주요 콘텐츠로 건너뛰기
MacBook Pro 15" Unibody Mid 2010 Optical Drive Replacement
단지 전제 조건
이 안내서는 다른 가이드의 선행 작업으로 사용하기 위한 것입니다. 그 자체로는 불완전합니다.
필요한 것
  1. MacBook Pro 15" Unibody Mid 2010 Optical Drive Replacement, Optical Drive: 1 단계, 이미지 1/1
    • Use the flat end of a spudger to pry the AirPort/Bluetooth ribbon cable connector up off the logic board.
  2. MacBook Pro 15" Unibody Mid 2010 Optical Drive Replacement: 2 단계, 이미지 1/1
    • Disconnect the camera cable by pulling its connector away from the socket (toward the optical drive) on the logic board.
  3. MacBook Pro 15" Unibody Mid 2010 Optical Drive Replacement: 3 단계, 이미지 1/1
    • Use the flat end of a spudger to pry the optical drive connector up off the logic board.
  4. MacBook Pro 15" Unibody Mid 2010 Optical Drive Replacement: 4 단계, 이미지 1/2 MacBook Pro 15" Unibody Mid 2010 Optical Drive Replacement: 4 단계, 이미지 2/2
    • Remove the two Phillips screws securing the AirPort/Bluetooth board housing.
    • Carefully rotate the AirPort/Bluetooth board housing (with AirPort/Antenna cables still attached) out of the lower case.
  5. MacBook Pro 15" Unibody Mid 2010 Optical Drive Replacement: 5 단계, 이미지 1/1
    • Remove the following three Phillips screws securing the optical drive to the upper case:
    • One 4.5 mm Phillips screw securing the optical drive bracket to the upper case near the fan.
    • Two 2.5 mm Phillips screws securing the optical drive to the upper case near the optical drive opening.
  6. MacBook Pro 15" Unibody Mid 2010 Optical Drive Replacement: 6 단계, 이미지 1/1
    • Lift the optical drive near its connector and pull it away from the upper case to remove it from the computer.
결론
Walter Galan
694,877 평판
안내서 1,203개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 13
전체 시간: 969
