소개
Use this guide to replace the entire display assembly on your MacBook Pro, in order to fix a cracked or faulty screen. This assembly also includes the integrated ribbon cables for the display and backlight.
Although we’ve successfully tested this procedure using original Apple replacement displays, Apple’s T2 chip may prevent aftermarket displays from working correctly, and your MacBook Pro may not boot as a result.
For your safety, discharge your MacBook Pro's battery below 25% before you begin. A charged lithium-ion battery can create a dangerous and uncontrollable fire if accidentally punctured.
필요한 것
Power on your Mac and launch Terminal.
Copy and paste the following command (or type it exactly) into Terminal:
sudo nvram AutoBoot=%00
Press [return]. If prompted, enter your administrator password and press [return] again. Note: Your return key may also be labeled ⏎ or "enter."
sudo nvram AutoBoot=%03
Use a P5 Pentalobe driver to remove six screws securing the lower case, of the following lengths:
Four 3.7 mm screws
Two 7.3 mm screws
Press a suction handle into place near the front edge of the lower case, between the screw holes.
Pull up on the suction handle just enough to open a small gap under the lower case.
Remove the lower case.
Set it in place and align the sliding clips near the display hinge. Press down and slide the cover toward the hinge. It should stop sliding as the clips engage.
When the sliding clips are fully engaged and the lower case looks correctly aligned, press down firmly on the lower case to engage the four hidden clips underneath. You should feel and hear them snap into place.
Peel up and remove the insulating sticker covering the battery board, on the edge of the logic board nearest the battery.
If the cover doesn't peel up easily, apply mild heat with an iOpener, hair dryer, or heat gun to soften the adhesive underneath, and try again.
Use a spudger to gently pry up the locking flap on the ZIF connector for the battery board data cable.
Slide the battery board data cable out of its socket on the battery board, and remove it completely.
Use a T5 Torx driver to remove the 6.7 mm pancake screw securing the battery power connector.
Use a T3 Torx driver to remove the two 3.5 mm screws securing the cover on the display board flex cable.
Remove the display board flex cover.
Use a T3 Torx driver to remove the four 2.0 mm screws from the hinge covers (two screws on each side).
Use a T5 Torx driver to remove the single 2.9 mm screw securing the antenna cable bundle.
Use a T5 Torx driver to remove the four 3.3 mm screws securing the display board.
Make sure the display board flex cable lies on top of the board, not trapped underneath.
Use a P2 Pentalobe driver to remove the sixteen 1.5 mm screws securing the antenna assembly (eight on each side).
Use a T3 Torx driver to remove the four 3.9 mm screws securing the display cable cover springs.
Use a T8 Torx driver to remove two 5.0 mm screws from each hinge (four screws total).
Using a T3 Torx driver, remove the two 1.5 mm screws securing the cover bracket for the Touch Bar digitizer and lid angle sensor connectors.
Use a P2 Pentalobe driver to remove the 1.9 mm-long screw securing the lid angle sensor.
Use tweezers, or your fingers, to pull the lid angle sensor up from the frame and release it from its metal peg.
Remove the lid angle sensor.
If you plan to re-use your screen, open it and apply a piece of tape to the glass directly above each hinge. This helps protect the glass from getting scratched in the following step.
Fully open the screen and stand your MacBook Pro up on one side.
Use a T8 Torx driver to remove the two remaining 5.0 mm hinge screws (one from each hinge).
Remove the topmost screw last, using one hand to steady both halves of the MacBook Pro to make sure they don't separate and fall over unexpectedly.
Push both halves of the MacBook Pro together so that the hinges can be lifted clear of their recesses in the chassis.
Push the main body of the MacBook Pro away from you while pulling the screen toward you to separate it.
다른 43명이 해당 안내서를 완성하였습니다.
댓글 21개
Anybody know the screen part# or where to find it?
Ou est ce qu’on trouve l’écran ?
Is it possible to boot up the machine without the screen attached (and use external displays only)?
yes USBC to HDMI
jim -
