주요 콘텐츠로 건너뛰기
MacBook Pro 13" Unibody Mid 2009 Hard Drive Cable Replacement
필요한 것
  1. MacBook Pro 13" Unibody Mid 2009 Hard Drive Cable Replacement, Remove the lower case screws: 1 단계, 이미지 1개 중 1개
    • Remove the following 10 screws securing the lower case to the MacBook Pro 13" Unibody:
    • Seven 3 mm Phillips screws.
  2. MacBook Pro 13" Unibody Mid 2009 Hard Drive Cable Replacement, Lift the lower case away: 2 단계, 이미지 1개 중 1개
    • Slightly lift the lower case and push it toward the rear of the computer to free the mounting tabs.
  3. MacBook Pro 13" Unibody Mid 2009 Hard Drive Cable Replacement, Battery: 3 단계, 이미지 1개 중 1개
    • For precautionary purposes, we advise that you disconnect the battery connector from the logic board to avoid any electrical discharge.
    • Use the flat end of a spudger to lift the battery connector up out of its socket on the logic board.
  4. MacBook Pro 13" Unibody Mid 2009 Hard Drive Cable Replacement, Hard Drive: 4 단계, 이미지 1개 중 1개
    • Remove two Phillips screws securing the hard drive bracket to the upper case.
    • These screws are captive to the hard drive bracket.
  5. MacBook Pro 13" Unibody Mid 2009 Hard Drive Cable Replacement: 5 단계, 이미지 1개 중 1개
    • Lift the the retaining bracket out of the upper case.
  6. MacBook Pro 13" Unibody Mid 2009 Hard Drive Cable Replacement: 6 단계, 이미지 1개 중 1개
    • Lift the hard drive by its pull tab and pull it out of the chassis, minding the cable attaching it to the computer.
  7. MacBook Pro 13" Unibody Mid 2009 Hard Drive Cable Replacement: 7 단계, 이미지 1개 중 1개
    • Remove the hard drive cable by pulling its connector straight away from the hard drive.
  8. MacBook Pro 13" Unibody Mid 2009 Hard Drive Cable Replacement, Hard Drive Cable: 8 단계, 이미지 1개 중 1개
    • Remove the following four screws securing the hard drive and IR sensor cable to the upper case:
    • Two 1.5 mm Phillips screws.
    • Two 9.5 mm Phillips screws.
  9. MacBook Pro 13" Unibody Mid 2009 Hard Drive Cable Replacement: 9 단계, 이미지 2개 중 1개 MacBook Pro 13" Unibody Mid 2009 Hard Drive Cable Replacement: 9 단계, 이미지 2개 중 2개
    • Slide the hard drive and IR sensor bracket away from the edge of the upper case.
    • Carefully peel the hard drive and IR sensor cable from the upper case.
  10. MacBook Pro 13" Unibody Mid 2009 Hard Drive Cable Replacement: 10 단계, 이미지 1개 중 1개
    • Use the flat end of a spudger to pry the hard drive cable connector up off the logic board.
  11. MacBook Pro 13" Unibody Mid 2009 Hard Drive Cable Replacement: 11 단계, 이미지 1개 중 1개
    • Lift the hard drive/IR sensor cable assembly out of the upper case.
    • If your replacement part does not come with the hard drive bracket and indicator light, you will need to pull those off of the part you are removing and install them on the new part.
    • Your replacement part may come with several adhesive foam bumpers. These are to ensure a snug fit of both bracket and hard drive. Apply only as needed.
결론
다른 293명이 해당 안내서를 완성하였습니다.
작성자
9다른 기여자 명과 함께
Walter Galan
706,370 평판
안내서 1,203개를 작성함
7가이드 댓글
Used a Phillips #00 and a creditcard. It's an easy job, takes about 10 minutes. :)
sjoerdstra - 답글
In step #8 the two small screws were very tight in my computer. The Phillips #00 was too large and damaging the screws. I changed to a Phillips #000 applied substantial pressure and voila, the screws came off.
Reassembly: placing the IR sensor cable (the one you"peeled off" in step #9) is a bit tricky. Start from the side opposite the IR sensor (the side with the two small screws of step 8) and press first along the short vertical side and then across towards the IR section. There should be a little left for a vertical section at the IR sensor end.
bgrinstein - 답글
Very Easy and clearly written instructions
omar - 답글
Can you illustrate how to attach the gold strip cable?
Rene - 답글
if i change the HDD cable and get the same results what could be the the real problem , because the original problem as we all know was the we were getting the question mark on the white screen .
Curtis O'brien - 답글
댓글 쓰기
조회 통계:
지난 24시간: 11
지난 7일: 57
지난 30일: 237
전체 시간: 167,299
