주요 콘텐츠로 건너뛰기
MacBook Unibody Model A1278 Access Door Replacement
필요한 것
  1. MacBook Unibody Model A1278 Access Door Replacement, Access Door: 1 단계, 이미지 1개 중 1개
    • With the case closed, place the Unibody top-side down on a flat surface.
    • Depress the grooved side of the access door release latch enough to grab the free end. Lift the release latch until it is vertical.
  2. MacBook Unibody Model A1278 Access Door Replacement: 2 단계, 이미지 1개 중 1개
    • The access door should now be raised enough to lift it up and out of the Unibody.
결론
다른 55명이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
Walter Galan
706,355 평판
안내서 1,203개를 작성함
3가이드 댓글
Are there more than one A1278? Mine is the MacBook Pro 13” from 2010, which has no access door, but just a single body shell (613-8316-A)
Martin - 답글
Yes there are multiple machines with the model identifier A1278. In fact all non retina 13“ MacBook Pro models share the same A1278 model identifier as well as the Late 2008 Aluminum MacBook. However only the Late 2008 MacBook has the split access door.
Carl Hauschke -
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 13
지난 30일: 54
전체 시간: 42,835
