소개
Replacing the MagSafe DC-In board requires removal of the logic board.
Remove the following ten screws securing the lower case to the upper case:
Three 13.5 mm (14.1 mm) Phillips screws.
Seven 3 mm Phillips screws.
Use the edge of a spudger to pry the battery connector upwards from its socket on the logic board.
Use the flat end of a spudger to lift the right fan connector out of its socket on the logic board.
Carefully lift the logic board assembly from its left side and work it out of the upper case, minding the optical drive cable and the I/O ports that may get caught during removal.
If necessary, use the flat end of a spudger to separate the microphone from the upper case.
Pull the I/O port side of the logic board away from the side of the upper case and remove the logic board assembly.
다른 54명이 해당 안내서를 완성하였습니다.
댓글 4개
Hello , my Mac book pro. 2011 has been shut down by itself after a spark in charger what could be the problem it is please explain it.
you have shorted your battery and possibly burnt the board
Hello , before using this tuto, i want to be sure…
My MBP 15 early 2011 2Ghz, works fine with AC adapter, the thing is the batterie don’t works ?
Changing DC inboard could change this ? Or it must be batterie totaly down and nothing else?
Thanks for your reply
Tony
