주요 콘텐츠로 건너뛰기
MacBook Pro 13" Retina Display Mid 2014 Fan Replacement
필요한 것
  1. MacBook Pro 13" Retina Display Mid 2014 Fan Replacement, Lower Case: 1 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    Magnetic Project Mat
    $16.96
    • Two 2.3 mm P5 Pentalobe screws
    • Eight 3.0 mm P5 Pentalobe screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
  2. MacBook Pro 13" Retina Display Mid 2014 Fan Replacement: 2 단계, 이미지 1개 중 1개
    • Wedge your fingers between the upper case and the lower case.
    • Gently pull the lower case away from the upper case to remove it.
  3. MacBook Pro 13" Retina Display Mid 2014 Fan Replacement: 3 단계, 이미지 2개 중 1개 MacBook Pro 13" Retina Display Mid 2014 Fan Replacement: 3 단계, 이미지 2개 중 2개
    • The lower case is connected to the upper case with two plastic clips near its center.
    • During reassembly, gently push down the center of the lower case to reattach the two plastic clips.
  4. MacBook Pro 13" Retina Display Mid 2014 Fan Replacement, Battery Connector: 4 단계, 이미지 1개 중 1개
    • If necessary, remove the plastic cover adhered to the battery contact board.
  5. MacBook Pro 13" Retina Display Mid 2014 Fan Replacement: 5 단계, 이미지 2개 중 1개 MacBook Pro 13" Retina Display Mid 2014 Fan Replacement: 5 단계, 이미지 2개 중 2개
    • Use the flat end of a spudger to lift the battery connector straight up out of its socket on the logic board.
    • Be sure you lift up only on the connector itself, not the socket, or you risk permanent damage to the logic board.
  6. MacBook Pro 13" Retina Display Mid 2014 Fan Replacement: 6 단계, 이미지 1개 중 1개
    • Bend the battery connector up out of the way to prevent accidental contact with its socket during your repair.
  7. MacBook Pro 13" Retina Display Mid 2014 Fan Replacement, Heat Sink: 7 단계, 이미지 3개 중 1개 MacBook Pro 13" Retina Display Mid 2014 Fan Replacement, Heat Sink: 7 단계, 이미지 3개 중 2개 MacBook Pro 13" Retina Display Mid 2014 Fan Replacement, Heat Sink: 7 단계, 이미지 3개 중 3개
    • Carefully remove the rubber fan bumper from the edge of the heat sink.
    • The fan bumper wraps around the heat sink and fits into slots in the fan duct. During reassembly, be sure to fit the tabs into the notches in the fan duct.
  8. MacBook Pro 13" Retina Display Mid 2014 Fan Replacement: 8 단계, 이미지 2개 중 1개 MacBook Pro 13" Retina Display Mid 2014 Fan Replacement: 8 단계, 이미지 2개 중 2개
    • Use the flat end of a spudger to peel the four foam stickers off of the heat sink screws.
  9. MacBook Pro 13" Retina Display Mid 2014 Fan Replacement: 9 단계, 이미지 1개 중 1개
    • Remove the following screws securing the heat sink to the logic board:
    • Four 2.6 mm T5 screws
    • One 2.4 mm Phillips #000 screw
  10. MacBook Pro 13" Retina Display Mid 2014 Fan Replacement: 10 단계, 이미지 2개 중 1개 MacBook Pro 13" Retina Display Mid 2014 Fan Replacement: 10 단계, 이미지 2개 중 2개
  11. MacBook Pro 13" Retina Display Mid 2014 Fan Replacement, Fan: 11 단계, 이미지 2개 중 1개 MacBook Pro 13" Retina Display Mid 2014 Fan Replacement, Fan: 11 단계, 이미지 2개 중 2개
    • Use the tip of a spudger to push on either side of the the iSight camera cable connector to walk it out of its socket on the logic board.
  12. MacBook Pro 13" Retina Display Mid 2014 Fan Replacement: 12 단계, 이미지 2개 중 1개 MacBook Pro 13" Retina Display Mid 2014 Fan Replacement: 12 단계, 이미지 2개 중 2개
    • Peel the iSight camera cable off the fan housing to fold it out of the way.
  13. MacBook Pro 13" Retina Display Mid 2014 Fan Replacement: 13 단계, 이미지 3개 중 1개 MacBook Pro 13" Retina Display Mid 2014 Fan Replacement: 13 단계, 이미지 3개 중 2개 MacBook Pro 13" Retina Display Mid 2014 Fan Replacement: 13 단계, 이미지 3개 중 3개
    • Use the tip of a spudger to flip the tab on the fan's ZIF connector.
    • Carefully pull the fan cable straight out of its socket.
  14. MacBook Pro 13" Retina Display Mid 2014 Fan Replacement: 14 단계, 이미지 1개 중 1개
    • Remove the following screws securing the fan to the upper case:
    • One 5.0 mm T5 Torx screw
    • Two 3.6 mm T5 Torx screws
  15. MacBook Pro 13" Retina Display Mid 2014 Fan Replacement: 15 단계, 이미지 3개 중 1개 MacBook Pro 13" Retina Display Mid 2014 Fan Replacement: 15 단계, 이미지 3개 중 2개 MacBook Pro 13" Retina Display Mid 2014 Fan Replacement: 15 단계, 이미지 3개 중 3개
    • Lift the end of the fan closest to the display hinge and remove the fan from the upper case.
결론
다른 28명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Sam Goldheart
회원 가입일: 10/18/12
474,929 평판
안내서 538개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,608개를 작성함
4가이드 댓글
Very clear guide, and highly informative photos. It might be useful to add that the PL5 screws on the back of the case do not insert vertically. These insert at a slight angle and attempting to insert them straight will cause cross treading.
Robert Chave - 답글
Simple and clear step by step instructions.
cosilverturq - 답글
What is the use of the four foam stickers in step 9? Mine don’t stick anymore after taking out.
Visalbotr Chan - 답글
A mi me ha pasado lo mismo. Supongo que sirve para ejercer una pequeña presión sobre los tornillos. Yo le he puesto unas pegatinas, recortadas, de las que se usan para tope de muebles, para que no rocen, y creo que hacen el apaño.
Jose Luis -
댓글 쓰기
조회 통계:
지난 24시간: 14
지난 7일: 193
지난 30일: 853
전체 시간: 47,342
