주요 콘텐츠로 건너뛰기
MacBook Unibody Model A1342 AirPort/Bluetooth Board Replacement
필요한 것
  1. MacBook Unibody Model A1342 AirPort/Bluetooth Board Replacement, Lower Case: 1 단계, 이미지 1개 중 1개
    • Remove the eight 4 mm Phillips screws securing the lower case to the MacBook.
  2. MacBook Unibody Model A1342 AirPort/Bluetooth Board Replacement: 2 단계, 이미지 3개 중 1개 MacBook Unibody Model A1342 AirPort/Bluetooth Board Replacement: 2 단계, 이미지 3개 중 2개 MacBook Unibody Model A1342 AirPort/Bluetooth Board Replacement: 2 단계, 이미지 3개 중 3개
    • The lower case is constructed of rubber-coated aluminum. Do not excessively bend the aluminum during removal, as any permanent deformation will cause tolerance issues after reassembly.
    • Slightly lift the lower case near the vent opening.
    • Continue running your fingers between the lower and upper cases until the upper case pops off its retaining clips.
    • The location of these three clips is shown in the third picture.
  3. MacBook Unibody Model A1342 AirPort/Bluetooth Board Replacement, Battery: 3 단계, 이미지 1개 중 1개
    • For precautionary purposes, we advise that you disconnect the battery connector from the logic board to avoid any electrical discharge. This step is optional and is not required.
    • Use the flat end of a spudger to lift the battery connector up out of its socket on the logic board.
    • It may be easier to use your fingernails to lift up on both sides of the connector.
  4. MacBook Unibody Model A1342 AirPort/Bluetooth Board Replacement, Rear Vent: 4 단계, 이미지 1개 중 1개
    • Remove the following screws from the optical drive side of the rear vent:
    • Two 10 mm T8 Torx
    • Two 5.2 mm Phillips
  5. MacBook Unibody Model A1342 AirPort/Bluetooth Board Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the following screws from the port side of rear vent:
    • Two 10 mm T8 Torx
  6. MacBook Unibody Model A1342 AirPort/Bluetooth Board Replacement: 6 단계, 이미지 1개 중 1개
    • Carefully lift the rear vent out of the upper case.
  7. MacBook Unibody Model A1342 AirPort/Bluetooth Board Replacement, Rear Speaker Assembly: 7 단계, 이미지 1개 중 1개
    • Use the flat end of a spudger to pry the AirPort/Bluetooth cable connector up off the logic board.
  8. MacBook Unibody Model A1342 AirPort/Bluetooth Board Replacement: 8 단계, 이미지 1개 중 1개
    • Remove the following screws securing the right speaker assembly to the upper case:
    • One 12 mm Phillips screw.
    • One 3 mm Phillips screw.
  9. MacBook Unibody Model A1342 AirPort/Bluetooth Board Replacement: 9 단계, 이미지 1개 중 1개
    • Remove the single 2.2 mm Phillips screw inserted horizontally into the side of the optical drive.
  10. MacBook Unibody Model A1342 AirPort/Bluetooth Board Replacement: 10 단계, 이미지 2개 중 1개 MacBook Unibody Model A1342 AirPort/Bluetooth Board Replacement: 10 단계, 이미지 2개 중 2개
    • Pry the AirPort and Bluetooth antenna connectors (3 total) up off the AirPort/Bluetooth card.
    • De-route the long antenna from its channel in the rear speaker housing.
  11. MacBook Unibody Model A1342 AirPort/Bluetooth Board Replacement: 11 단계, 이미지 1개 중 1개
    • Use the flat end of a spudger to pry the rear speaker cable connector up off the logic board.
  12. MacBook Unibody Model A1342 AirPort/Bluetooth Board Replacement: 12 단계, 이미지 1개 중 1개
    • Remove the rear speaker assembly from the upper case.
  13. MacBook Unibody Model A1342 AirPort/Bluetooth Board Replacement: 13 단계, 이미지 2개 중 1개 MacBook Unibody Model A1342 AirPort/Bluetooth Board Replacement: 13 단계, 이미지 2개 중 2개
    • Carefully peel the AirPort/Bluetooth cable from its channel within the rear speaker assembly.
    • Use the flat end of a spudger to pry the AirPort/Bluetooth cable up off the rear speaker.
  14. MacBook Unibody Model A1342 AirPort/Bluetooth Board Replacement: 14 단계, 이미지 1개 중 1개
    • Remove three 3 mm Phillips screws securing the AirPort/Bluetooth board to the rear speaker assembly.
  15. MacBook Unibody Model A1342 AirPort/Bluetooth Board Replacement: 15 단계, 이미지 1개 중 1개
    • Lift the AirPort/Bluetooth board up off the rear speaker assembly.
  16. MacBook Unibody Model A1342 AirPort/Bluetooth Board Replacement, AirPort/Bluetooth Board: 16 단계, 이미지 1개 중 1개
    • AirPort/Bluetooth board remains.
결론
다른 30명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Walter Galan
701,042 평판
안내서 1,203개를 작성함
댓글 3개
Terrific guide; no problems, at all! Don't forget you need to add the Wi-Fi service back to the list of services:
1. Go to System Preferences → Network and click the + button to add a service.
2. Select Wi-Fi as the Interface and provide a service name.
For more info, please see http://apple.stackexchange.com/questions....
schmidtjoel - 답글
At Step 11 I accidently pulled the connector off the board incorrectly and it won't fit back on. What is the difficulty level of resoldering this back onto the logic board or should I take it to a professional?
gregpif - 답글
Hello!
Does anyone know where I could find this bt card but with Bt 4.0 LE in order to get handoff and continuity to work on this A1342 Macbook?
Thanks!
junkprotectorvpc - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 8
지난 30일: 27
전체 시간: 42,132
