소개
This guide will help you replace the logic board.
도구
Remove the following ten screws:
Three 14.4 mm Phillips #00 screws
Three 3.5 mm Phillips #00 screws
Four 3.5 mm shouldered Phillips #00 screws
Use the edge of a spudger to pry the battery connector upwards from its socket on the logic board.
Use the tip of a spudger to pull the right speaker/subwoofer cable out from under the retaining finger molded into the upper case.
Pull the right speaker/subwoofer cable upward to lift the connector out of its socket on the logic board.
De-route the microphone cable from its slot molded into the left speaker enclosure.
다른 188명이 해당 안내서를 완성하였습니다.
댓글 23개
I decided to take out the logic board because I had a water problem. As you can problably guess all the componentes from both sides of the board, near the ventilation, were dirty with some green and white stuff so I cleand it all up with isopropilic alcohol. I assembeled it buck up and it turns on but it doesnt run the osx, screen doesnt turn on, you cant hear the welcome sound every time you turn on a mac and the only thing you can hear is the fan spinning faster and faster until it reaches its top speed and it stays like that. what can I do to fix it??
Three years later, the answer is that you need to reset your SMC.
ROBOLOBO -
is it possible to assemble the laptop completely without the unibody enclosure?
Yes you can, but it would be unsafe for the macbook
Ryan -
My macbook is not suspended when under the screen... help me
