주요 콘텐츠로 건너뛰기
MacBook Pro 15 "Unibody de finales de 2008 y principios de 2009 a mediados de reemplazo de pared
필요한 것
  1. MacBook Pro 15 "Unibody de finales de 2008 y principios de 2009 a mediados de reemplazo de pared, Puerta de acceso: 1 단계, 이미지 1/2 MacBook Pro 15 "Unibody de finales de 2008 y principios de 2009 a mediados de reemplazo de pared, Puerta de acceso: 1 단계, 이미지 2/2
    • Con el estuche cerrado, coloca el Unibody boca arriba sobre una superficie plana.
    • Presiona el lado ranurado del pestillo de liberación de la puerta de acceso lo suficiente para agarrar el extremo libre. Levanta el pestillo de liberación hasta que quede vertical.
    The A1286 has no Access Door.!!
    I actually can see no sign of the battery!...
    aguib - 답글
    aguib로 부터 인용:
    I assume you have the newer model, with the built-in battery. It's still removable with tools, but these are the wrong instructions for that model.
    lgc90 - 답글
    when will there be a guide for the other unibody macbook pro. that does not have an access door?
    irishking - 답글
    Is there a manual to show, how disasembly the display, i mean, after step 5, to check the display between lcd and aluminiun back case?
    Max
    Max - 답글
    On other guides you state the height of the HD that can be supported, e.g. MacBook Pro 15" Core 2 Duo Model A1211 Hard Drive Replacement , I have read ( but have not confirmed ) that the uni-body MacBook Pro can be fitted with the 750GB and 1TB 12mm drive from Western Digital.
    Can you confirm this?
    Many thanks in advance.
    ahothabeth - 답글
    SHerwood Ball로 부터 인용:
    My display and aluminum casing has separated.
    I don't know if it just snaps back together or does it need to be glued.
    I dropped mine on the carpeted stairs and the display still works.
    I'm hoping I can just snap it back together and that no plastic pieces or teeth of the snapping
    portion have been broken........
    SHerwood Ball - 답글
    When you say "left fan" is this "left when looking at the logic board after turning the computer over and looking it up opening it up" or "left when sitting at the computer keyboard and typing on it"?
    thvv - 답글
    We always use left and right in reference to the computer when you're using it.
    Andrew Optimus Goldheart -
    Directions were great and the worn dc in board was replaced. The hardest part of the procedure is disconnecting the data display cable. A better description of step 21 is to slide the connector parallel to the circuit board towards the outside corner. Reconnecting correctly took several tries.
    I used the tip of the spudger to nudge the corners a little at a time to seat the connector.
    The ribbon connector for the keyboard has to be inserted all the way before seating the retaining cap. It took me three tries . First try power button did not work second try numbers keys did not work.
    Thanks for the directions ...could not have done it with out them!!!
    landryd - 답글
    Hola. Poseo un MacBook Pro Late 2008 y debo cambiarle las cornetas. Me sirve unas cornetas de un MBP Late 2011?
    jegonzalez80 - 답글
    Please read the instructions about removing the bluetooth cable - you CAN work around it, and NOT take off the plug.
    kenneth krabat - 답글
  2. MacBook Pro 15 "Unibody de finales de 2008 y principios de 2009 a mediados de reemplazo de pared: 2 단계, 이미지 1/1
    • La puerta de acceso ahora debe estar lo suficientemente levantada para levantarla y sacarla del Unibody.
  3. MacBook Pro 15 "Unibody de finales de 2008 y principios de 2009 a mediados de reemplazo de pared, Battery: 3 단계, 이미지 1/1
    • Asegúrate de que el pestillo de liberación de la puerta de acceso esté vertical antes de continuar.
    • Agarra la lengüeta de plástico translúcido y extrae la batería de la Unibody.
    • Si se presiona el pestillo, se bloqueará la batería en su lugar.
    Do I need to wait for the battery to charge completely before using the computer (while plugged in)?
    Kaila Potts - 답글
    No. You do not need to charge it completely before removing it.
    Titus (#1579) - 답글
  4. MacBook Pro 15 "Unibody de finales de 2008 y principios de 2009 a mediados de reemplazo de pared, Case inferior: 4 단계, 이미지 1/1
    • Retira los siguientes ocho tornillos que sujetan la carcasa inferior al chasis:
    • Un tornillo Phillips de 5.4 mm.
    • Tres tornillos Phillips de 14 mm.
    • Cuatro tornillos Phillips de 3.5 mm.
    Hi, My name is Jess I need help asap I accidentally dropped my macbook Pro and i cant find the silver screw for the top left back side, Does any one know if I can replace it with an eye glass screw?? If you can help at all Please e-mail me at Chambliss_jess@yahoo.com thx please help me my bf is going off... ;(
    Jess - 답글
    The fixit PH00 is the wrong screw driver for this entire job. It did not fit in the screws, it was too pointy and caused screws to be rounded off.
    mattrittgers - 답글
  5. MacBook Pro 15 "Unibody de finales de 2008 y principios de 2009 a mediados de reemplazo de pared: 5 단계, 이미지 1/1
    • Usando ambas manos, levanta y retira la caja inferior de la caja superior.
    About midway along each edge is a snap. To release each snap, gently slide the flat edge of a Spudger under the lower case, then lift the lower case away.
    jonathansturges - 답글
  6. MacBook Pro 15 "Unibody de finales de 2008 y principios de 2009 a mediados de reemplazo de pared, Pared media: 6 단계, 이미지 1/1
    • Retira los siguientes 5 tornillos que sujetan la pared intermedia a la caja superior:
    • Tres tornillos Phillips de 10.5 mm.
    • Dos tornillos Phillips de 3.7 mm.
  7. MacBook Pro 15 "Unibody de finales de 2008 y principios de 2009 a mediados de reemplazo de pared: 7 단계, 이미지 1/1
    • Levanta la pared media de la caja superior.
결론
Para volver a ensamblar tu dispositivo, sigue estas instrucciones en orden inverso.
다른 3명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
en es
100%
이 번역자 분들은 저희가 세상을 수리하는데 동참해 주시는 분입니다! 기여하시겠습니까?
번역 시작하기 ›
Walter Galan
694,692 평판
안내서 1,203개 작성하였습니다
댓글 한 개
Anyone know what size screws hold the black rubber battery pads on either side of the trackpad?
They are Phillips head, but I can’t find the size in any of the guides for the MacBookPro5,1 — Help?
Mitch - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 13
전체 시간: 20,589
