주요 콘텐츠로 건너뛰기
MacBook Pro 13" Unibody Mid 2009 Logic Board Replacement
단지 전제 조건
이 가이드는 전제 조건 전용 가이드입니다! 이 가이드는 다른 절차의 일부이며 단독으로 사용할 수 없습니다.
필요한 것
  1. MacBook Pro 13" Unibody Mid 2009 Logic Board Replacement, Logic Board: 1 단계, 이미지 3개 중 1개 MacBook Pro 13" Unibody Mid 2009 Logic Board Replacement, Logic Board: 1 단계, 이미지 3개 중 2개 MacBook Pro 13" Unibody Mid 2009 Logic Board Replacement, Logic Board: 1 단계, 이미지 3개 중 3개
    • Grab the plastic pull tab secured to the display data cable lock, and rotate it toward the DC-in side of the computer.
    • Pull the display data cable connector straight away from its socket, towards the DC-in side of the computer.
  2. MacBook Pro 13" Unibody Mid 2009 Logic Board Replacement: 2 단계, 이미지 2개 중 1개 MacBook Pro 13" Unibody Mid 2009 Logic Board Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the following two screws securing the display data cable bracket to the upper case:
    • One 7 mm Phillips.
    • One 5 mm Phillips.
    • Lift the display data cable bracket out of the upper case.
  3. MacBook Pro 13" Unibody Mid 2009 Logic Board Replacement: 3 단계, 이미지 1개 중 1개
    • Use the flat end of a spudger to pry the subwoofer and right speaker connector up off the logic board.
  4. MacBook Pro 13" Unibody Mid 2009 Logic Board Replacement: 4 단계, 이미지 1개 중 1개
    • In this step you will disconnect the camera cable. Most machines will have a small self adhesive plastic retainer stuck to the logic board to keep the connector in place. Before disconnecting the cable, be sure this retainer is moved out of the way.
    • Pull the camera cable connector toward the optical drive to disconnect it from the logic board.
    • This socket is metal and easily bent. Be sure to align the connector with its socket on the logic board before mating the two pieces.
  5. MacBook Pro 13" Unibody Mid 2009 Logic Board Replacement: 5 단계, 이미지 3개 중 1개 MacBook Pro 13" Unibody Mid 2009 Logic Board Replacement: 5 단계, 이미지 3개 중 2개 MacBook Pro 13" Unibody Mid 2009 Logic Board Replacement: 5 단계, 이미지 3개 중 3개
    • Use the flat end of a spudger to pry the optical drive, hard drive, and trackpad cable connectors up off the logic board.
  6. MacBook Pro 13" Unibody Mid 2009 Logic Board Replacement: 6 단계, 이미지 3개 중 1개 MacBook Pro 13" Unibody Mid 2009 Logic Board Replacement: 6 단계, 이미지 3개 중 2개 MacBook Pro 13" Unibody Mid 2009 Logic Board Replacement: 6 단계, 이미지 3개 중 3개
    • Use your fingernail or the tip of a spudger to flip up the cable retaining flap on the ZIF socket for the keyboard ribbon cable.
    • Use your spudger to slide the keyboard ribbon cable out of its socket.
  7. MacBook Pro 13" Unibody Mid 2009 Logic Board Replacement: 7 단계, 이미지 1개 중 1개
    • Peel the small strip of black tape off the keyboard backlight ribbon cable socket.
  8. MacBook Pro 13" Unibody Mid 2009 Logic Board Replacement: 8 단계, 이미지 3개 중 1개 MacBook Pro 13" Unibody Mid 2009 Logic Board Replacement: 8 단계, 이미지 3개 중 2개 MacBook Pro 13" Unibody Mid 2009 Logic Board Replacement: 8 단계, 이미지 3개 중 3개
    • Use the tip of a spudger to flip up the cable retaining flap on the ZIF socket for the keyboard backlight ribbon cable.
    • Use your spudger to slide the keyboard backlight ribbon cable out of its socket.
  9. MacBook Pro 13" Unibody Mid 2009 Logic Board Replacement: 9 단계, 이미지 1개 중 1개
    • Use the flat end of a spudger to pry the battery indicator cable connector up off the logic board.
  10. MacBook Pro 13" Unibody Mid 2009 Logic Board Replacement: 10 단계, 이미지 1개 중 1개
    • Use the tip of a spudger to pry the microphone off the adhesive attaching it to the upper case.
  11. MacBook Pro 13" Unibody Mid 2009 Logic Board Replacement: 11 단계, 이미지 1개 중 1개
    • Remove the following screws:
    • Five 3.1 mm Phillips.
    • Two 3.9 mm Phillips.
    • Two 7 mm Phillips from the DC-in board.
  12. MacBook Pro 13" Unibody Mid 2009 Logic Board Replacement: 12 단계, 이미지 2개 중 1개 MacBook Pro 13" Unibody Mid 2009 Logic Board Replacement: 12 단계, 이미지 2개 중 2개
    • Remove the following Tri-point screws securing the battery to the upper case:
    • One 5.5 mm Tri-point screw.
    • One 13.5 mm Tri-point screw.
    • Lift the battery out of the upper case.
  13. MacBook Pro 13" Unibody Mid 2009 Logic Board Replacement: 13 단계, 이미지 2개 중 1개 MacBook Pro 13" Unibody Mid 2009 Logic Board Replacement: 13 단계, 이미지 2개 중 2개
    • Lift the logic board from its left edge and raise it until the ports clear the side of the upper case.
    • Pull the logic board away from the side of the upper case and remove it, minding the DC-in board that may get caught.
    • Be careful not to rip out the fragile connector plug of the microphone assembly.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
10다른 기여자 명과 함께
Walter Galan
706,370 평판
안내서 1,203개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 8
전체 시간: 5,603
