주요 콘텐츠로 건너뛰기
MacBook Pro 13" Touch Bar 2018 Battery Replacement
필요한 것
  1. MacBook Pro 13" Touch Bar 2018 Battery Replacement, Disable Auto Boot: 1 단계, 이미지 3개 중 1개 MacBook Pro 13" Touch Bar 2018 Battery Replacement, Disable Auto Boot: 1 단계, 이미지 3개 중 2개 MacBook Pro 13" Touch Bar 2018 Battery Replacement, Disable Auto Boot: 1 단계, 이미지 3개 중 3개
    • Before starting this procedure, you must disable your Mac's Auto Boot feature. Auto Boot powers on your Mac when you open the lid, and may be accidentally triggered during disassembly. Use this guide or follow the abbreviated instructions below to disable Auto Boot. This command may not work on all Macs.
    • Power on your Mac and launch Terminal.
    • Copy and paste the following command (or type it exactly) into Terminal:
    • sudo nvram AutoBoot=%00
    • Press [return]. If prompted, enter your administrator password and press [return] again. Note: Your return key may also be labeled ⏎ or "enter."
    • You can now safely power down your Mac and open the bottom case, without it accidentally powering on.
    • When your repair is complete and your Mac is successfully reassembled, re-enable Auto Boot with the following command:
    • sudo nvram AutoBoot=%03
  2. MacBook Pro 13" Touch Bar 2018 Battery Replacement, Remove the pentalobe screws: 2 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    Magnetic Project Mat
    $19.95
    • Before proceeding, unplug and power down your MacBook. Close the display and lay it on a soft surface, top-side down.
    • Use a P5 Pentalobe driver to remove the six screws securing the lower case:
    • Two 6.2 mm screws
    • Four 3.4 mm screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
  3. MacBook Pro 13" Touch Bar 2018 Battery Replacement, Open a gap using a suction cup: 3 단계, 이미지 2개 중 1개 MacBook Pro 13" Touch Bar 2018 Battery Replacement, Open a gap using a suction cup: 3 단계, 이미지 2개 중 2개
    • Apply a suction handle to the lower case near the front-center area of the MacBook Pro.
    • Lift the suction handle to create a slight gap between the lower case and the chassis.
  4. MacBook Pro 13" Touch Bar 2018 Battery Replacement, Separate the clips: 4 단계, 이미지 3개 중 1개 MacBook Pro 13" Touch Bar 2018 Battery Replacement, Separate the clips: 4 단계, 이미지 3개 중 2개 MacBook Pro 13" Touch Bar 2018 Battery Replacement, Separate the clips: 4 단계, 이미지 3개 중 3개
    • Insert one corner of an opening pick into the space between the lower case and the chassis.
    • Slide the opening pick around the nearest corner and halfway up the side of the case.
    • This releases the first of the hidden clips securing the lower case to the chassis. You should feel and hear the clip pop free.
  5. MacBook Pro 13" Touch Bar 2018 Battery Replacement: 5 단계, 이미지 3개 중 1개 MacBook Pro 13" Touch Bar 2018 Battery Replacement: 5 단계, 이미지 3개 중 2개 MacBook Pro 13" Touch Bar 2018 Battery Replacement: 5 단계, 이미지 3개 중 3개
    • Repeat the previous step on the opposite side, sliding your opening pick under the lower case and up the side to pop the second clip free.
  6. MacBook Pro 13" Touch Bar 2018 Battery Replacement: 6 단계, 이미지 3개 중 1개 MacBook Pro 13" Touch Bar 2018 Battery Replacement: 6 단계, 이미지 3개 중 2개 MacBook Pro 13" Touch Bar 2018 Battery Replacement: 6 단계, 이미지 3개 중 3개
    • Insert your opening pick once again under the front edge of the lower case, near one of the two centermost screw holes.
    • Give the pick a firm twist to pop free the third clip securing the lower case to the chassis.
    • Repeat this procedure near the other of the two centermost screw holes, popping the fourth clip free.
  7. MacBook Pro 13" Touch Bar 2018 Battery Replacement: 7 단계, 이미지 3개 중 1개 MacBook Pro 13" Touch Bar 2018 Battery Replacement: 7 단계, 이미지 3개 중 2개 MacBook Pro 13" Touch Bar 2018 Battery Replacement: 7 단계, 이미지 3개 중 3개
    • Pull the lower case firmly towards the front of the MacBook (away from the hinge area) to separate the last of the clips securing the lower case.
    • Pull first at one corner, then the other.
    • Pull to the side—not up.
    • This can require a lot of force.
  8. MacBook Pro 13" Touch Bar 2018 Battery Replacement, Remove the lower case: 8 단계, 이미지 3개 중 1개 MacBook Pro 13" Touch Bar 2018 Battery Replacement, Remove the lower case: 8 단계, 이미지 3개 중 2개 MacBook Pro 13" Touch Bar 2018 Battery Replacement, Remove the lower case: 8 단계, 이미지 3개 중 3개
    • Remove the lower case.
    • To reinstall the lower case:
    • Set it in place and align the sliding clips near the display hinge. Press down and slide the cover toward the hinge. It should stop sliding as the clips engage.
    • When the sliding clips are fully engaged and the lower case looks correctly aligned, press down firmly on the lower case to engage the four hidden clips underneath. You should feel and hear them snap into place.
  9. MacBook Pro 13" Touch Bar 2018 Battery Replacement, Uncover the battery connector: 9 단계, 이미지 2개 중 1개 MacBook Pro 13" Touch Bar 2018 Battery Replacement, Uncover the battery connector: 9 단계, 이미지 2개 중 2개
    • Carefully peel up the large piece of tape covering the battery connector, on the edge of the logic board nearest the battery.
    • Remove the tape.
  10. MacBook Pro 13" Touch Bar 2018 Battery Replacement: 10 단계, 이미지 2개 중 1개 MacBook Pro 13" Touch Bar 2018 Battery Replacement: 10 단계, 이미지 2개 중 2개
    • Gently peel back the small piece of tape covering the battery board data cable connector.
    • The tape is integrated into the ribbon cable and will not detach completely. Simply peel it back enough to access the connector.
  11. MacBook Pro 13" Touch Bar 2018 Battery Replacement: 11 단계, 이미지 2개 중 1개 MacBook Pro 13" Touch Bar 2018 Battery Replacement: 11 단계, 이미지 2개 중 2개
    • Use the tip of a spudger to flip up the small black locking tab securing the cable in its connector.
  12. MacBook Pro 13" Touch Bar 2018 Battery Replacement: 12 단계, 이미지 2개 중 1개 MacBook Pro 13" Touch Bar 2018 Battery Replacement: 12 단계, 이미지 2개 중 2개
    • Disconnect the battery board data cable by sliding it out from its socket.
    • Slide parallel to the logic board, in the direction of the cable.
  13. MacBook Pro 13" Touch Bar 2018 Battery Replacement: 13 단계, 이미지 2개 중 1개 MacBook Pro 13" Touch Bar 2018 Battery Replacement: 13 단계, 이미지 2개 중 2개
    • Fold the battery board data cable to the side and out of the way.
  14. MacBook Pro 13" Touch Bar 2018 Battery Replacement: 14 단계, 이미지 1개 중 1개
    • Use a T5 Torx driver to remove the 3.7 mm pancake screw securing the battery power connector.
  15. MacBook Pro 13" Touch Bar 2018 Battery Replacement, Disconnect the battery: 15 단계, 이미지 2개 중 1개 MacBook Pro 13" Touch Bar 2018 Battery Replacement, Disconnect the battery: 15 단계, 이미지 2개 중 2개
    • Use a spudger to gently lift the battery power connector, disconnecting the battery.
    • Lift the connector high enough so that it stays separated from its socket. If it accidentally makes contact during the course of your repair, it could damage your MacBook Pro.
  16. MacBook Pro 13" Touch Bar 2018 Battery Replacement, Remove the trackpad connector screws: 16 단계, 이미지 1개 중 1개
    • Use a T3 Torx driver to remove the two 1.8 mm screws securing the trackpad cable connector bracket.
  17. MacBook Pro 13" Touch Bar 2018 Battery Replacement: 17 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Remove the trackpad cable connector bracket with a pair of tweezers.
  18. MacBook Pro 13" Touch Bar 2018 Battery Replacement, Disconnect the trackpad: 18 단계, 이미지 2개 중 1개 MacBook Pro 13" Touch Bar 2018 Battery Replacement, Disconnect the trackpad: 18 단계, 이미지 2개 중 2개
    • Use a spudger to disconnect the trackpad ribbon cable by gently prying its connector straight up from the logic board.
  19. MacBook Pro 13" Touch Bar 2018 Battery Replacement, Heat the trackpad cable: 19 단계, 이미지 1개 중 1개
    • Prepare an iOpener and lay it on top of the trackpad ribbon cable for about a minute, in order to soften the adhesive securing the trackpad ribbon cable to the top of the battery.
    • If you don't have an iOpener, use a hair dryer to warm up the cable instead. The cable should be warm, but not too hot to touch. Be careful not to overheat the battery.
  20. MacBook Pro 13" Touch Bar 2018 Battery Replacement, Peel up the trackpad cable: 20 단계, 이미지 3개 중 1개 MacBook Pro 13" Touch Bar 2018 Battery Replacement, Peel up the trackpad cable: 20 단계, 이미지 3개 중 2개 MacBook Pro 13" Touch Bar 2018 Battery Replacement, Peel up the trackpad cable: 20 단계, 이미지 3개 중 3개
    • Carefully peel the trackpad ribbon cable up off the battery, and push it out of the way.
    • Do not fold or tear the cable.
  21. MacBook Pro 13" Touch Bar 2018 Battery Replacement, Remove the trackpad screws: 21 단계, 이미지 1개 중 1개
    • Use a T5 Torx driver to remove the ten screws securing the trackpad assembly:
    • Two 4.3 mm screws
    • Eight 5.8 mm screws
  22. MacBook Pro 13" Touch Bar 2018 Battery Replacement: 22 단계, 이미지 2개 중 1개 MacBook Pro 13" Touch Bar 2018 Battery Replacement: 22 단계, 이미지 2개 중 2개
    • Swing the display open slightly to access the trackpad.
    • Carefully thread the trackpad ribbon cable out through the hole in the MacBook Pro's frame.
  23. MacBook Pro 13" Touch Bar 2018 Battery Replacement: 23 단계, 이미지 3개 중 1개 MacBook Pro 13" Touch Bar 2018 Battery Replacement: 23 단계, 이미지 3개 중 2개 MacBook Pro 13" Touch Bar 2018 Battery Replacement: 23 단계, 이미지 3개 중 3개
    • Remove the trackpad assembly.
    • Be sure not to lose the six small washers (two circular and four rectangular) resting on the underside of the trackpad.
  24. MacBook Pro 13" Touch Bar 2018 Battery Replacement, Unscrew the battery board: 24 단계, 이미지 1개 중 1개
    • Use a T5 Torx driver to remove the two 3.2 mm screws from the battery board.
  25. MacBook Pro 13" Touch Bar 2018 Battery Replacement, Protect the display and keyboard: 25 단계, 이미지 3개 중 1개 MacBook Pro 13" Touch Bar 2018 Battery Replacement, Protect the display and keyboard: 25 단계, 이미지 3개 중 2개 MacBook Pro 13" Touch Bar 2018 Battery Replacement, Protect the display and keyboard: 25 단계, 이미지 3개 중 3개
    • The liquid adhesive remover provided in your kit can cause damage if it contacts the MacBook Pro's display or keyboard.
    • To protect your display, place a sheet of aluminum foil between the display and keyboard and leave it there while you work.
    • Additionally, use some tape and/or foil to seal off the area under the trackpad. Optionally, you may also layer an absorbent towel directly underneath the trackpad area to soak up any excess adhesive remover.
  26. MacBook Pro 13" Touch Bar 2018 Battery Replacement, Protect the speakers: 26 단계, 이미지 1개 중 1개
    • Before removing the battery, it's important to protect the speakers on either side. The speakers are glued down just like the battery—so if the liquid adhesive remover gets under the speakers, they may come loose and rattle after your repair.
    • Cut a length of packing tape or painter's tape, and slide one edge between the battery and the speaker on the left side.
  27. MacBook Pro 13" Touch Bar 2018 Battery Replacement: 27 단계, 이미지 3개 중 1개 MacBook Pro 13" Touch Bar 2018 Battery Replacement: 27 단계, 이미지 3개 중 2개 MacBook Pro 13" Touch Bar 2018 Battery Replacement: 27 단계, 이미지 3개 중 3개
    • Press all along the edge of the tape with your spudger to stick it securely to the MacBook Pro's aluminum case, sealing off the speaker from the battery.
    • Be careful not to poke or puncture the battery.
    • Fold the tape over and lightly adhere it to the speaker to keep it out of the way.
    • The foam bumpers on top of the speaker may tear when peeling the tape off. Don't press the tape directly onto the bumpers.
  28. MacBook Pro 13" Touch Bar 2018 Battery Replacement: 28 단계, 이미지 1개 중 1개
    • Repeat the previous two steps on the opposite side in order to seal off the other speaker from the battery.
  29. MacBook Pro 13" Touch Bar 2018 Battery Replacement, Elevate the right edge: 29 단계, 이미지 3개 중 1개 MacBook Pro 13" Touch Bar 2018 Battery Replacement, Elevate the right edge: 29 단계, 이미지 3개 중 2개 MacBook Pro 13" Touch Bar 2018 Battery Replacement, Elevate the right edge: 29 단계, 이미지 3개 중 3개
    • To control the flow of adhesive remover and direct it away from the speaker, raise the right edge of your MacBook Pro a few inches using a book or foam block.
  30. MacBook Pro 13" Touch Bar 2018 Battery Replacement, Protect your eyes and skin: 30 단계, 이미지 2개 중 1개 MacBook Pro 13" Touch Bar 2018 Battery Replacement, Protect your eyes and skin: 30 단계, 이미지 2개 중 2개
    • Now that your MacBook Pro is fully prepped, it's time to prep yourself.
    • iFixit adhesive remover contains acetone, a mild skin and eye irritant.
    • Wear eye protection when handling and applying the adhesive remover. (Eye protection is included in your kit.)
    • Do not wear contact lenses without eye protection.
    • Protective gloves are also included in your kit. If you are concerned about possible skin irritation, put your gloves on now.
  31. MacBook Pro 13" Touch Bar 2018 Battery Replacement, Open the adhesive remover: 31 단계, 이미지 3개 중 1개 MacBook Pro 13" Touch Bar 2018 Battery Replacement, Open the adhesive remover: 31 단계, 이미지 3개 중 2개 MacBook Pro 13" Touch Bar 2018 Battery Replacement, Open the adhesive remover: 31 단계, 이미지 3개 중 3개
    • Pull off the black rubber stopper from your bottle of adhesive remover.
    • Twist to loosen or remove the bottle cap before you cut the applicator tip.
    • This unseals the bottle and allows the pressure to equalize before you cut the applicator tip. If you skip this step, the adhesive remover may spray out unexpectedly when the tip is cut.
    • Use scissors to cut off the sealed tip of the applicator.
    • Cutting close to the narrow tip will give you better control so you can apply the adhesive remover in small amounts.
    • Twist and close the bottle cap securely before you proceed further.
  32. MacBook Pro 13" Touch Bar 2018 Battery Replacement, Apply the adhesive remover: 32 단계, 이미지 3개 중 1개 MacBook Pro 13" Touch Bar 2018 Battery Replacement, Apply the adhesive remover: 32 단계, 이미지 3개 중 2개 MacBook Pro 13" Touch Bar 2018 Battery Replacement, Apply the adhesive remover: 32 단계, 이미지 3개 중 3개
    • Apply a few drops of adhesive remover underneath the far right battery cell.
    • You don't need to use very much—the small bottle contains more than twice the amount of solvent needed to remove all the battery cells.
    • Wait about two minutes for the adhesive remover to penetrate and soften the battery adhesive before you proceed to the next step.
  33. MacBook Pro 13" Touch Bar 2018 Battery Replacement, Separate the outside right battery cell: 33 단계, 이미지 3개 중 1개 MacBook Pro 13" Touch Bar 2018 Battery Replacement, Separate the outside right battery cell: 33 단계, 이미지 3개 중 2개 MacBook Pro 13" Touch Bar 2018 Battery Replacement, Separate the outside right battery cell: 33 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    Plastic Cards
    $2.99
    • After a couple minutes, insert one corner of a plastic card underneath the far right battery cell, starting from the front edge.
    • This shouldn't require much force. If you have trouble, apply more adhesive remover and give it 2-3 additional minutes to penetrate.
    • Try not to deform the battery. A damaged battery can leak dangerous chemicals and/or catch fire.
    • Wiggle the card from side to side and slide it all the way under the battery cell.
    • Lift to fully separate the adhesive, but don't try to remove the battery cell yet.
    • Leave the plastic card temporarily underneath the cell to prevent it from re-adhering while you continue.
  34. MacBook Pro 13" Touch Bar 2018 Battery Replacement, Alternative: separate the battery cell with floss: 34 단계, 이미지 1개 중 1개
    • If you have difficulty getting the card underneath any of the battery cells, try working a piece of floss or wire underneath the battery cell. Pull it side-to-side in a sawing motion to separate the adhesive.
    • Wear thick gloves or wrap the floss around a couple of driver handles so as not to hurt your fingers.
  35. MacBook Pro 13" Touch Bar 2018 Battery Replacement, Elevate the left edge: 35 단계, 이미지 2개 중 1개 MacBook Pro 13" Touch Bar 2018 Battery Replacement, Elevate the left edge: 35 단계, 이미지 2개 중 2개
    • Repeat the last few steps to separate the far left battery cell.
    • Begin by elevating the left side of the MacBook Pro to direct the flow of adhesive remover away from the speaker.
  36. MacBook Pro 13" Touch Bar 2018 Battery Replacement, Apply adhesive remover: 36 단계, 이미지 3개 중 1개 MacBook Pro 13" Touch Bar 2018 Battery Replacement, Apply adhesive remover: 36 단계, 이미지 3개 중 2개 MacBook Pro 13" Touch Bar 2018 Battery Replacement, Apply adhesive remover: 36 단계, 이미지 3개 중 3개
    • Apply a few drops of adhesive remover under the far left battery cell, and wait about two minutes for it to penetrate.
  37. MacBook Pro 13" Touch Bar 2018 Battery Replacement, Separate the outer left cell: 37 단계, 이미지 2개 중 1개 MacBook Pro 13" Touch Bar 2018 Battery Replacement, Separate the outer left cell: 37 단계, 이미지 2개 중 2개
    • Slide one corner of a plastic card underneath the far left battery cell, and carefully separate the adhesive holding it in place.
  38. MacBook Pro 13" Touch Bar 2018 Battery Replacement, Elevate the back edge: 38 단계, 이미지 1개 중 1개
    • Next, raise the back edge of your MacBook Pro to direct the flow of adhesive remover away from the keyboard/logic board area.
  39. MacBook Pro 13" Touch Bar 2018 Battery Replacement, Apply adhesive remover: 39 단계, 이미지 3개 중 1개 MacBook Pro 13" Touch Bar 2018 Battery Replacement, Apply adhesive remover: 39 단계, 이미지 3개 중 2개 MacBook Pro 13" Touch Bar 2018 Battery Replacement, Apply adhesive remover: 39 단계, 이미지 3개 중 3개
    • Apply a few drops of adhesive remover under each of the remaining three battery cells.
    • There are openings in the aluminum case underneath these cells, so some of the adhesive remover may leak out instead of penetrating underneath the battery.
    • Be mindful of leaks, and apply more adhesive remover in the following steps if needed.
    • Wait about two minutes before you continue.
  40. MacBook Pro 13" Touch Bar 2018 Battery Replacement, Separate the inner left cell: 40 단계, 이미지 3개 중 1개 MacBook Pro 13" Touch Bar 2018 Battery Replacement, Separate the inner left cell: 40 단계, 이미지 3개 중 2개 MacBook Pro 13" Touch Bar 2018 Battery Replacement, Separate the inner left cell: 40 단계, 이미지 3개 중 3개
    • The remaining two smaller battery cells each sit on a slightly raised portion of the MacBook's aluminum frame.
    • Slide a plastic card all the way underneath the far left battery cell—which you already separated in the previous steps—and then insert it carefully between the remaining left-side battery cell and the MacBook Pro's aluminum case.
  41. MacBook Pro 13" Touch Bar 2018 Battery Replacement: 41 단계, 이미지 2개 중 1개 MacBook Pro 13" Touch Bar 2018 Battery Replacement: 41 단계, 이미지 2개 중 2개
    • Use your plastic card to fully separate the remaining battery cell on the left side.
    • Take care to not pry against the logic board.
    • Leave your plastic card in place temporarily to prevent the left-side battery cells from re-adhering.
  42. MacBook Pro 13" Touch Bar 2018 Battery Replacement, Separate the inner right cell: 42 단계, 이미지 3개 중 1개 MacBook Pro 13" Touch Bar 2018 Battery Replacement, Separate the inner right cell: 42 단계, 이미지 3개 중 2개 MacBook Pro 13" Touch Bar 2018 Battery Replacement, Separate the inner right cell: 42 단계, 이미지 3개 중 3개
    • Repeat the previous two steps to separate the remaining battery cell on the right.
  43. MacBook Pro 13" Touch Bar 2018 Battery Replacement, Separate the middle cells: 43 단계, 이미지 3개 중 1개 MacBook Pro 13" Touch Bar 2018 Battery Replacement, Separate the middle cells: 43 단계, 이미지 3개 중 2개 MacBook Pro 13" Touch Bar 2018 Battery Replacement, Separate the middle cells: 43 단계, 이미지 3개 중 3개
    • The final battery cells can be more difficult to remove. If needed, apply more adhesive remover to make the job easier.
    • Slide the corner of one of your plastic cards underneath the top edge of one of the cells and then work it underneath the other cell.
    • Wiggle the card from side to side and slide it underneath the battery cells to fully separate the adhesive holding them in place.
  44. MacBook Pro 13" Touch Bar 2018 Battery Replacement, Remove the battery: 44 단계, 이미지 3개 중 1개 MacBook Pro 13" Touch Bar 2018 Battery Replacement, Remove the battery: 44 단계, 이미지 3개 중 2개 MacBook Pro 13" Touch Bar 2018 Battery Replacement, Remove the battery: 44 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Before you remove the battery, ensure that the battery connector is sufficiently raised and not in the way of the battery board.
    • Remove the battery.
    • Before installing a new battery, remove all remaining adhesive from the MacBook Pro's case.
    • Peel off any large strips of adhesive using tweezers or gloved fingers.
    • Scrape away any remaining chunks of adhesive with a plastic tool, and clean the underlying areas with adhesive remover or isopropyl alcohol. Wipe in one direction (not back and forth) until the chassis is clean and ready for your new battery.
    • This can take quite a bit of work, so be patient.
    • When you're done, carefully remove the protective tape from the speakers.
  45. MacBook Pro 13" Touch Bar 2018 Battery Replacement, Battery installation: 45 단계, 이미지 3개 중 1개 MacBook Pro 13" Touch Bar 2018 Battery Replacement, Battery installation: 45 단계, 이미지 3개 중 2개 MacBook Pro 13" Touch Bar 2018 Battery Replacement, Battery installation: 45 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    Tesa 61395 Tape
    $12.99
    • Double-check the fit and alignment of your new battery before sticking it down.
    • Be mindful of the battery data cable and make sure it doesn't get pinched or trapped under the battery board.
    • If your battery came with adhesive pre-installed on the bottom, flip it over and carefully peel away the liner to expose the adhesive. If your battery did not come with adhesive, apply a thin double-sided adhesive tape such as Tesa 61395 to keep your battery in place.
    • Carefully position the battery and set it into place.
    • Place the battery close to the logic board so the trackpad cable can reach its connector.
    • Press and hold each cell firmly for 5-10 seconds to secure it to the lower case.
결론
Repair didn’t go as planned? Try some basic troubleshooting or search our Answers community for help.
다른 47명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Tarun Thiruma
회원 가입일: 11/20/19
37,667 평판
안내서 134개를 작성함
댓글 17개
When remounting, putting back the trackpad in a nicely centered position can become a lengthy exercise of patience.
I haven’t find guides or tricks to help; the best I came up with was to
* put back just two corner screws, without tightening them, that is enough to keep it in place and not lose the washers
* flip back your macbook keyboard up
* center the trackpad and fix it in place with adhesive tape
* flip it back belly-up, tighten the two corner screws and add the remaining six.
Sergio Ballestrero - 답글
Thanks; everything went well, except at the end I realized that I somehow damaged the battery connector from step 12/13. What is the part number, please?
Brian Jackson - 답글
The replacement went very smoothly, and when I re-assembled the laptop, the spacebar and command keys seemed tight. Any thoughts about how that might happen?
JNM - 답글
Der Akkutausch funktioniert auch mit dem Heißluftfön bei max. 100° Celsius…
Einfach die Akku-Sektionen dazu eine Minute etwas erwärmen und dann mit der Karte den Klebstoff lösen!
Der Einbau des Trackpads ist etwas fummelig da es beim Zentrieren keine Arretierung oder ähnliches gibt, dazu am besten einige Schrauben etwas anziehen und dann systematisch festziehen! Ich legte das aufgeklappte MacBook über einen Überhang damit ich von oben das Trackpad immer justieren konnte und mit der anderen Hand schraubte ich von unten die Schrauben fest ;-)
Bruce Kungfuzius - 답글
I fixed it! My original battery had swollen badly and had been a fire hazard.
This was my first time fixing a phone / laptop. Instructions were quite clear and easy to follow. I didn't run into any problem.
Very proud of myself at the moment ☺️
Haoxue Wang - 답글
댓글 쓰기
조회 통계:
지난 24시간: 100
지난 7일: 593
지난 30일: 2,459
전체 시간: 101,491
