이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
This guide will show you how to remove the Access Door from your laptop.
필요한 것
With the case closed, place the Unibody top-side down on a flat surface.
Depress the grooved side of the access door release latch enough to grab the free end. Lift the release latch until it is vertical.
다른 55명이 해당 안내서를 완성하였습니다.
댓글 3개
Are there more than one A1278? Mine is the MacBook Pro 13” from 2010, which has no access door, but just a single body shell (613-8316-A)
Yes there are multiple machines with the model identifier A1278. In fact all non retina 13“ MacBook Pro models share the same A1278 model identifier as well as the Late 2008 Aluminum MacBook. However only the Late 2008 MacBook has the split access door.
Esenyurt Konut Projeleri thanks for helpfull writing
