주요 콘텐츠로 건너뛰기
MacBook Pro 13" Unibody Early 2011 Logic Board Replacement
필요한 것
  1. MacBook Pro 13" Unibody Early 2011 Logic Board Replacement, Lower Case: 1 단계, 이미지 1개 중 1개
    • Remove the following ten screws:
    • Three 14.4 mm Phillips #00 screws
    • Three 3.5 mm Phillips #00 screws
    • Four 3.5 mm shouldered Phillips #00 screws
    • When replacing the small screws, align them perpendicular to the slight curvature of the case (they don't go straight down).
  2. MacBook Pro 13" Unibody Early 2011 Logic Board Replacement: 2 단계, 이미지 2개 중 1개 MacBook Pro 13" Unibody Early 2011 Logic Board Replacement: 2 단계, 이미지 2개 중 2개
    • Use your fingers to pry the lower case away from the body of the MacBook near the vent.
    • Remove the lower case.
  3. MacBook Pro 13" Unibody Early 2011 Logic Board Replacement, Battery Connection: 3 단계, 이미지 2개 중 1개 MacBook Pro 13" Unibody Early 2011 Logic Board Replacement, Battery Connection: 3 단계, 이미지 2개 중 2개
    • Use the edge of a spudger to pry the battery connector upwards from its socket on the logic board.
    • It is useful to pry upward on both short sides of the connector to "walk" it out of its socket. Be careful with the corners of the connectors, they can be easily broken off.
  4. MacBook Pro 13" Unibody Early 2011 Logic Board Replacement: 4 단계, 이미지 1개 중 1개
    • Bend the battery cable slightly away from its socket on the logic board so it does not accidentally connect itself while you work.
  5. MacBook Pro 13" Unibody Early 2011 Logic Board Replacement, Fan: 5 단계, 이미지 3개 중 1개 MacBook Pro 13" Unibody Early 2011 Logic Board Replacement, Fan: 5 단계, 이미지 3개 중 2개 MacBook Pro 13" Unibody Early 2011 Logic Board Replacement, Fan: 5 단계, 이미지 3개 중 3개
    • Use the edge of a spudger to gently pry the fan connector up and out of its socket on the logic board.
    • It is useful to twist the spudger axially from beneath the fan cable wires to release the connector.
    • The fan socket and the fan connector can be seen in the second and third pictures. Be careful not to break the plastic fan socket off the logic board as you use your spudger to lift the fan connector straight up and out of its socket. The layout of the logic board shown in the second picture may look slightly different than your machine but the fan socket is the same.
  6. MacBook Pro 13" Unibody Early 2011 Logic Board Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the following three screws securing the fan to the logic board:
    • One 7.2 mm T6 Torx screw
    • Two 5.3 mm T6 Torx screws
  7. MacBook Pro 13" Unibody Early 2011 Logic Board Replacement: 7 단계, 이미지 1개 중 1개
    • Lift the fan out of its recess in the logic board, minding its cable that may get caught.
  8. MacBook Pro 13" Unibody Early 2011 Logic Board Replacement, Logic Board: 8 단계, 이미지 2개 중 1개 MacBook Pro 13" Unibody Early 2011 Logic Board Replacement, Logic Board: 8 단계, 이미지 2개 중 2개
    • Use the tip of a spudger to pull the right speaker/subwoofer cable out from under the retaining finger molded into the upper case.
    • Pull the right speaker/subwoofer cable upward to lift the connector out of its socket on the logic board.
  9. MacBook Pro 13" Unibody Early 2011 Logic Board Replacement: 9 단계, 이미지 1개 중 1개
    • Disconnect the camera cable from the logic board.
    • The camera cable slides out from its logic board connector. If your cable feels fragile, use a spudger to walk the cable out from the metal tabs on each side of the connector head.
  10. MacBook Pro 13" Unibody Early 2011 Logic Board Replacement: 10 단계, 이미지 2개 중 1개 MacBook Pro 13" Unibody Early 2011 Logic Board Replacement: 10 단계, 이미지 2개 중 2개
    • Disconnect the following four cables:
    • AirPort/Bluetooth cable
    • Optical drive cable
    • Hard drive cable
    • Trackpad cable
    • To disconnect the cables, use the flat end of a spudger to pry their connectors up from the sockets on the logic board.
  11. MacBook Pro 13" Unibody Early 2011 Logic Board Replacement: 11 단계, 이미지 3개 중 1개 MacBook Pro 13" Unibody Early 2011 Logic Board Replacement: 11 단계, 이미지 3개 중 2개 MacBook Pro 13" Unibody Early 2011 Logic Board Replacement: 11 단계, 이미지 3개 중 3개
    • Use your fingernail to flip up the retaining flap on the keyboard ribbon cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap, not the socket itself.
    • Use the tip of a spudger to pull the keyboard ribbon cable out of its socket.
    • The cable may be difficult to insert. If you are having trouble, temporarily attach a piece of tape to the cable to help you guide the cable into the socket.
  12. MacBook Pro 13" Unibody Early 2011 Logic Board Replacement: 12 단계, 이미지 1개 중 1개
    • If present, remove the small strip of black tape covering the keyboard backlight cable socket.
  13. MacBook Pro 13" Unibody Early 2011 Logic Board Replacement: 13 단계, 이미지 3개 중 1개 MacBook Pro 13" Unibody Early 2011 Logic Board Replacement: 13 단계, 이미지 3개 중 2개 MacBook Pro 13" Unibody Early 2011 Logic Board Replacement: 13 단계, 이미지 3개 중 3개
    • Use the tip of a spudger or your fingernail to flip up the retaining flap on the keyboard backlight ribbon cable ZIF socket.
    • Pull the keyboard backlight ribbon cable out of its socket.
  14. MacBook Pro 13" Unibody Early 2011 Logic Board Replacement: 14 단계, 이미지 1개 중 1개
    • Use the flat end of a spudger to pry the sleep sensor/battery indicator connector up from its socket on the logic board.
  15. MacBook Pro 13" Unibody Early 2011 Logic Board Replacement: 15 단계, 이미지 3개 중 1개 MacBook Pro 13" Unibody Early 2011 Logic Board Replacement: 15 단계, 이미지 3개 중 2개 MacBook Pro 13" Unibody Early 2011 Logic Board Replacement: 15 단계, 이미지 3개 중 3개
    • Grab the plastic pull tab secured to the display data cable lock and rotate it toward the DC-In side of the computer.
    • Pull the display data cable straight out of its socket on the logic board.
    • Do not lift up on the display data cable, as its socket is very fragile. Pull the cable parallel to the face of the logic board.
  16. MacBook Pro 13" Unibody Early 2011 Logic Board Replacement: 16 단계, 이미지 1개 중 1개
    • Remove the following nine screws:
    • Five 3.6 mm T6 Torx screws
    • Two 4.3 mm T6 Torx screws
    • Two 7.2 mm T6 Torx screws
    • In some models the screws may be slightly shorter as follows:
    • Five 3.0 mm T6 screws
    • Two 3.6 mm T6 screws
    • Two 6.7 mm T6 screws
  17. MacBook Pro 13" Unibody Early 2011 Logic Board Replacement: 17 단계, 이미지 2개 중 1개 MacBook Pro 13" Unibody Early 2011 Logic Board Replacement: 17 단계, 이미지 2개 중 2개
    • Remove the following two screws:
    • One 8.6 mm Phillips screw
    • One 5.5 mm Phillips screw
    • Remove the display data cable retainer from the upper case.
  18. MacBook Pro 13" Unibody Early 2011 Logic Board Replacement: 18 단계, 이미지 1개 중 1개
    • Use the tip of a spudger to gently peel the microphone off the adhesive securing it to the upper case.
  19. MacBook Pro 13" Unibody Early 2011 Logic Board Replacement: 19 단계, 이미지 1개 중 1개
    • Minding the many connectors near its edges, lift the logic board from the end nearest the optical drive.
    • Without flexing the board, maneuver it out of the upper case, minding the flexible connection to the DC-In board that may get caught in the upper case.
    • Remove the logic board.
  20. MacBook Pro 13" Unibody Early 2011 Logic Board Replacement, Left Speaker: 20 단계, 이미지 1개 중 1개
    • De-route the microphone cable from its slot molded into the left speaker enclosure.
  21. MacBook Pro 13" Unibody Early 2011 Logic Board Replacement: 21 단계, 이미지 1개 중 1개
    • Remove the small piece of black tape covering the left speaker connector.
  22. MacBook Pro 13" Unibody Early 2011 Logic Board Replacement: 22 단계, 이미지 1개 중 1개
    • Use the flat end of a spudger to pry the left speaker connector up from its socket on the logic board.
    • Pry up from beneath the wires.
  23. MacBook Pro 13" Unibody Early 2011 Logic Board Replacement: 23 단계, 이미지 1개 중 1개
    • Carefully pry the left speaker off the foam adhesive securing it to the logic board.
    • Remove the left speaker.
  24. MacBook Pro 13" Unibody Early 2011 Logic Board Replacement, Logic Board: 24 단계, 이미지 1개 중 1개
    • Remove the piece of black tape covering the microphone connector.
  25. MacBook Pro 13" Unibody Early 2011 Logic Board Replacement: 25 단계, 이미지 1개 중 1개
    • Pull the microphone cable upward to lift its connector out of the socket on the logic board.
    • Remove the microphone.
  26. MacBook Pro 13" Unibody Early 2011 Logic Board Replacement: 26 단계, 이미지 1개 중 1개
    • Pull the MagSafe DC-In board cable toward the heat sink to disconnect it from the logic board.
    • Remove the DC-In board.
  27. MacBook Pro 13" Unibody Early 2011 Logic Board Replacement: 27 단계, 이미지 2개 중 1개 MacBook Pro 13" Unibody Early 2011 Logic Board Replacement: 27 단계, 이미지 2개 중 2개
    • Remove the three 8.4 mm #1 Phillips screws securing the heat sink to the logic board.
    • Don't lose the springs held under each of the screws.
    • Carefully remove the heat sink from the processor.
    • If the heat sink seems to be stuck, it may be helpful to gently pry it off the processor with a plastic spudger. Be careful not to break any surface mount components on the processor while prying.
    • Be sure to clean off the old thermal paste and apply a new layer before you reinstall the heat sink. We have a guide that makes it easy.
  28. MacBook Pro 13" Unibody Early 2011 Logic Board Replacement: 28 단계, 이미지 2개 중 1개 MacBook Pro 13" Unibody Early 2011 Logic Board Replacement: 28 단계, 이미지 2개 중 2개
    • Pull the two RAM retaining arms away from the center of the RAM chip.
    • The RAM chip should "pop" up slightly from its socket.
    • Pull the RAM stick out of its socket.
    • Repeat this process to remove the second RAM chip.
    • Logic board remains.
결론
다른 132명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Andrew Bookholt
592,087 평판
안내서 619개를 작성함
댓글 6개
My son spilled soda into 13"MB early 2011, I did not get to repair for 6 weeks. Machine took over twice typical time to start-up and once running, cursor showed stuttered movement and launching applications was very slow.
I used guide (only steps 1-19) to remove logic board and delicately cleaned with very slightly damp Q-Tip (using Windex electronics cleaner) & dried, every place I cleaned, using compressed air. I did not remove the heatsink, as I assumed the paste protected the processor underneath.
Once cleaned, I reversed all steps and it booted quickly and all other issues disappeared. THANK YOU!!!
mitchkirk - 답글
what is logic board part number if I want to order new one
QASEM ALHADIDI - 답글
For the Early 2011 MBP A1278 with the Core i5 2.3 GHz processor, the part numbers are 661-5869 and 661-6078
Susanna -
Do you send to Brazil the same Logic board above Its the Early 2011 MBP A1278 with the Core i5 2.3 GHz processo. It had many issues with it’s Logic boar and I think it’s a manufacture defect. I’m so desaposentes with apple planned Obsolescence, ando no repair. It’s not the same apple. My computer was boutique inAustralia , so I’m protected by their consumer act(2010) I just have to prove it was a hidden problem.
Maria carolina - 답글
My track pad was difficult to "click". I've replaced batteries before, so I knew that it was definitely a swollen battery. However, when removing the damaged, swollen battery, I used the end of a flat head screw driver to pry up the battery connection... DON'T DO THAT! I saw the tiniest of sparks around pins 4-5-6 on the 9 pin battery connector. New battery installed, but the OS didn't recognize the new battery -- black "X" over the battery indicator. Further, the wall charger would not recharge the new battery. Instead, the computer ran off the 30% charge that new batteries are shipped with. I ordered another new battery, and after draining a second battery without being able to charge, I figured that spark was the sign that I fried something in the logic board. Indeed that was exactly the case, and logic board replacement did fix the issue. I found these instructions INVALUABLE in replacing my old logic board.
$260 lesson: Always use a plastic spudger when dislodging connectors in computers!
Thanks!
Jake Ketchum - 답글
댓글 쓰기
조회 통계:
지난 24시간: 10
지난 7일: 50
지난 30일: 334
전체 시간: 213,470
