이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
하단 케이스를 상단 케이스에 고정하는 다음 나사 열 개를 풀어주세요:
13.5mm (14.1mm) Phillips/십자 나사 세 개.
3mm Phillips/십자 나사 일곱 개
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Disconnect the camera cable connector from its socket on the logic board.
Use the flat end of a spudger to pry the AirPort/Bluetooth connector up from its socket on the logic board.
Use the flat end of a spudger to pry the optical drive connector up from its socket on the logic board.
Remove following two screws:
One 8.6 mm Phillips screw
One 3.9 mm Phillips screw
Carefully rotate the AirPort/Bluetooth board housing (with AirPort/Antenna cables still attached) out of the lower case.
Remove the three 3.5 mm T6 Torx screws securing the optical drive to the upper case.
Lift the optical drive near its connector and pull it away from the upper case to remove it from the computer.
Pull the optical drive cable out of the optical drive.
Remove the two black Phillips #0 screws securing the small metal mounting bracket. Transfer this bracket to your new optical drive or hard drive enclosure.
다른 52명이 해당 안내서를 완성하였습니다.
댓글 7개
Many thanks for this superb resource. My 4 year old had actually shoved a couple of coins into the drive. I would never have had the guts to replace it myself without your help - by far the best on the web!
For anyone who has stripped a screw in step 8 this note might make your day. I stripped the longer screw using a #00 bit. I then took a 1.5mm flat head bit from the iFixit screwdriver kit and rocked it along the line of the flat head into the stripped screw head, with some pressure a few times and that created enough of a depression to easily remove the screw. There was even enough purchase to reinstall it securely so no need to hunt down a replacement screw.
I'd need to know where I could find the connector between the optical drive and the logicboard. I put my hdd in a caddie to put it instead of the optical drive but my macbook keep disconnecting it. Already changed the caddie so I guess that the connector is faulty.
Anyone ? :)
Found it ! But iFixit you should put a link to the other tutorial when you mention the connector in step 11 :D
Right as rain! The comments were especially helpful, although so many stories about stripping screws had me concerned..but I used pressure, care, and voila… success without heartache! I made a template to keep track of the screws and it was very helpful. I did note my mounting bracket was held on by Phillips #00…reattaching was the hardest part, but that could have to do with the fact that I am a disabled Vietnam Vet (yeah, do the math). Thank you so much.
Pete Banks - 답글
