주요 콘텐츠로 건너뛰기
MacBook Pro 16" 2023 Trackpad Replacement
필요한 것
  1. MacBook Pro 16" 2023 Trackpad Replacement, Prepare your MacBook for disassembly: 1 단계, 이미지 3개 중 1개 MacBook Pro 16" 2023 Trackpad Replacement, Prepare your MacBook for disassembly: 1 단계, 이미지 3개 중 2개 MacBook Pro 16" 2023 Trackpad Replacement, Prepare your MacBook for disassembly: 1 단계, 이미지 3개 중 3개
    • Allow your MacBook's battery to drain below 10% before starting this repair. A charged battery may catch fire if damaged during the repair.
    • Fully shut down your MacBook, close the lid, and flip it over. Keep the lid closed until you've physically disconnected the battery.
    • Unplug the MagSafe cable and any accessories connected to your MacBook.
  2. MacBook Pro 16" 2023 Trackpad Replacement, Unfasten the lower case: 2 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    FixMat
    $36.95
    • Use a P5 pentalobe driver to remove the eight screws securing the lower case:
    • Four 9.1 mm‑long screws
    • Four 6 mm‑long screws
  3. MacBook Pro 16" 2023 Trackpad Replacement, Insert an opening pick: 3 단계, 이미지 3개 중 1개 MacBook Pro 16" 2023 Trackpad Replacement, Insert an opening pick: 3 단계, 이미지 3개 중 2개 MacBook Pro 16" 2023 Trackpad Replacement, Insert an opening pick: 3 단계, 이미지 3개 중 3개
    • Apply a suction handle to the center of the lower case's front edge.
    • Pull up on the suction handle to create a gap between the lower case and the frame.
    • Insert an opening pick into the gap.
  4. MacBook Pro 16" 2023 Trackpad Replacement, Release the right clips: 4 단계, 이미지 3개 중 1개 MacBook Pro 16" 2023 Trackpad Replacement, Release the right clips: 4 단계, 이미지 3개 중 2개 MacBook Pro 16" 2023 Trackpad Replacement, Release the right clips: 4 단계, 이미지 3개 중 3개
    • Slide your opening pick around the bottom right corner and up the right edge of the lower case.
    • If your pick gets stuck at the cutout, use your fingers to lift the lower case up slightly to allow your pick to slide underneath.
    • Slide your pick until it reaches the middle of the cutout, or until the rightmost clip stops it from sliding.
    • Twist your pick to release the two right clips.
    • You'll hear and feel a pop when each of the two clips releases.
  5. MacBook Pro 16" 2023 Trackpad Replacement, Release the left clips: 5 단계, 이미지 3개 중 1개 MacBook Pro 16" 2023 Trackpad Replacement, Release the left clips: 5 단계, 이미지 3개 중 2개 MacBook Pro 16" 2023 Trackpad Replacement, Release the left clips: 5 단계, 이미지 3개 중 3개
    • Slide your opening pick around the bottom left corner and up the left edge of the lower case.
    • If your pick gets stuck at the cutout, pry the lower case up slightly to allow your pick to slide underneath.
    • Slide your pick until it reaches the middle of the cutout, or until the leftmost clip stops it from sliding.
    • Twist your pick to release the left two clips.
  6. MacBook Pro 16" 2023 Trackpad Replacement, Release the sliding clips: 6 단계, 이미지 3개 중 1개 MacBook Pro 16" 2023 Trackpad Replacement, Release the sliding clips: 6 단계, 이미지 3개 중 2개 MacBook Pro 16" 2023 Trackpad Replacement, Release the sliding clips: 6 단계, 이미지 3개 중 3개
    • Sliding clips along the back edge of the MacBook further secure the lower case. Separating these clips may require a lot of force—consider using gloves to protect your hands from the sharp edges of the lower case.
    • Firmly pull the lower case away from the back edge, one corner at a time, to disengage the sliding clips.
    • Keep the lower case flat to the MacBook. Don't pull upward until it's completely separated.
  7. MacBook Pro 16" 2023 Trackpad Replacement, Remove the lower case: 7 단계, 이미지 2개 중 1개 MacBook Pro 16" 2023 Trackpad Replacement, Remove the lower case: 7 단계, 이미지 2개 중 2개
    • Remove the lower case.
    • To reinstall the lower case:
    • Lay it down and align the sliding clips with the back edge of the MacBook. Press down on the lower case and slide it toward the back edge to engage the clips.
    • When one side is engaged, it may push the other out of alignment. Check both sides as you push.
    • Once the back corners of the lower case are secured and flush with the frame, press down along the middle of the lower case to engage the four remaining clips.
    • You'll hear and feel each clip snap into place.
  8. MacBook Pro 16" 2023 Trackpad Replacement, Remove the trackpad cable bracket: 8 단계, 이미지 3개 중 1개 MacBook Pro 16" 2023 Trackpad Replacement, Remove the trackpad cable bracket: 8 단계, 이미지 3개 중 2개 MacBook Pro 16" 2023 Trackpad Replacement, Remove the trackpad cable bracket: 8 단계, 이미지 3개 중 3개
    • Use a 3IP Torx Plus driver to remove the two 2.1 mm screws securing the trackpad cable bracket.
    • Remove the bracket.
  9. MacBook Pro 16" 2023 Trackpad Replacement, Disconnect the trackpad: 9 단계, 이미지 2개 중 1개 MacBook Pro 16" 2023 Trackpad Replacement, Disconnect the trackpad: 9 단계, 이미지 2개 중 2개
    • Use the flat end of your spudger to pry up and disconnect the trackpad cable press connector from the logic board.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down in the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
  10. MacBook Pro 16" 2023 Trackpad Replacement, Move the trackpad cable: 10 단계, 이미지 3개 중 1개 MacBook Pro 16" 2023 Trackpad Replacement, Move the trackpad cable: 10 단계, 이미지 3개 중 2개 MacBook Pro 16" 2023 Trackpad Replacement, Move the trackpad cable: 10 단계, 이미지 3개 중 3개
    • The trackpad cable is lightly adhered to the battery board.
    • Peel the trackpad cable from the battery board.
    • Move the cable over the front edge of the MacBook.
    • Be careful not to crease the cable.
  11. MacBook Pro 16" 2023 Trackpad Replacement, Uncover the battery data cable connector: 11 단계, 이미지 2개 중 1개 MacBook Pro 16" 2023 Trackpad Replacement, Uncover the battery data cable connector: 11 단계, 이미지 2개 중 2개
    • Peel back the tape covering the battery data cable connector on the logic board.
  12. MacBook Pro 16" 2023 Trackpad Replacement, Unlatch the connector: 12 단계, 이미지 2개 중 1개 MacBook Pro 16" 2023 Trackpad Replacement, Unlatch the connector: 12 단계, 이미지 2개 중 2개
    • Use the point of a spudger or a clean fingernail to flip up the small locking flap on the battery data cable ZIF connector.
  13. MacBook Pro 16" 2023 Trackpad Replacement, Disconnect the battery data cable: 13 단계, 이미지 3개 중 1개 MacBook Pro 16" 2023 Trackpad Replacement, Disconnect the battery data cable: 13 단계, 이미지 3개 중 2개 MacBook Pro 16" 2023 Trackpad Replacement, Disconnect the battery data cable: 13 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Slide one arm of your blunt nose tweezers under the battery data cable.
    • Grip the cable just below the head of the connector.
    • Slide the connector straight out of its socket.
  14. MacBook Pro 16" 2023 Trackpad Replacement, Uncover the connector: 14 단계, 이미지 2개 중 1개 MacBook Pro 16" 2023 Trackpad Replacement, Uncover the connector: 14 단계, 이미지 2개 중 2개
    • Peel back the tape covering the battery data cable connector on the battery board.
  15. MacBook Pro 16" 2023 Trackpad Replacement, Disconnect the battery data cable: 15 단계, 이미지 3개 중 1개 MacBook Pro 16" 2023 Trackpad Replacement, Disconnect the battery data cable: 15 단계, 이미지 3개 중 2개 MacBook Pro 16" 2023 Trackpad Replacement, Disconnect the battery data cable: 15 단계, 이미지 3개 중 3개
    • Use the point of your spudger or a clean fingernail to flip up the small locking flap on the battery data cable ZIF connector.
    • Use blunt nose tweezers to grab the battery data cable just under the head of the connector and slide it straight out of its socket.
  16. MacBook Pro 16" 2023 Trackpad Replacement, Remove the battery data cable: 16 단계, 이미지 3개 중 1개 MacBook Pro 16" 2023 Trackpad Replacement, Remove the battery data cable: 16 단계, 이미지 3개 중 2개 MacBook Pro 16" 2023 Trackpad Replacement, Remove the battery data cable: 16 단계, 이미지 3개 중 3개
    • The battery data cable is adhered to the battery board and logic board.
    • Peel the cable from the battery board and the logic board.
    • Remove the cable.
  17. MacBook Pro 16" 2023 Trackpad Replacement, Unfasten the battery connector: 17 단계, 이미지 1개 중 1개
    • Use a T5 Torx driver to remove the 3.9 mm pancake screw securing the battery connector.
  18. MacBook Pro 16" 2023 Trackpad Replacement, Disconnect the battery: 18 단계, 이미지 3개 중 1개 MacBook Pro 16" 2023 Trackpad Replacement, Disconnect the battery: 18 단계, 이미지 3개 중 2개 MacBook Pro 16" 2023 Trackpad Replacement, Disconnect the battery: 18 단계, 이미지 3개 중 3개
    • Use the flat end of your spudger to lift the battery connector away from the battery board, disconnecting the battery.
    • Lift the connector high enough that it doesn't accidentally make contact during the repair, but no more than 45 degrees to prevent damaging its hinge.
    • For added safety, place a barrier, such as a piece of a playing card, between the connector and board.
  19. MacBook Pro 16" 2023 Trackpad Replacement, Unfasten the trackpad: 19 단계, 이미지 2개 중 1개 MacBook Pro 16" 2023 Trackpad Replacement, Unfasten the trackpad: 19 단계, 이미지 2개 중 2개
    • Use your T5 Torx driver to remove the 13 screws securing the trackpad:
    • Ten 5 mm screws
    • Three 5.8 mm screws
    • During reassembly, center the trackpad in the frame before fully tightening the screws.
  20. MacBook Pro 16" 2023 Trackpad Replacement, Remove the trackpad: 20 단계, 이미지 3개 중 1개 MacBook Pro 16" 2023 Trackpad Replacement, Remove the trackpad: 20 단계, 이미지 3개 중 2개 MacBook Pro 16" 2023 Trackpad Replacement, Remove the trackpad: 20 단계, 이미지 3개 중 3개
    • Open your MacBook slowly. The trackpad will remain on the screen.
    • Be careful not to lose the nine washers from their screw posts on the trackpad. Without them, your trackpad won't fit properly.
    • Guide the trackpad cable through its slot in the frame.
  21. MacBook Pro 16" 2023 Trackpad Replacement: 21 단계, 이미지 3개 중 1개 MacBook Pro 16" 2023 Trackpad Replacement: 21 단계, 이미지 3개 중 2개 MacBook Pro 16" 2023 Trackpad Replacement: 21 단계, 이미지 3개 중 3개
    • Remove the trackpad.
    • Make sure your new trackpad has a ribbon cable installed before reassembly. If necessary, transfer the old cable, or install the one your new trackpad came with.
    • Before installing your trackpad, make sure all nine washers are in place:
    • Four rectangular washers
    • Five circular washers
결론
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
작성자
3다른 기여자 명과 함께
Clay Eickemeyer
회원 가입일: 09/19/22
95,641 평판
안내서 466개를 작성함
Guide Team Guide Team 회원
Staff
10 회원들
안내서 15,803개를 작성함
1가이드 댓글
Where to buy the trackpad replacement part?
LT3 - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 15
지난 30일: 56
전체 시간: 1,468
