주요 콘텐츠로 건너뛰기
MacBook Pro 15" Retina Display Mid 2014 SSD Replacement
필요한 것
  1. MacBook Pro 15" Retina Display Mid 2014 SSD Replacement, Lower Case: 1 단계, 이미지 1개 중 1개
    • Remove the following P5 pentalobe screws securing the lower case to the MacBook Pro:
    • Eight 3.0 mm
    • Two 2.3 mm
  2. MacBook Pro 15" Retina Display Mid 2014 SSD Replacement: 2 단계, 이미지 1개 중 1개
    • Lifting from the edge nearest the clutch cover, lift the lower case off the MacBook Pro.
    • Set the lower case aside.
  3. MacBook Pro 15" Retina Display Mid 2014 SSD Replacement, Battery Connector: 3 단계, 이미지 1개 중 1개
    • Peel back the warning label covering the battery connector.
  4. MacBook Pro 15" Retina Display Mid 2014 SSD Replacement: 4 단계, 이미지 2개 중 1개 MacBook Pro 15" Retina Display Mid 2014 SSD Replacement: 4 단계, 이미지 2개 중 2개
    • Using the flat end of a spudger, gently pry the battery connector straight up out of its socket on the logic board.
    • Bend the battery cables back and out of the way, ensuring that the battery connector doesn't accidentally make contact with the logic board.
  5. MacBook Pro 15" Retina Display Mid 2014 SSD Replacement, SSD: 5 단계, 이미지 1개 중 1개
    • Remove the single 3.1 mm T5 Torx screw securing the SSD to the logic board.
  6. MacBook Pro 15" Retina Display Mid 2014 SSD Replacement: 6 단계, 이미지 2개 중 1개 MacBook Pro 15" Retina Display Mid 2014 SSD Replacement: 6 단계, 이미지 2개 중 2개
    • Slightly lift the rightmost side of the SSD and firmly slide it straight away out of its socket on the logic board.
결론
다른 147명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Walter Galan
706,370 평판
안내서 1,203개를 작성함
35가이드 댓글
What about adding a 2nd SSD to this machine? Is that possible? Thanks!
Kim - 답글
I am also wondering the same. Is there a second SSD drive bay?
Greg Bennett -
if i bought the 1TB SSD Im not sure how you clone everything to it before it is installed?
badboy - 답글
Is it possible to install 1TB SSD? What brand should I buy? Or characteristics? Please help me.
JjCruz -
You can use a program such as Carbon Copy Cloner to 'clone' your drive from one to another.
jeffsolano -
댓글 쓰기
조회 통계:
지난 24시간: 28
지난 7일: 160
지난 30일: 1,156
전체 시간: 303,988
