소개
Removing a few screws will remove this part and allow access to your RAM.
필요한 것
Use your fingers to push both battery release tabs away from the battery, and lift the battery out of the computer.
Remove the three identical 2mm Phillips screws from the memory door.
Lift the memory door up enough to grip it and slide it toward you, pulling it away from the casing.
거의 끝나갑니다!
결론
다른 20명이 해당 안내서를 완성하였습니다.
