주요 콘텐츠로 건너뛰기
MacBook Pro 15" Retina Display Mid 2014 Lower Case Replacement
필요한 것
  1. MacBook Pro 15" Retina Display Mid 2014 Lower Case Replacement, Lower Case: 1 단계, 이미지 1개 중 1개
    • Remove the following P5 pentalobe screws securing the lower case to the MacBook Pro:
    • Eight 3.0 mm
    • Two 2.3 mm
  2. MacBook Pro 15" Retina Display Mid 2014 Lower Case Replacement: 2 단계, 이미지 1개 중 1개
    • Lifting from the edge nearest the clutch cover, lift the lower case off the MacBook Pro.
    • Set the lower case aside.
결론
다른 19명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Walter Galan
706,370 평판
안내서 1,203개를 작성함
1가이드 댓글
Walter, please, change this guide's difficulty from moderate to easy :D
It's really that simple.
P.S. You've really saved me. I opened it by myself but then noticed that screws were different size. Oh, I always remember iFixit and opened it cuz I was sure that I'll find smth here. Many thanks!
Jizo - 답글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 23
지난 30일: 123
전체 시간: 31,427
