주요 콘텐츠로 건너뛰기
MacBook Pro 15" Retina Display Mid 2014 AirPort Board Replacement
필요한 것
  1. MacBook Pro 15" Retina Display Mid 2014 AirPort Board Replacement, Lower Case: 1 단계, 이미지 1/1
    • Remove the following P5 pentalobe screws securing the lower case to the MacBook Pro:
    • Eight 3.0 mm
    • Two 2.3 mm
  2. MacBook Pro 15" Retina Display Mid 2014 AirPort Board Replacement: 2 단계, 이미지 1/1
    • Lifting from the edge nearest the clutch cover, lift the lower case off the MacBook Pro.
    • Set the lower case aside.
  3. MacBook Pro 15" Retina Display Mid 2014 AirPort Board Replacement, Battery Connector: 3 단계, 이미지 1/1
    • Peel back the warning label covering the battery connector.
  4. MacBook Pro 15" Retina Display Mid 2014 AirPort Board Replacement: 4 단계, 이미지 1/2 MacBook Pro 15" Retina Display Mid 2014 AirPort Board Replacement: 4 단계, 이미지 2/2
    • Using the flat end of a spudger, gently pry the battery connector straight up out of its socket on the logic board.
    • Bend the battery cables back and out of the way, ensuring that the battery connector doesn't accidentally make contact with the logic board.
  5. MacBook Pro 15" Retina Display Mid 2014 AirPort Board Replacement, AirPort Board: 5 단계, 이미지 1/1
    • Use the tip of a spudger to detach the three antenna connectors up from their sockets on the AirPort board.
  6. MacBook Pro 15" Retina Display Mid 2014 AirPort Board Replacement: 6 단계, 이미지 1/2 MacBook Pro 15" Retina Display Mid 2014 AirPort Board Replacement: 6 단계, 이미지 2/2
    • Remove the single 2.9 mm T5 Torx screw securing the AirPort board to the logic board.
    • Grasp the edges of the board and slide it out from its connector.
    • Lift and remove the AirPort board.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Walter Galan
684,330 평판
안내서 1,203개 작성하였습니다
0 Comments
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 28
30일 전: 122
전체 시간: 21,414
