이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
하단 케이스를 상단 케이스에 고정하는 다음 나사 열 개를 풀어주세요:
3mm Phillips/십자 나사 일곱 개
13.5mm Phillips/십자 나사 세 개
이 단계에 사용된 도구:P6 Pentalobe Screwdriver 2009 15" MacBook Pro Battery$5.49
배터리 상단 가장자리에서 5-점 Pentalobe/펜타로브/별 나사 두 개를 분리하세요.
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Use the tip of a spudger to rotate the plastic retainer away from the camera cable connector.
Peel the camera cable off the adhesive securing it to the body of the optical drive.
Disconnect the Bluetooth cable by pulling the male end straight away from its socket.
Use the flat end of a spudger to pry the Bluetooth antenna cable up from its socket on the board.
Remove the two 8 mm Phillips screws securing the Bluetooth/camera cable retainer to the upper case.
Lift the Bluetooth board/cable retainer assembly out of the upper case.
Remove the two 8 mm Phillips screws securing the camera cable retainer to the upper case.
Lift the camera cable retainer out of the upper case.
Grab the plastic pull tab secured to the display data cable lock and rotate it toward the DC-In side of the computer.
Remove the single 7 mm Phillips screw securing the display data cable retainer to the upper case.
Remove the display data cable retainer from the upper case.
Remove the outer two T6 Torx screws securing both display hinges to the upper case (four screws total).
Open your MacBook Pro so the display is perpendicular to the upper case.
Place your opened MacBook Pro on a table as pictured.
While holding the display and upper case together with your left hand, remove the remaining T6 Torx screw from the lower display bracket.
Remove the last remaining T6 Torx screw securing the display to the upper case.
Grab the upper case with your right hand and rotate it slightly toward the top of the display so the upper display bracket clears the edge of the upper case.
Rotate the display slightly away from the upper case.
Lift the display up and away from the upper case, minding any brackets or cables that may get caught.
다른 43명이 해당 안내서를 완성하였습니다.
