주요 콘텐츠로 건너뛰기
이 번역은 원본 안내서의 최신 업데이트를 반영하지 않을 수 있습니다. 번역 업데이트를 돕거나 아니면 원본 안내서 보기를 참조하세요.
MacBook Pro 13" Unibody 中期 2009 电池更换
필요한 것
  1. MacBook Pro 13" Unibody 中期 2009 电池更换, 后壳: 1 단계, 이미지 1/1
    • 移除下列将 MacBook Pro 13" Unibody后壳固定的 10个 螺丝:
    • 7个3 mm Phillips螺丝
    • 3个13.5 mm Phillips 螺丝
  2. MacBook Pro 13" Unibody 中期 2009 电池更换: 2 단계, 이미지 1/1
    • 轻轻提起后壳然后推向电脑的后方来松开卡舌。
  3. MacBook Pro 13" Unibody 中期 2009 电池更换, 电池: 3 단계, 이미지 1/1
    • 拆下将电池固定在顶壳的三点螺丝。
    • 1个 5.5 mm 三点螺丝。
    • 1个13.5 mm 三点螺丝
  4. MacBook Pro 13" Unibody 中期 2009 电池更换: 4 단계, 이미지 1/1
    • 使用撬棒扁平的一段来将电池的连接器从逻辑板的插座中分离开来。
  5. MacBook Pro 13" Unibody 中期 2009 电池更换: 5 단계, 이미지 1/1
    • 将电池从顶壳中移除。
결론
要重新组装您的设备,请按照本指南的相反顺序进行操作。
다른 727명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
en zh
85%
이 번역자 분들은 저희가 세상을 수리하는데 동참해 주시는 분입니다! 기여하시겠습니까?
번역 시작하기 ›
Walter Galan
694,692 평판
안내서 1,203개 작성하였습니다
댓글 50개
My laptop wouldn't believe the battery was new until I reset the SMC as well ( http://support.apple.com/kb/HT3964 ).
penguinofdeath - 답글
Perfect! I didn't want to wait for the Tri-wing screwdriver to ship, so I gave it a try by wedging a FH 1 in between two of the wings. It worked well to unscrew, but you must be very careful when resetting the screws that hold the battery. If you get them started with your finger (a little pressure with your thumb pushing straight down will get the job done) then you can do a few final turns with the FH 1. If you try to start resetting the screws with the off-center-FH1-workaround, you will strip the screw! Keep the screws centered and don't force anything.
Laurence Benson - 답글
worked like a charm. my old battery had bulged and made it so that the track pad would not click :-( replacing the battery did the trick.
statprof - 답글
My local Apple Store wants $179 plus tax to change this battery, AND I have to leave my laptop for "a couple of days." This is one store that clearly doesn't get it (Cherry Creak Mall, Denver). Thus, a DIY fix is mandatory... but, they won't sell just the battery.
channonholiday - 답글
iFixit sells the battery you need for $119 ([연계 제품이 누락 또는 비활성화 됨: IF163-019]), and once you get it, doing the replacement shouldn't take more than 30 minutes, even if you've never done a repair like this before.
Taylor Arnicar -
댓글 쓰기
조회 통계:
24 시간 전: 20
7일 전: 135
30일 전: 608
전체 시간: 572,273
