주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
MacBook Pro 16" 2021 Trackpad Replacement
단지 전제 조건
이 가이드는 전제 조건만을 다룹니다! 이 가이드는 다른 절차의 일부이며 단독으로 사용할 수 없습니다.
필요한 것
  1. MacBook Pro 16" 2021 Trackpad Replacement, Unfasten the trackpad: 1 단계, 이미지 2개 중 1개 MacBook Pro 16" 2021 Trackpad Replacement, Unfasten the trackpad: 1 단계, 이미지 2개 중 2개
    • Use a T5 Torx driver to remove the 13 screws securing the trackpad assembly:
    • Ten 5 mm screws
    • Three 5.8 mm screws
    • These screws all look similar—be careful not to mix them up.
    • Adding a little blue threadlocker to the screw threads during reassembly can help prevent the screws from working themselves loose over time.
    • Install the screws loosely at first, and then check the trackpad alignment before tightening them down.
  2. MacBook Pro 16" 2021 Trackpad Replacement, Remove the trackpad: 2 단계, 이미지 3개 중 1개 MacBook Pro 16" 2021 Trackpad Replacement, Remove the trackpad: 2 단계, 이미지 3개 중 2개 MacBook Pro 16" 2021 Trackpad Replacement, Remove the trackpad: 2 단계, 이미지 3개 중 3개
    • Swing the display open slightly, but keep the MacBook upside-down. The trackpad assembly should separate and lay flat on the display.
    • Carefully feed the trackpad's ribbon cable through its slot in the frame.
  3. MacBook Pro 16" 2021 Trackpad Replacement: 3 단계, 이미지 3개 중 1개 MacBook Pro 16" 2021 Trackpad Replacement: 3 단계, 이미지 3개 중 2개 MacBook Pro 16" 2021 Trackpad Replacement: 3 단계, 이미지 3개 중 3개
    • As you remove the trackpad assembly, be very careful not to lose the nine small metal washers resting on the screw posts. (They will fly off and get lost with very little provocation.)
    • Remove the trackpad assembly.
결론
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our MacBook Pro 16" 2021 Answers community for help.
Alex Diaz-Kokaisl
회원 가입일: 01/16/22
220,389 평판
안내서 1,066개를 작성함
iFixit iFixit 회원
Staff
124 회원들
안내서 24,166개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 14
전체 시간: 120
