: 26 단계, 이미지 2/3 MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: 26 단계, 이미지 3/3
    • Use the tip of a spudger to flip the retaining tab on the microphone cable ZIF connector.
    • Pull the microphone cable out of its socket on the logic board.
  26. MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: 27 단계, 이미지 1/3 MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: 27 단계, 이미지 2/3 MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: 27 단계, 이미지 3/3
    • If necessary, peel back any tape covering the keyboard cable connector.
    • Use the tip of a spudger to flip the retaining tab on the ZIF connector.
  27. MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: 28 단계, 이미지 1/2 MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: 28 단계, 이미지 2/2
    • Pull the keyboard cable straight out of its ZIF socket on the logic board.
  28. MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: 29 단계, 이미지 1/3 MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: 29 단계, 이미지 2/3 MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: 29 단계, 이미지 3/3
    • If necessary, peel back any tape covering the trackpad cable connector.
  29. MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: 30 단계, 이미지 1/2 MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: 30 단계, 이미지 2/2
    • Pull the trackpad ribbon cable straight out of its socket on the logic board.
  30. MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: 31 단계, 이미지 1/1
    • Remove the five 3.5 mm T5 Torx screws securing the logic board to the upper case.
    • When reassembling, install all five screws loosely, position the logic board, and then tighten evenly.
  31. MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: 32 단계, 이미지 1/3 MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: 32 단계, 이미지 2/3 MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: 32 단계, 이미지 3/3
    • Lift the processor end of the logic board up slightly and pull it toward the fan recess to free the ports from the edge of the upper case.
    • Remove the logic board.
    • When reinstalling, make sure the keyboard, keyboard backlight, MagSafe, and microphone cables don't get trapped beneath the logic board.
    • Also be sure to slide the ports' metal EMI fingers under the side of the case, not over.
  32. MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement, Dual Microphone Assembly: 33 단계, 이미지 1/1
    • Remove the following screws securing the left speaker to the upper case:
    • One 5.7 mm T5 Torx screw
    • One 6.5 mm T5 Torx screw
    • One 3.8 mm T5 Torx screw
  33. MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: 34 단계, 이미지 1/3 MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: 34 단계, 이미지 2/3 MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: 34 단계, 이미지 3/3
    • Lift the corner of the left speaker up and slide it toward the battery to remove it from the upper case.
    • Be careful not to snag the speaker cable on the screw hole post in the side of the case.
  34. MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: 35 단계, 이미지 1/1
    • Remove the single 3.7 mm T5 Torx screw securing the case-edge of the battery contact board.
  35. MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: 36 단계, 이미지 1/2 MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: 36 단계, 이미지 2/2
    • Insert the tip of a spudger under the battery-side portion of the rubber microphone cable cover to detach the adhesive there.
  36. MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: 37 단계, 이미지 1/2 MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: 37 단계, 이미지 2/2
    • Use the flat end of a spudger to wedge the battery contact board up slightly to allow room to extract the dual microphone assembly.
  37. MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: 38 단계, 이미지 1/3 MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: 38 단계, 이미지 2/3 MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: 38 단계, 이미지 3/3
    • Remove the rubber microphone cover with a set of tweezers
    • Be careful not to snag the cover on the screw post in the case or on the battery contact board.
  38. MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: 39 단계, 이미지 1/3 MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: 39 단계, 이미지 2/3 MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: 39 단계, 이미지 3/3
    • Insert the tip of a spudger underneath the connector end of the microphone ribbon cable and slide it toward the screw post to free that half from the upper case.
    • If the microphone is very resistant to prying, try heating it with an iOpener. Heating it will soften the adhesive and minimize the risk of tearing the cable.
  39. MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: 40 단계, 이미지 1/3 MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: 40 단계, 이미지 2/3 MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: 40 단계, 이미지 3/3
    • Insert the tip of a spudger under the battery-side portion of the microphone ribbon cable and slide it toward the screw post to free it from the upper case.
  40. MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: 41 단계, 이미지 1/2 MacBook Pro 13" Retina Display Mid 2014 Dual Microphone Assembly Replacement: 41 단계, 이미지 2/2
    • Pull the dual microphone cable assembly up and toward the logic board recess to remove it from the upper case.
    • Be very careful not to snag the cable on the screw post in the case or the battery contact board.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Sam Goldheart
회원 가입일: 10/18/12
457,237 평판
안내서 537개 작성하였습니다
iFixit iFixit 회원
Community
138 회원들
안내서 17,041개 작성하였습니다
2 댓글
Very clear and concise, thank you.
T Col - 답글
Where can you get the replacement microphone? Do you have the part number?
Hanks Caddy - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 12
30일 전: 41
전체 시간: 6,043
