이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Use your fingers to push both battery release tabs away from the battery, and lift the battery out of the computer.
다른 80명이 해당 안내서를 완성하였습니다.
댓글 3개
Help! After installing new battery, one of the tabs does not close totally, leaving a bit or orange showing, and mouse pad is hardly operational. Cannot seem to get it to install completely. Put old battery back in to double check and its fine. Tried new battery 3 times to no avail!! Any tips?? Thank you!
Mmm, I think in two options:
1. The new battery has some imperfections and don´t met the official dimensions.
2. If the new battery is used, had an overheat and that caused a variation in its dimensions.
Sorry if I can´t help you more
This has to be the easiest iFixit tutorial ever! Haha
