주요 콘텐츠로 건너뛰기
MacBook Pro 17" Unibody Feet Replacement
필요한 것
  1. MacBook Pro 17" Unibody Feet Replacement, Lower Case: 1 단계, 이미지 1개 중 1개
    • Seven 3 mm Phillips screws.
  2. MacBook Pro 17" Unibody Feet Replacement: 2 단계, 이미지 2개 중 1개 MacBook Pro 17" Unibody Feet Replacement: 2 단계, 이미지 2개 중 2개
    • Wedge your fingers between the lower case and the vent, and lift upward to release the two clips holding the lower case to the upper case.
    • During reassembly, carefully align the lower case and then press it firmly until both clips engage.
    • Remove the lower case.
  3. MacBook Pro 17" Unibody Feet Replacement, Feet: 3 단계, 이미지 3개 중 1개 MacBook Pro 17" Unibody Feet Replacement, Feet: 3 단계, 이미지 3개 중 2개 MacBook Pro 17" Unibody Feet Replacement, Feet: 3 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Remove any broken or damaged feet.
    • Remove any pieces from the old foot that may have broken off in the foot hole.
    • Use tweezers to peel up and remove the old adhesive tape from the foot pad.
  4. MacBook Pro 17" Unibody Feet Replacement: 4 단계, 이미지 1개 중 1개
    • Scrub the foot pad with adhesive remover to remove any remaining adhesive.
  5. MacBook Pro 17" Unibody Feet Replacement: 5 단계, 이미지 1개 중 1개
    • Wipe the foot pad with an alcohol prep pad to remove any residue left by the cleaner.
  6. MacBook Pro 17" Unibody Feet Replacement: 6 단계, 이미지 1개 중 1개
    • Peel a replacement foot from the plastic backing.
  7. MacBook Pro 17" Unibody Feet Replacement: 7 단계, 이미지 3개 중 1개 MacBook Pro 17" Unibody Feet Replacement: 7 단계, 이미지 3개 중 2개 MacBook Pro 17" Unibody Feet Replacement: 7 단계, 이미지 3개 중 3개
    • Align the new foot inside the foot pad.
    • Make sure the alignment nub on the foot is lined up with the small hole near the perimeter of the pad.
    • Lay the foot down while keeping it properly aligned.
    • Check for proper alignment from the inside of the lower case. Use tweezers to slide the alignment nub so it lines up with the hole.
  8. MacBook Pro 17" Unibody Feet Replacement: 8 단계, 이미지 1개 중 1개
    • Press the new foot down firmly with your finger and maintain pressure for 30 seconds to set the pressure sensitive adhesive. Support the other side of the cover while you press the foot down.
    • Repeat the last six steps for any broken or damaged feet.
결론
To reassemble the device, replace the lower case and all of the screws.
다른 10명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Arthur Shi
회원 가입일: 01/03/18
309,598 평판
안내서 701개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,608개를 작성함
2가이드 댓글
I’m not sure if you really need to remove the lower case. It doesn’t really hurt it to do it though, give you a chance to blow out the accumulated dust.
snoakes1 - 답글
Great tip. Looks like I was doing it wrong. I’ll try that next time.
lovemymac - 답글
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 37
지난 30일: 133
전체 시간: 3,072
