주요 콘텐츠로 건너뛰기
MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement
필요한 것
  1. MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement, Lower Case: 1 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    Magnetic Project Mat
    $16.96
    • Two 2.3 mm P5 Pentalobe screws
    • Eight 3.0 mm P5 Pentalobe screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
  2. MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement: 2 단계, 이미지 1개 중 1개
    • Wedge your fingers between the upper case and the lower case.
    • Gently pull the lower case away from the upper case to remove it.
  3. MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement: 3 단계, 이미지 2개 중 1개 MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement: 3 단계, 이미지 2개 중 2개
    • The lower case is connected to the upper case with two plastic clips near its center.
    • During reassembly, gently push down the center of the lower case to reattach the two plastic clips.
  4. MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement, Battery Connector: 4 단계, 이미지 1개 중 1개
    • If necessary, remove the plastic cover adhered to the battery contact board.
  5. MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement: 5 단계, 이미지 2개 중 1개 MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement: 5 단계, 이미지 2개 중 2개
    • Use the flat end of a spudger to lift the battery connector straight up out of its socket on the logic board.
    • Be sure you lift up only on the connector itself, not the socket, or you risk permanent damage to the logic board.
  6. MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement: 6 단계, 이미지 1개 중 1개
    • Bend the battery connector up out of the way to prevent accidental contact with its socket during your repair.
  7. MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement, Heat Sink: 7 단계, 이미지 3개 중 1개 MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement, Heat Sink: 7 단계, 이미지 3개 중 2개 MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement, Heat Sink: 7 단계, 이미지 3개 중 3개
    • Carefully remove the rubber fan bumper from the edge of the heat sink.
    • The fan bumper wraps around the heat sink and fits into slots in the fan duct. During reassembly, be sure to fit the tabs into the notches in the fan duct.
  8. MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement: 8 단계, 이미지 2개 중 1개 MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement: 8 단계, 이미지 2개 중 2개
    • Use the flat end of a spudger to peel the four foam stickers off of the heat sink screws.
  9. MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement: 9 단계, 이미지 1개 중 1개
    • Remove the following screws securing the heat sink to the logic board:
    • Four 2.6 mm T5 screws
    • One 2.4 mm Phillips #000 screw
  10. MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement: 10 단계, 이미지 2개 중 1개 MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement: 10 단계, 이미지 2개 중 2개
  11. MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement, Fan: 11 단계, 이미지 2개 중 1개 MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement, Fan: 11 단계, 이미지 2개 중 2개
    • Use the tip of a spudger to push on either side of the the iSight camera cable connector to walk it out of its socket on the logic board.
  12. MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement: 12 단계, 이미지 2개 중 1개 MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement: 12 단계, 이미지 2개 중 2개
    • Peel the iSight camera cable off the fan housing to fold it out of the way.
  13. MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement: 13 단계, 이미지 3개 중 1개 MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement: 13 단계, 이미지 3개 중 2개 MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement: 13 단계, 이미지 3개 중 3개
    • Use the tip of a spudger to flip the tab on the fan's ZIF connector.
    • Carefully pull the fan cable straight out of its socket.
  14. MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement: 14 단계, 이미지 1개 중 1개
    • Remove the following screws securing the fan to the upper case:
    • One 5.0 mm T5 Torx screw
    • Two 3.6 mm T5 Torx screws
  15. MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement: 15 단계, 이미지 3개 중 1개 MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement: 15 단계, 이미지 3개 중 2개 MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement: 15 단계, 이미지 3개 중 3개
    • Lift the end of the fan closest to the display hinge and remove the fan from the upper case.
  16. MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement, Logic Board Assembly: 16 단계, 이미지 2개 중 1개 MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement, Logic Board Assembly: 16 단계, 이미지 2개 중 2개
    • Remove the two 2.1 mm T5 Torx screws securing the I/O board cable bracket to the logic board.
    • Remove the I/O board cable bracket.
  17. MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement: 17 단계, 이미지 2개 중 1개 MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement: 17 단계, 이미지 2개 중 2개
    • Use the flat end of a spudger to pop the I/O board connector straight up off its socket on the logic board.
    • Be careful to only pry up on the I/O board cable, not on the socket itself or you risk damaging your logic board.
  18. MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement: 18 단계, 이미지 2개 중 1개 MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement: 18 단계, 이미지 2개 중 2개
    • Lift the logic board end of the I/O board cable straight up to bend it out of the way.
    • To avoid damage to the cable, fold only at the bend in the I/O board end of the cable.
  19. MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement: 19 단계, 이미지 2개 중 1개 MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement: 19 단계, 이미지 2개 중 2개
    • Use the tip of a spudger to lift the right speaker connector straight up out of its socket on the logic board.
  20. MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement: 20 단계, 이미지 2개 중 1개 MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement: 20 단계, 이미지 2개 중 2개
    • With the tip of a spudger, push on either side of the I/O board connector to walk it out of its socket on the logic board.
  21. MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement: 21 단계, 이미지 3개 중 1개 MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement: 21 단계, 이미지 3개 중 2개 MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement: 21 단계, 이미지 3개 중 3개
    • Use the flat end of a spudger to disconnect the keyboard backlight cable and bend it up out of the way of the logic board.
  22. MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement: 22 단계, 이미지 3개 중 1개 MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement: 22 단계, 이미지 3개 중 2개 MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement: 22 단계, 이미지 3개 중 3개
    • Grab the black plastic tab to flip the display cable connector open and pull it straight out of its socket on the logic board.
  23. MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement: 23 단계, 이미지 2개 중 1개 MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement: 23 단계, 이미지 2개 중 2개
    • Carefully pull the DC-In board connector straight out of its socket on the logic board.
  24. MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement: 24 단계, 이미지 3개 중 1개 MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement: 24 단계, 이미지 3개 중 2개 MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement: 24 단계, 이미지 3개 중 3개
    • Wedge the flat end of a spudger under the left speaker cable near the connector and lift it straight up out of its socket and fold it out of the way.
  25. MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement: 25 단계, 이미지 2개 중 1개 MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement: 25 단계, 이미지 2개 중 2개
    • If necessary, peel back any tape covering the microphone cable ZIF connector.
  26. MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement: 26 단계, 이미지 3개 중 1개 MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement: 26 단계, 이미지 3개 중 2개 MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement: 26 단계, 이미지 3개 중 3개
    • Use the tip of a spudger to flip the retaining tab on the microphone cable ZIF connector.
    • Pull the microphone cable out of its socket on the logic board.
  27. MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement: 27 단계, 이미지 3개 중 1개 MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement: 27 단계, 이미지 3개 중 2개 MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement: 27 단계, 이미지 3개 중 3개
    • If necessary, peel back any tape covering the keyboard cable connector.
    • Use the tip of a spudger to flip the retaining tab on the ZIF connector.
  28. MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement: 28 단계, 이미지 2개 중 1개 MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement: 28 단계, 이미지 2개 중 2개
    • Pull the keyboard cable straight out of its ZIF socket on the logic board.
  29. MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement: 29 단계, 이미지 3개 중 1개 MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement: 29 단계, 이미지 3개 중 2개 MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement: 29 단계, 이미지 3개 중 3개
    • If necessary, peel back any tape covering the trackpad cable connector.
  30. MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement: 30 단계, 이미지 2개 중 1개 MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement: 30 단계, 이미지 2개 중 2개
    • Pull the trackpad ribbon cable straight out of its socket on the logic board.
  31. MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement: 31 단계, 이미지 1개 중 1개
    • Remove the five 3.5 mm T5 Torx screws securing the logic board to the upper case.
    • When reassembling, install all five screws loosely, position the logic board, and then tighten evenly.
  32. MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement: 32 단계, 이미지 3개 중 1개 MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement: 32 단계, 이미지 3개 중 2개 MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement: 32 단계, 이미지 3개 중 3개
    • Lift the processor end of the logic board up slightly and pull it toward the fan recess to free the ports from the edge of the upper case.
    • Remove the logic board.
    • When reinstalling, make sure the keyboard, keyboard backlight, MagSafe, and microphone cables don't get trapped beneath the logic board.
    • Also be sure to slide the ports' metal EMI fingers under the side of the case, not over.
  33. MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement, Logic Board: 33 단계, 이미지 1개 중 1개
    • Remove the single 2.9 mm T5 Torx screw securing the SSD to the logic board.
  34. MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement: 34 단계, 이미지 3개 중 1개 MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement: 34 단계, 이미지 3개 중 2개 MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement: 34 단계, 이미지 3개 중 3개
    • Lift the free end of the SSD up slightly and pull it straight out of its socket on the logic board.
결론
다른 53명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Sam Goldheart
회원 가입일: 10/18/12
474,924 평판
안내서 538개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,608개를 작성함
10가이드 댓글
Hi @sam !
I have a macbook pro 13" retina i5 2.6 8gb mid 2014 Model. A1502 and it has the damaged board.
In SAT, I changed it for 600 euros to replace it.
I have found a logicboard used for this same model A1502 (i7 3.0 Ghz 8Gb Ram) for half price and I would like to know if it is possible to replace it for this, or the mac will give me some problem when plugging a logicboard with different characteristics that the original?
Thanks for you support !
neotic82 - 답글
Was these ever answered?
Jimbo Hayze -
Question: Can I put a 2014 logic board in a 2015 model? I have a water damaged MF839LL/a 2015 model, but I can get a MGX72LL/a 2014 model logic board for cheap. Thanks!
Danny M - 답글
Sam, thank you so much! Repair guide worked perfectly for removing logic board to clean corrosion after a water spill on the keyboard! Everything was exactly as picture and explained. I have two questions I was hoping Sam or someone else knowledgeable could answer.
1. Can/ should I replace the foam stickers from the heat sink screws (step 8)? If so, what kind of computer safe adhesive should I use to ensure that they stay in place?
2. Should the plastic cover adhered to the battery contact board in step 4 be replaced?
Andrew Lingousky - 답글
Thanks from the bottom of my feet for the excellent guide, my water-damaged mac lives again! Everything works but the power button…
stupple82 - 답글
댓글 쓰기
조회 통계:
지난 24시간: 77
지난 7일: 543
지난 30일: 913
전체 시간: 88,195
