주요 콘텐츠로 건너뛰기
MacBook Unibody Model A1278 LVDS Display Cable Replacement
필요한 것
  1. MacBook Unibody Model A1278 LVDS Display Cable Replacement, Access Door: 1 단계, 이미지 1개 중 1개
    • With the case closed, place the Unibody top-side down on a flat surface.
    • Depress the grooved side of the access door release latch enough to grab the free end. Lift the release latch until it is vertical.
  2. MacBook Unibody Model A1278 LVDS Display Cable Replacement: 2 단계, 이미지 1개 중 1개
    • The access door should now be raised enough to lift it up and out of the Unibody.
  3. MacBook Unibody Model A1278 LVDS Display Cable Replacement, Battery: 3 단계, 이미지 1개 중 1개
    • Be sure the access door release latch is vertical before proceeding.
    • Grab the white plastic tab and pull the battery up and out of the Unibody.
  4. MacBook Unibody Model A1278 LVDS Display Cable Replacement, Lower Case: 4 단계, 이미지 1개 중 1개
    • Remove the following eight screws securing the lower case to the chassis:
    • One 3 mm Phillips screw.
    • Four 3.5 mm Phillips screws.
  5. MacBook Unibody Model A1278 LVDS Display Cable Replacement: 5 단계, 이미지 1개 중 1개
    • Using both hands, lift and remove the lower case off the upper case.
  6. MacBook Unibody Model A1278 LVDS Display Cable Replacement, Display Assembly: 6 단계, 이미지 1개 중 1개
    • Disconnect the camera cable by pulling the male end straight away from its socket.
    • Be careful not to pull up on the cable as you remove it from the socket.
  7. MacBook Unibody Model A1278 LVDS Display Cable Replacement: 7 단계, 이미지 2개 중 1개 MacBook Unibody Model A1278 LVDS Display Cable Replacement: 7 단계, 이미지 2개 중 2개
    • De-route the camera data cable from the channel in the optical drive.
  8. MacBook Unibody Model A1278 LVDS Display Cable Replacement: 8 단계, 이미지 2개 중 1개 MacBook Unibody Model A1278 LVDS Display Cable Replacement: 8 단계, 이미지 2개 중 2개
    • Remove the following screws securing the camera data cable and right speaker to the upper case:
    • One 9.9 mm partially threaded Phillips screw
    • One 9.6 mm threaded Phillips screw
    • One 4 mm Phillips screw
    • Slide the camera cable bracket out from under the subwoofer and remove it from the computer.
    • The iSight cable has an eyelet through which passes the left-most screw in these pictures.
  9. MacBook Unibody Model A1278 LVDS Display Cable Replacement: 9 단계, 이미지 2개 중 1개 MacBook Unibody Model A1278 LVDS Display Cable Replacement: 9 단계, 이미지 2개 중 2개
    • Grab the plastic pull tab secured to the display data cable lock and rotate it toward the DC-in side of the computer.
    • Pull the display data cable connector straight away from its socket.
    • Make sure to pull the connector straight away and not straight up from its socket.
  10. MacBook Unibody Model A1278 LVDS Display Cable Replacement: 10 단계, 이미지 2개 중 1개 MacBook Unibody Model A1278 LVDS Display Cable Replacement: 10 단계, 이미지 2개 중 2개
    • Remove the following two screws from the display data cable bracket:
    • One 7 mm Phillips screw.
    • One 5 mm Phillips screw.
    • Lift the display data cable bracket out of the upper case.
  11. MacBook Unibody Model A1278 LVDS Display Cable Replacement: 11 단계, 이미지 1개 중 1개
    • Remove the two outer 6 mm Torx screws securing each side of the display to the upper case (4 screws total).
  12. MacBook Unibody Model A1278 LVDS Display Cable Replacement: 12 단계, 이미지 1개 중 1개
    • Open your MacBook so the display is perpendicular to the upper case.
    • Place your opened MacBook on a table as pictured.
    • While holding the display and upper case together with your left hand, remove the 6 mm Torx screw from the lower display bracket.
  13. MacBook Unibody Model A1278 LVDS Display Cable Replacement: 13 단계, 이미지 1개 중 1개
    • Be sure to hold the display and upper case together with your left hand. Failure to do so may cause the freed display/upper case to fall, potentially damaging each component.
    • Remove the last remaining 6 mm Torx screw securing the display to the upper case.
  14. MacBook Unibody Model A1278 LVDS Display Cable Replacement: 14 단계, 이미지 3개 중 1개 MacBook Unibody Model A1278 LVDS Display Cable Replacement: 14 단계, 이미지 3개 중 2개 MacBook Unibody Model A1278 LVDS Display Cable Replacement: 14 단계, 이미지 3개 중 3개
    • Grab the upper case with your right hand and rotate it slightly toward the top of the display so the upper display bracket clears the edge of the upper case.
    • Rotate the display slightly away from the upper case.
    • Lift the display away from the upper case, minding any brackets or cables that may get caught.
  15. MacBook Unibody Model A1278 LVDS Display Cable Replacement, Front Display Glass: 15 단계, 이미지 2개 중 1개 MacBook Unibody Model A1278 LVDS Display Cable Replacement, Front Display Glass: 15 단계, 이미지 2개 중 2개
    • In the following steps, you will use a heat gun to soften the adhesive securing the outer black border around the underside of the front glass panel to the display. The area the adhesive is applied to is shown in red in the second picture.
    • With the heat gun set to low, start by heating the outer black border near the upper right corner of the glass panel.
    • Always aim the heat gun away from the soft rubber strip around the display glass. Heating the rubber will cause it to melt slightly, turning its finish from matte to glossy. Touching overheated rubber can cause it to permanently deform.
    • Due to the heat applied, it is normal for a layer of condensation to develop on the inside of the glass panel and/or the outside of the LCD. It can be removed with glass cleaner once the glass is separated from the display.
  16. MacBook Unibody Model A1278 LVDS Display Cable Replacement: 16 단계, 이미지 3개 중 1개 MacBook Unibody Model A1278 LVDS Display Cable Replacement: 16 단계, 이미지 3개 중 2개 MacBook Unibody Model A1278 LVDS Display Cable Replacement: 16 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    Heavy-Duty Suction Cups (Pair)
    $14.95
    • With the panel sufficiently heated, fasten a heavy-duty suction cup near the upper right corner of the display glass.
    • Don't fasten the suction cup on top of the rubber strip around the edge of the display glass.
    • To attach the suction cups we sell, first position the suction cup with the movable handle parallel to the face of the glass panel. While lightly holding the suction cup against the glass, raise the movable handle until it is parallel with the other handle.
    • Slowly and gently pull the corner of the display glass up off the display assembly.
    • If only the top edge of the glass lifts up (as seen in the third picture), repeat steps one and two until you can lift up the corner of the panel.
  17. MacBook Unibody Model A1278 LVDS Display Cable Replacement: 17 단계, 이미지 3개 중 1개 MacBook Unibody Model A1278 LVDS Display Cable Replacement: 17 단계, 이미지 3개 중 2개 MacBook Unibody Model A1278 LVDS Display Cable Replacement: 17 단계, 이미지 3개 중 3개
    • Gently lift the corner of the display glass enough to insert a spudger between it and the display assembly.
    • Use the flat end of a spudger to gently pry up the adhesive securing the front glass to the display.
    • Pry up the glass panel a few inches away from the upper right corner along the top and right edges of the display.
  18. MacBook Unibody Model A1278 LVDS Display Cable Replacement: 18 단계, 이미지 2개 중 1개 MacBook Unibody Model A1278 LVDS Display Cable Replacement: 18 단계, 이미지 2개 중 2개
    • Use a heat gun to soften the adhesive under the black strip along the right side of the front glass panel.
    • Attach a suction cup along the right side of the front glass panel.
    • Pull up on the glass panel while you use the flat end of a spudger to separate it from the rest of the display assembly.
    • Continue working along the right edge of the front display glass until it is separated from the display.
    • It may be helpful to use a guitar pick or another thin plastic object to keep the upper right corner of the front glass panel from sticking back down to the display assembly.
  19. MacBook Unibody Model A1278 LVDS Display Cable Replacement: 19 단계, 이미지 2개 중 1개 MacBook Unibody Model A1278 LVDS Display Cable Replacement: 19 단계, 이미지 2개 중 2개
    • Use your heat gun to soften the adhesive under the black strip along the top edge of the glass display panel.
    • Attach a suction cup near the top edge of the glass display panel and use it to pull the glass panel up off the display.
    • Work along the top edge of the glass panel, carefully using the flat end of a spudger to separate the adhesive if necessary.
  20. MacBook Unibody Model A1278 LVDS Display Cable Replacement: 20 단계, 이미지 2개 중 1개 MacBook Unibody Model A1278 LVDS Display Cable Replacement: 20 단계, 이미지 2개 중 2개
    • Use a heat gun to soften the adhesive under the black strip near the upper left corner of the glass display panel.
    • Attach a suction cup near the upper left corner of the glass display panel.
    • Pull up on the suction cup and use the flat end of a spudger to carefully pry the glass display panel out of the display assembly.
    • Once the upper left corner has been separated from the display, it may be helpful to use a guitar pick or another thin plastic object to keep the glass from sticking back down to the display assembly.
  21. MacBook Unibody Model A1278 LVDS Display Cable Replacement: 21 단계, 이미지 2개 중 1개 MacBook Unibody Model A1278 LVDS Display Cable Replacement: 21 단계, 이미지 2개 중 2개
    • Use a heat gun to soften the adhesive under the black strip along the left side of the front glass panel.
    • Attach a suction cup along the left side of the front glass panel.
    • Continue working along the left edge of the front display glass until it is separated from the display.
  22. MacBook Unibody Model A1278 LVDS Display Cable Replacement: 22 단계, 이미지 2개 중 1개 MacBook Unibody Model A1278 LVDS Display Cable Replacement: 22 단계, 이미지 2개 중 2개
    • Now that the top, left, and right edges of the glass are free from the display, slowly lift the top edge of the glass panel and gently rotate it out of the display.
    • If necessary, use the flat end of a spudger to free the bottom edge of the glass display panel from the display assembly.
    • Before reassembling, be sure to clean both the inside of the glass display panel and the LCD as any dust or fingerprints trapped inside will be annoyingly visible when the machine is on. It is recommended to use a silicon roller and sticky sheets to clean well.
  23. MacBook Unibody Model A1278 LVDS Display Cable Replacement: 23 단계, 이미지 2개 중 1개 MacBook Unibody Model A1278 LVDS Display Cable Replacement: 23 단계, 이미지 2개 중 2개
    • Insert the edge of a plastic opening tool between the display glass and the camera bracket, and run it around the camera bracket to separate it from the display glass.
    • Do not forget to stick the camera bracket down to the new front display glass before reassembly.
  24. MacBook Unibody Model A1278 LVDS Display Cable Replacement: 24 단계, 이미지 3개 중 1개 MacBook Unibody Model A1278 LVDS Display Cable Replacement: 24 단계, 이미지 3개 중 2개 MacBook Unibody Model A1278 LVDS Display Cable Replacement: 24 단계, 이미지 3개 중 3개
    • During the glass removal process, the AirPort & iSight data cable may stick to the adhesive on the glass panel, disconnecting it from the camera board as the panel is lifted. If your AirPort & iSight data cable is still connected to the camera board, skip this step.
    • If your objective is to remove the camera board, skip this step as reconnecting the AirPort & iSight data cable is not necessary.
    • To reconnect the cable, first use the tip of a spudger to remove the piece of foam tape over the AirPort & iSight data cable ZIF socket.
    • Use the tip of a spudger to flip up the ZIF cable retainer on the AirPort & iSight data cable socket.
    • Insert the AirPort & iSight data cable into its socket on the camera board and use the tip of a spudger to snap down the ZIF cable retainer, locking the cable in place.
    • Reapply the piece of tape covering the AirPort & iSight data cable socket.
  25. MacBook Unibody Model A1278 LVDS Display Cable Replacement, Clutch Cover: 25 단계, 이미지 2개 중 1개 MacBook Unibody Model A1278 LVDS Display Cable Replacement, Clutch Cover: 25 단계, 이미지 2개 중 2개
    • Slide the clutch cover toward the right edge of the display.
    • The clutch cover will move approximately .5" and stop. Do not force it too far to the right.
    • When reinstalling the clutch cover, be sure to slip it over the components protruding from the lower edge of the display about .25" to the right of its final installed position on the display.
  26. MacBook Unibody Model A1278 LVDS Display Cable Replacement: 26 단계, 이미지 3개 중 1개 MacBook Unibody Model A1278 LVDS Display Cable Replacement: 26 단계, 이미지 3개 중 2개 MacBook Unibody Model A1278 LVDS Display Cable Replacement: 26 단계, 이미지 3개 중 3개
    • Starting at its far right end, rock the clutch cover along its long axis while pulling it away from the clutch hinge.
    • Working from right to left, carefully continue to release and lift the clutch along the lower edge of the display assembly.
    • Lift the clutch cover up off the front bezel and set it aside.
    • When reinstalling the clutch cover, be sure to widen the opening when slipping it over the small black plastic cosmetic cover that fills the open end of the clutch cover when it is in place. The cosmetic cover has very thin and delicate plastic arms that hold it to the right clutch hinge.
  27. MacBook Unibody Model A1278 LVDS Display Cable Replacement, LCD Panel: 27 단계, 이미지 1개 중 1개
    • De-route the display data cable from its retaining bracket near the lower left edge of the display.
  28. MacBook Unibody Model A1278 LVDS Display Cable Replacement: 28 단계, 이미지 1개 중 1개
    • Remove the following six screws securing the LCD panel to the front bezel:
    • Four 3.25 mm Phillips with large heads.
    • Two 3.2 mm Phillips with small heads.
  29. MacBook Unibody Model A1278 LVDS Display Cable Replacement: 29 단계, 이미지 1개 중 1개
    • Do not try to remove the LCD yet. The circuitry along its lower edge is wedged in a gap along the lower edge of the display recess in the aluminum display assembly.
    • Hold the display vertically and tip it enough to grab the top edge of the LCD and rotate it slightly out of the display assembly, being careful not to break the circuitry off its lower edge.
    • Pull the LCD toward the top edge of the display to slide the circuitry along its lower edge out of the recess in the aluminum display assembly.
    • It may be helpful to use one hand to feed the display data cable through its channel in the aluminum display assembly as you pull the LCD toward the top edge of the display with the other hand.
  30. MacBook Unibody Model A1278 LVDS Display Cable Replacement: 30 단계, 이미지 1개 중 1개
  31. MacBook Unibody Model A1278 LVDS Display Cable Replacement: 31 단계, 이미지 1개 중 1개
    • Peel the piece of tape covering the display data cable connector away from the edge closest to the LCD.
  32. MacBook Unibody Model A1278 LVDS Display Cable Replacement: 32 단계, 이미지 2개 중 1개 MacBook Unibody Model A1278 LVDS Display Cable Replacement: 32 단계, 이미지 2개 중 2개
    • Use the tip of a spudger to flip up the thin steel retaining clip securing the display data cable to its socket on the LCD.
    • Pull the display data cable straight away from its socket on the LCD.
    • Lift the LCD out of the display assembly and set it aside.
  33. MacBook Unibody Model A1278 LVDS Display Cable Replacement, LVDS Display Cable: 33 단계, 이미지 2개 중 1개 MacBook Unibody Model A1278 LVDS Display Cable Replacement, LVDS Display Cable: 33 단계, 이미지 2개 중 2개
    • Carefully route the LVDS display data cable through the slot located to the left of the antenna assembly.
    • Do not use excessive force as you may damage the LVDS display data cable.
    • Lift and remove the LVDS display data cable from the display assembly.
결론
다른 10명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Walter Galan
706,282 평판
안내서 1,203개를 작성함
6가이드 댓글
do i need a new display glass to reassemble the macbook or can i reuse the old one?
joergzambo - 답글
Still a very interesting question?Can I use the old display glass to reassemble the macbook (in reverse order) or is that only going to work with a new display or glue or whatsoever?
gsdfw442f -
On an A1278 13" MBP, the guide does not seem correct... It is not the split-back, and the cables are in different sections
Luke Barone - 답글
I'm glad you pointed this out, but it's weird that nothing's been changed.
dcole871 -
I did it but broke the glass. Be careful!
keyneschang - 답글
댓글 쓰기
조회 통계:
지난 24시간: 8
지난 7일: 43
지난 30일: 256
전체 시간: 89,017
