주요 콘텐츠로 건너뛰기
MacBook Pro 15" Unibody Late 2011 Feet Replacement
필요한 것
  1. MacBook Pro 15" Unibody Late 2011 Feet Replacement, Lower Case: 1 단계, 이미지 1/1
    • Three 13.5 mm (14.1 mm) Phillips screws.
    • Seven 3 mm Phillips screws.
    • When removing these screws, note how they come out at a slight angle. They must be reinstalled the same way.
  2. MacBook Pro 15" Unibody Late 2011 Feet Replacement: 2 단계, 이미지 1/1
    • Using both hands, lift the lower case near the vent to pop it off two clips securing it to the upper case.
  3. MacBook Pro 15" Unibody Late 2011 Feet Replacement, Feet: 3 단계, 이미지 1/3 MacBook Pro 15" Unibody Late 2011 Feet Replacement, Feet: 3 단계, 이미지 2/3 MacBook Pro 15" Unibody Late 2011 Feet Replacement, Feet: 3 단계, 이미지 3/3
    • Remove any broken or damaged feet.
    • Remove any pieces from the old foot that may have broken off in the foot hole.
    • Use tweezers to peel up and remove the old adhesive tape from the foot pad.
  4. MacBook Pro 15" Unibody Late 2011 Feet Replacement: 4 단계, 이미지 1/1
    • Scrub the foot pad with adhesive remover to remove any remaining adhesive.
  5. MacBook Pro 15" Unibody Late 2011 Feet Replacement: 5 단계, 이미지 1/1
    • Wipe the foot pad with an alcohol prep pad to remove any residue left by the cleaner.
  6. MacBook Pro 15" Unibody Late 2011 Feet Replacement: 6 단계, 이미지 1/1
    • Peel a replacement foot from the plastic backing.
  7. MacBook Pro 15" Unibody Late 2011 Feet Replacement: 7 단계, 이미지 1/3 MacBook Pro 15" Unibody Late 2011 Feet Replacement: 7 단계, 이미지 2/3 MacBook Pro 15" Unibody Late 2011 Feet Replacement: 7 단계, 이미지 3/3
    • Align the new foot inside the foot pad.
    • Make sure the alignment nub on the foot is lined up with the small hole near the perimeter of the pad.
    • Lay the foot down while keeping it properly aligned.
    • Check for proper alignment from the inside of the lower case. Use tweezers to slide the alignment nub so it lines up with the hole.
  8. MacBook Pro 15" Unibody Late 2011 Feet Replacement: 8 단계, 이미지 1/1
    • Press the new foot down firmly with your finger and maintain pressure for 30 seconds to set the pressure sensitive adhesive. Support the other side of the cover while you press the foot down.
    • Repeat the last six steps for any broken or damaged feet.
결론
다른 10명이 해당 안내서를 완성하였습니다.
Arthur Shi
회원 가입일: 01/03/18
221,564 평판
안내서 441개 작성하였습니다
iFixit iFixit 회원
Community
141 회원들
안내서 17,643개 작성하였습니다
0 댓글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 15
전체 시간: 1,413
