주요 콘텐츠로 건너뛰기
MacBook Pro 15" Unibody Late 2008 and Early 2009 AirPort/iSight Cable Replacement
필요한 것
  1. MacBook Pro 15" Unibody Late 2008 and Early 2009 AirPort/iSight Cable Replacement, Access Door: 1 단계, 이미지 1/2 MacBook Pro 15" Unibody Late 2008 and Early 2009 AirPort/iSight Cable Replacement, Access Door: 1 단계, 이미지 2/2
    • With the case closed, place the Unibody top-side down on a flat surface.
    • Depress the grooved side of the access door release latch enough to grab the free end. Lift the release latch until it is vertical.
  2. MacBook Pro 15" Unibody Late 2008 and Early 2009 AirPort/iSight Cable Replacement: 2 단계, 이미지 1/1
    • The access door should now be raised enough to lift it up and out of the Unibody.
  3. MacBook Pro 15" Unibody Late 2008 and Early 2009 AirPort/iSight Cable Replacement, Battery: 3 단계, 이미지 1/1
    • Be sure the access door release latch is vertical before proceeding.
    • Grab the translucent plastic tab and pull the battery up and out of the Unibody.
    • If the latch is depressed it will lock the battery in place.
  4. MacBook Pro 15" Unibody Late 2008 and Early 2009 AirPort/iSight Cable Replacement, Lower Case: 4 단계, 이미지 1/1
    • Remove the following eight screws securing the lower case to the chassis:
    • One 5.4 mm Phillips screw.
    • Three 14 mm Phillips screws.
    • Four 3.5 mm Phillips screws.
  5. MacBook Pro 15" Unibody Late 2008 and Early 2009 AirPort/iSight Cable Replacement: 5 단계, 이미지 1/1
    • Using both hands, lift and remove the lower case off the upper case.
  6. MacBook Pro 15" Unibody Late 2008 and Early 2009 AirPort/iSight Cable Replacement, Display Assembly: 6 단계, 이미지 1/2 MacBook Pro 15" Unibody Late 2008 and Early 2009 AirPort/iSight Cable Replacement, Display Assembly: 6 단계, 이미지 2/2
    • If necessary, peel the EMI gasket off the camera cable connector.
    • Disconnect the camera cable by pulling the male end straight away from its socket toward the optical drive opening.
    • Do not try to lift this connector straight up off the board. Pull the connector parallel to the face of the logic board.
    • Deroute the camera data cable from the channel in the optical drive.
  7. MacBook Pro 15" Unibody Late 2008 and Early 2009 AirPort/iSight Cable Replacement: 7 단계, 이미지 1/2 MacBook Pro 15" Unibody Late 2008 and Early 2009 AirPort/iSight Cable Replacement: 7 단계, 이미지 2/2
    • Remove the two Phillips screws securing the camera cable bracket to the upper case.
    • The leftmost screw may remain captive in the camera cable.
    • Seperate the camera cable bracket from the camera cable and remove it from the computer.
  8. MacBook Pro 15" Unibody Late 2008 and Early 2009 AirPort/iSight Cable Replacement: 8 단계, 이미지 1/2 MacBook Pro 15" Unibody Late 2008 and Early 2009 AirPort/iSight Cable Replacement: 8 단계, 이미지 2/2
    • Grab the plastic pull tab secured to the LVDS cable lock and rotate it toward the DC-in side of the computer.
    • Pull the LVDS connector straight away from its socket.
    • When disconnecting the LVDS cable, do not pull on the black tab secured to the LVDS cable lock. We recommend wiggling the cable while applying tension to slowly "walk" the connector out of its socket.
  9. MacBook Pro 15" Unibody Late 2008 and Early 2009 AirPort/iSight Cable Replacement: 9 단계, 이미지 1/2 MacBook Pro 15" Unibody Late 2008 and Early 2009 AirPort/iSight Cable Replacement: 9 단계, 이미지 2/2
    • Remove the 7 mm Phillips screw from the LVDS cable bracket.
    • This screw may remain captive in the LVDS cable.
    • Lift the LVDS cable bracket out of the upper case.
  10. MacBook Pro 15" Unibody Late 2008 and Early 2009 AirPort/iSight Cable Replacement: 10 단계, 이미지 1/1
    • Remove the two outer 6 mm Torx screws securing each side of the display to the upper case (four screws total).
  11. MacBook Pro 15" Unibody Late 2008 and Early 2009 AirPort/iSight Cable Replacement: 11 단계, 이미지 1/1
    • Open your MacBook Pro so the display is perpendicular to the upper case.
    • Place your opened MacBook Pro on a table as pictured.
    • While holding the display and upper case together with your other hand, remove the 6 mm Torx screw from the lower display bracket.
  12. MacBook Pro 15" Unibody Late 2008 and Early 2009 AirPort/iSight Cable Replacement: 12 단계, 이미지 1/1
    • Be sure to hold the display and upper case together with your other hand. Failure to do so may cause the freed display/upper case to fall, potentially damaging each component.
    • Remove the last remaining 6 mm Torx screw securing the display to the upper case.
  13. MacBook Pro 15" Unibody Late 2008 and Early 2009 AirPort/iSight Cable Replacement: 13 단계, 이미지 1/3 MacBook Pro 15" Unibody Late 2008 and Early 2009 AirPort/iSight Cable Replacement: 13 단계, 이미지 2/3 MacBook Pro 15" Unibody Late 2008 and Early 2009 AirPort/iSight Cable Replacement: 13 단계, 이미지 3/3
    • Grab the upper case with your right hand and rotate it slightly toward the top of the display so the upper display bracket clears the edge of the upper case.
    • Rotate the display slightly away from the upper case.
    • Lift the display away from the upper case, minding any brackets or cables that may get caught.
  14. MacBook Pro 15" Unibody Late 2008 and Early 2009 AirPort/iSight Cable Replacement, Front Display Glass: 14 단계, 이미지 1/2 MacBook Pro 15" Unibody Late 2008 and Early 2009 AirPort/iSight Cable Replacement, Front Display Glass: 14 단계, 이미지 2/2
    • In the following steps, you will use a heat gun to soften the adhesive securing the outer black border around the underside of the front glass panel to the display. The area the adhesive is applied to is shown in red in the second picture.
    • Before starting, be sure to clean the display glass with lint-free cloth moistened with a mild solution; it will make the suction cup adhere better, and will make checking for dust on reassembly easier
    • With the heat gun set to low, start by heating the outer black border near the upper right corner of the glass panel.
    • Always aim the heat gun away from the soft rubber strip around the display glass. Heating the rubber will cause it to melt slightly, turning its finish from matte to glossy. Touching overheated rubber can cause it to permanently deform.
    • Due to the heat applied, it is normal for a layer of condensation to develop on the inside of the glass panel and/or the outside of the LCD. It can be removed with glass cleaner once the glass is separated from the display.
  15. MacBook Pro 15" Unibody Late 2008 and Early 2009 AirPort/iSight Cable Replacement: 15 단계, 이미지 1/3 MacBook Pro 15" Unibody Late 2008 and Early 2009 AirPort/iSight Cable Replacement: 15 단계, 이미지 2/3 MacBook Pro 15" Unibody Late 2008 and Early 2009 AirPort/iSight Cable Replacement: 15 단계, 이미지 3/3
    이 단계에 사용된 도구:
    Heavy-Duty Suction Cups (Pair)
    $14.95
    구매
    • With the panel sufficiently heated, fasten a heavy-duty suction cup near the upper right corner of the display glass.
    • Don't fasten the suction cup on top of the rubber strip around the edge of the display glass.
    • To attach the suction cups we sell, first position the suction cup with the movable handle parallel to the face of the glass panel. While lightly holding the suction cup against the glass, raise the movable handle until it is parallel with the other handle.
    • Slowly and gently pull the corner of the display glass up off the display assembly.
    • If only the top edge of the glass lifts up (as seen in the third picture), repeat steps one and two until you can lift up the corner of the panel.
  16. MacBook Pro 15" Unibody Late 2008 and Early 2009 AirPort/iSight Cable Replacement: 16 단계, 이미지 1/3 MacBook Pro 15" Unibody Late 2008 and Early 2009 AirPort/iSight Cable Replacement: 16 단계, 이미지 2/3 MacBook Pro 15" Unibody Late 2008 and Early 2009 AirPort/iSight Cable Replacement: 16 단계, 이미지 3/3
    • Gently lift the corner of the display glass enough to insert a spudger between it and the display assembly.
    • Use the flat end of a spudger to gently pry up the adhesive securing the front glass to the display.
    • Pry up the glass panel a few inches away from the upper right corner along the top and right edges of the display.
  17. MacBook Pro 15" Unibody Late 2008 and Early 2009 AirPort/iSight Cable Replacement: 17 단계, 이미지 1/2 MacBook Pro 15" Unibody Late 2008 and Early 2009 AirPort/iSight Cable Replacement: 17 단계, 이미지 2/2
    • Use a heat gun to soften the adhesive under the black strip along the right side of the front glass panel.
    • Attach a suction cup along the right side of the front glass panel.
    • Pull up on the glass panel while you use the flat end of a spudger to separate it from the rest of the display assembly.
    • Continue working along the right edge of the front display glass until it is separated from the display.
    • It may be helpful to use a guitar pick or another thin plastic object to keep the upper right corner of the front glass panel from sticking back down to the display assembly.
  18. MacBook Pro 15" Unibody Late 2008 and Early 2009 AirPort/iSight Cable Replacement: 18 단계, 이미지 1/2 MacBook Pro 15" Unibody Late 2008 and Early 2009 AirPort/iSight Cable Replacement: 18 단계, 이미지 2/2
    • Use your heat gun to soften the adhesive under the black strip along the top edge of the glass display panel.
    • Attach a suction cup near the top edge of the glass display panel and use it to pull the glass panel up off the display.
    • Work along the top edge of the glass panel, carefully using the flat end of a spudger to separate the adhesive if necessary.
  19. MacBook Pro 15" Unibody Late 2008 and Early 2009 AirPort/iSight Cable Replacement: 19 단계, 이미지 1/2 MacBook Pro 15" Unibody Late 2008 and Early 2009 AirPort/iSight Cable Replacement: 19 단계, 이미지 2/2
    • Use a heat gun to soften the adhesive under the black strip near the upper left corner of the glass display panel.
    • Attach a suction cup near the upper left corner of the glass display panel.
    • Pull up on the suction cup and use the flat end of a spudger to carefully pry the glass display panel out of the display assembly.
    • Once the upper left corner has been separated from the display, it may be helpful to use a guitar pick or another thin plastic object to keep the glass from sticking back down to the display assembly.
  20. MacBook Pro 15" Unibody Late 2008 and Early 2009 AirPort/iSight Cable Replacement: 20 단계, 이미지 1/2 MacBook Pro 15" Unibody Late 2008 and Early 2009 AirPort/iSight Cable Replacement: 20 단계, 이미지 2/2
    • Use a heat gun to soften the adhesive under the black strip along the left side of the front glass panel.
    • Attach a suction cup along the left side of the front glass panel.
    • Continue working along the left edge of the front display glass until it is separated from the display.
  21. MacBook Pro 15" Unibody Late 2008 and Early 2009 AirPort/iSight Cable Replacement: 21 단계, 이미지 1/2 MacBook Pro 15" Unibody Late 2008 and Early 2009 AirPort/iSight Cable Replacement: 21 단계, 이미지 2/2
    • Now that the top, left, and right edges of the glass are free from the display, slowly lift the top edge of the glass panel and gently rotate it out of the display.
    • If necessary, use the flat end of a spudger to free the bottom edge of the glass display panel from the display assembly.
    • Before reassembling, be sure to clean both the inside of the glass display panel and the LCD as any dust or fingerprints trapped inside will be annoyingly visible when the machine is on.
  22. MacBook Pro 15" Unibody Late 2008 and Early 2009 AirPort/iSight Cable Replacement: 22 단계, 이미지 1/2 MacBook Pro 15" Unibody Late 2008 and Early 2009 AirPort/iSight Cable Replacement: 22 단계, 이미지 2/2
    • Insert the edge of a plastic opening tool between the display glass and the camera bracket, and run it around the camera bracket to separate it from the display glass.
    • Do not forget to stick the camera bracket down to the new front display glass before reassembly.
  23. MacBook Pro 15" Unibody Late 2008 and Early 2009 AirPort/iSight Cable Replacement: 23 단계, 이미지 1/3 MacBook Pro 15" Unibody Late 2008 and Early 2009 AirPort/iSight Cable Replacement: 23 단계, 이미지 2/3 MacBook Pro 15" Unibody Late 2008 and Early 2009 AirPort/iSight Cable Replacement: 23 단계, 이미지 3/3
    • During the glass removal process, the camera cable may stick to the adhesive on the glass panel, disconnecting it from the camera board as the panel is lifted. If your camera cable is still connected to the camera board, skip this step.
    • To reconnect the cable, first use the tip of a spudger to remove the piece of foam tape over the camera cable ZIF socket.
    • Use the tip of a spudger to flip up the ZIF cable retainer on the camera cable socket.
    • Insert the camera cable into its socket on the camera board and use the tip of a spudger to snap down the ZIF cable retainer, locking the cable in place.
    • Reapply the piece of tape covering the camera cable socket.
  24. MacBook Pro 15" Unibody Late 2008 and Early 2009 AirPort/iSight Cable Replacement, LCD: 24 단계, 이미지 1/2 MacBook Pro 15" Unibody Late 2008 and Early 2009 AirPort/iSight Cable Replacement, LCD: 24 단계, 이미지 2/2
    • Slide the clutch cover toward the right edge of the display.
    • The clutch cover will move approximately .25" and stop. Do not force it too far to the right.
    • When reinstalling the clutch cover, be sure to slip it over the components protruding from the lower edge of the display about .25" to the right of its final installed position on the display.
  25. MacBook Pro 15" Unibody Late 2008 and Early 2009 AirPort/iSight Cable Replacement: 25 단계, 이미지 1/2 MacBook Pro 15" Unibody Late 2008 and Early 2009 AirPort/iSight Cable Replacement: 25 단계, 이미지 2/2
    • Starting at its far left end, rock the clutch cover along its long axis while pulling it away from the clutch hinge.
    • Working from right to left, carefully continue to release and lift the clutch along the lower edge of the display assembly.
    • Lift the clutch cover up off the front bezel and set it aside.
    • When reinstalling the clutch cover, be sure to widen the opening when slipping it over the small black plastic cosmetic cover that fills the open end of the clutch cover when it is in place. The cosmetic cover has very thin and delicate plastic arms that hold it to the right clutch hinge.
  26. MacBook Pro 15" Unibody Late 2008 and Early 2009 AirPort/iSight Cable Replacement: 26 단계, 이미지 1/1
    • Remove the six 2.9 mm Phillips screws securing the LCD panel to the front bezel.
  27. MacBook Pro 15" Unibody Late 2008 and Early 2009 AirPort/iSight Cable Replacement: 27 단계, 이미지 1/1
    • Pull the LCD toward the top edge of the display to slide the circuitry along its lower edge out of the recess in the aluminum display assembly.
    • It may be helpful to use one hand to feed the display data cable through its channel in the aluminum display assembly as you pull the LCD toward the top edge of the display with the other hand.
  28. MacBook Pro 15" Unibody Late 2008 and Early 2009 AirPort/iSight Cable Replacement: 28 단계, 이미지 1/1
    • Peel the piece of tape covering the display data cable connector away from the edge closest to the LCD.
  29. MacBook Pro 15" Unibody Late 2008 and Early 2009 AirPort/iSight Cable Replacement: 29 단계, 이미지 1/2 MacBook Pro 15" Unibody Late 2008 and Early 2009 AirPort/iSight Cable Replacement: 29 단계, 이미지 2/2
    • Use the tip of a spudger to flip up the thin steel retaining clip securing the display data cable to its socket on the LCD.
    • Pull the display data cable straight away from its socket on the LCD.
    • Lift the LCD out of the display assembly and set it aside.
    • If you are replacing the LVDS/display data cable, simply de-route it from its slot cut into the display casing.
  30. MacBook Pro 15" Unibody Late 2008 and Early 2009 AirPort/iSight Cable Replacement, AirPort/iSight Cable: 30 단계, 이미지 1/1
    • Remove the 2.2 mm Phillips screw located near the bottom right corner securing the AirPort/iSight cable to the display assembly
  31. MacBook Pro 15" Unibody Late 2008 and Early 2009 AirPort/iSight Cable Replacement: 31 단계, 이미지 1/2 MacBook Pro 15" Unibody Late 2008 and Early 2009 AirPort/iSight Cable Replacement: 31 단계, 이미지 2/2
    • Remove the single 2.9 mm Phillips screw securing the plastic tab covering right edge of the inverter board.
    • Lift and remove the plastic tab up off the inverter board.
  32. MacBook Pro 15" Unibody Late 2008 and Early 2009 AirPort/iSight Cable Replacement: 32 단계, 이미지 1/2 MacBook Pro 15" Unibody Late 2008 and Early 2009 AirPort/iSight Cable Replacement: 32 단계, 이미지 2/2
    • Use the tip of a spudger to flip up the retaining flap on the iSight ribbon cable ZIF socket on the iSight board.
    • Be sure you are prying up on the hinged retaining flap, not the socket itself.
    • Use the tip of a spudger to pull the iSight ribbon cable out of its socket.
  33. MacBook Pro 15" Unibody Late 2008 and Early 2009 AirPort/iSight Cable Replacement: 33 단계, 이미지 1/2 MacBook Pro 15" Unibody Late 2008 and Early 2009 AirPort/iSight Cable Replacement: 33 단계, 이미지 2/2
    • Use the tip of a spudger to push the AirPort cable retaining lock away from its socket on the AirPort board.
    • Pull the AirPort cable straight out of its socket on the AirPort board.
    • Do not lift up on the AirPort cable, as its socket is very fragile. Pull the cable parallel to the face of the AirPort board.
  34. MacBook Pro 15" Unibody Late 2008 and Early 2009 AirPort/iSight Cable Replacement: 34 단계, 이미지 1/2 MacBook Pro 15" Unibody Late 2008 and Early 2009 AirPort/iSight Cable Replacement: 34 단계, 이미지 2/2
    • De-route the iSight ribbon cable from its channel near the top right corner of the display assembly.
    • Continue de-routing the AirPort/iSight cable from the right side of the display assembly.
  35. MacBook Pro 15" Unibody Late 2008 and Early 2009 AirPort/iSight Cable Replacement: 35 단계, 이미지 1/1
    • Carefully pull half of the AirPort/iSight cable through the opening located underneath the right hinge.
    • Do not pull the AirPort/iSight cable completely through the opening. The right hinge prevents the cable from complete removal. Forcing the cable through the opening may cause severe damage to your AirPort/iSight cable.
  36. MacBook Pro 15" Unibody Late 2008 and Early 2009 AirPort/iSight Cable Replacement: 36 단계, 이미지 1/3 MacBook Pro 15" Unibody Late 2008 and Early 2009 AirPort/iSight Cable Replacement: 36 단계, 이미지 2/3 MacBook Pro 15" Unibody Late 2008 and Early 2009 AirPort/iSight Cable Replacement: 36 단계, 이미지 3/3
    • Remove three 2.5 mm T6 Torx screws securing the right hinge to the display assembly.
    • Remove the right hinge up off the display assembly.
  37. MacBook Pro 15" Unibody Late 2008 and Early 2009 AirPort/iSight Cable Replacement: 37 단계, 이미지 1/1
    • Pull the AirPort/iSight cable through the opening located near the bottom right corner of the display assembly.
    • Remove the AirPort/iSight cable from the display assembly.
결론
다른 12명이 해당 안내서를 완성하였습니다.
Walter Galan
694,692 평판
안내서 1,203개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 14
전체 시간: 15,053
