소개
Use this guide to replace the right fan.
필요한 것
Remove the following P5 pentalobe screws securing the lower case to the MacBook Pro:
Eight 3.0 mm
Two 2.3 mm
Use a spudger or tweezers to pry the three AirPort antenna cables straight up off of their sockets on the AirPort board.
Using the flat end of a spudger, pry the I/O Board connector straight up out of its socket on the logic board.
In a similar fashion, remove the I/O Board cable connector from its socket on the I/O Board.
Remove the I/O Board cable from the MacBook Pro.
Remove the single 2.9 mm T5 (sometimes T6) Torx screw securing the AirPort card to the logic board.
다른 12명이 해당 안내서를 완성하였습니다.
4 Comments
The killer info in this is which way the connectors come out. It's not that apparent when you are looking at them. Using this guide I cleaned the dust out of both fans which should make my mac run cooler. I'm also trying to figure out why my base is all bowed out.
My base did the exact same thing >:( did you find any solution?
sorry I didn’t see this sooner. Yes the batteries had bulged. I wound up taking it in on the last day (very lucky) of apple care and they took care of it. Had to replace the entire top of the computer
What is the serial number for the fan? Is it the same fan as in earlier models?
